Author Topic: Veglia Gauges Remove Bezel  (Read 5335 times)
Offline Stephen Hill
    • Wildgoose Chase Moto Guzzi
« on: October 31, 2017, 12:23:33 PM »
I would like to remove the bezels on the tach and speedo on my 1976 LeMans.  The lenses are quite dirty on the inside, and will clean up if I can get the bezels off.
I have no idea how hard this is to do, or how destructive I would need to be.  I'd rather live with dirty gauges than broken bits.  Anyone taken them apart, and if so, how tough is it to do??
BTW, is there a short form/code for identifying "classic" guzzi vs new guzzi threads?  I feel like I waste too much time scanning threads that are irrelevant to my bike/interests.
Stephen Hill
1977 Moto Guzzi LeMans Mk1
1989 Honda NT650, 1999 Honda VFR
1956 BSA Gold Star, 1968 BSA Royal Star
1968 Triumph Bonneville, 1969 Triumph Daytona, 1973 Triumph Trident
1968 Norton Fastback, 1969 Norton 650SS, 1972 Norton Commando Combat, 1974 Norton Commando Interstate
Offline Groover
    • Scooteropolis
Re: Veglia Gauges Remove Bezel
« Reply #1 on: October 31, 2017, 01:05:12 PM »
Not the exact ones, but same idea.
http://www.thisoldtractor.com/moto_guzzi_loopframe_gauge_trim_ring_removal_and_installation.html
Other than that, not sure what the best way would be. Can opener?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #2 on: October 31, 2017, 01:06:21 PM »
The trick is to keep the bezel from deforming while you use a tack puller, small screwdriver, or some tool you've made up to carefully pry the crimp up. I machined a pocket that it fit into. Others have used a hose clamp.
Putting "remove bezel" in the search box at the top will give you many tips.
Here's the first one that came up..
http://wildguzzi.com/forum/index.php?topic=76486.0
Offline jbell
  • Some progress
« Reply #3 on: October 31, 2017, 01:16:26 PM »
I'm assuming these are crimp on rather than screw on. From my inquiry regarding the same on Smiths gauges there are three methods.
1) Put a large radiator clamp (not too tight) just under the bezel to protect the housing and gently pry the bezel up in very small increments with a tiny screwdriver.
2) Put the large radiator clamp around the top of the bezel. Grind down one side of a set of pliers to fit under the bezel and again pry open in very small increments.
3) If you have a lathe, mount the gauge in the chuck and at low rpms insert a tool or screwdriver under the bezel to gently spin it open.
Again, this was advice for Smiths gauges, just assuming they'll work on Veglias.  I haven't tried this out, just passing on what passed down to me.  Luck!
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
« Reply #4 on: October 31, 2017, 01:25:42 PM »
Sounds like the bezels are crimped on.  I am pretty familiar with re and re bezels on Smith magnetic gauges.  On the Smith gauges. I buy new bezels because the chromed brass bezel generally does not respond well to unbending and rebending.  And new bezels are readily available.
On the Veglia instruments of this era (1976), am I stuck re-using the originals, or are replacement bevels available?
Stephen Hill
« Reply #5 on: October 31, 2017, 01:37:57 PM »
Putting "Veglia replacement bezel" in the search box brings up this thread..
http://wildguzzi.com/forum/index.php?topic=89589.0
Online PeteS
« Reply #6 on: October 31, 2017, 01:45:28 PM »
I haven't done the early Veglias but have done both instruments on my EV. I made a pry bar using a nail. Ground off three sides of the head and sharpened the remaining side. As said above lift only about 10 degrees at a time working around slowly.
Works one time. If you have to do it a second time the bezel will crack.
« Reply #7 on: October 31, 2017, 01:51:08 PM »
As previous have said the bezel is crimped on. I would recommend ordering new bezels, fairly cheap. I have bought several sets form this seller.
https://www.ebay.com/itm/Veglia-80mm-Tachometer-Bezel-Repair-Kit-Ducati-Moto-Guzzi-Morini-Laverda-BLACK/182859860368?hash=item2a934c0990:g:CsIAAOSwTA9X9swc&vxp=mtr
This is a simple clamping tool I made from scrap HPDE (hockey rink board) plastic
I protect the instrument body with a wrap of tape or a hose clamp, work slowly around the ruing with a tiny screwdriver to open the bezel ring.
Putting the new one on is done like this, use a fine brass punch and go round and round slowly tapping the bezel flat, you can get a good result this way.
I now use an old swing arm bearing mounted on a tool post on my lathe, the instrument sits in an aluminum carrier and the bearing is turned up against the bezel as the instrument spins getting a uniform and near perfect crimp of the ring.
This is a Nipon Denso from a Laverda (same as Honda CB750), on the lathe method
