Author Topic: Loop (Eldorado) Rear Hub Cracks !?!?!  (Read 2365 times)
« on: January 01, 2018, 04:38:11 PM »
My Eldorado's rear hub has many cracks in it that start at the corners of the triangular areas where the spokes attach.
Of course, I don't really have any way of determining how deep they go.
Do I need to replace this hub?
upload images to web
Re: Loop (Eldorado) Rear Hub Cracks !?!?!
« Reply #1 on: January 01, 2018, 04:49:02 PM »
The first time I pulled a wheel on my '69 Ambo I freaked out thinking that those were cracks too. But, I had it checked (zyglo tested IIRC) and it turns out they're only marks left during casting and not cracks.
« Last Edit: January 01, 2018, 04:49:25 PM by Antietam Classic Cycle »
« Reply #2 on: January 01, 2018, 04:50:02 PM »
Be sure they are cracks.  Scrub the hub and check visually.  Sometimes those tracks are just that -- tracks of contaminated fluid running down the surface.  Depending on what the contamination is, they can discolor or etch metal surfaces to look like cracks.  Also, you may learn something with the redneck magnaflux test:  Whack the hub with a wrench or other fairly massive metal object.  If it resonates it's good.  If it goes *thunk* it's cracked.  YMMV if the spokes are still in place.
« Reply #3 on: January 01, 2018, 05:23:35 PM »
This is a late '74, disc brake, Eldo, so, maybe they changed get hubs late in production.
I'm going to get it checked with magnaflux.
« Reply #4 on: January 01, 2018, 05:39:01 PM »
Rear hubs were the same on all Loops.
« Reply #5 on: January 01, 2018, 06:28:33 PM »
I just got a chance to get back out to the shop and investigate.  I cleaned up, and now can definitely that the "cracks" are just raised metal that flowed into cracks in the casting mold.
The hub is the same as what Les P posted, just not nice and shiny clean.
Offline ray bear
« Reply #6 on: January 01, 2018, 11:32:54 PM »
The hubs on my V7 sport and Eldorado all look the same, and there may be some fine cracks but most were what appeared to be casting marks, If they were going to break it would have happened many years ago, Put them back on the bike and keep riding and check them again in another 10 years or so.  Bill
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline normzone
« Reply #7 on: January 02, 2018, 10:37:02 AM »
I believe that would actually be the " redneck sonic inspection ". Redneck magnaflux would involve a magnet or other form of magnetic field.
I must have inspected a mile of welds in the eighties. Dye penetrant, and magnetic field indicator used to find welds polished into invisibility so they could be inspected after years in the field. Gahh, makes me ill to think about it. Great tool for the job, but messy.
Offline Don G
« Reply #8 on: January 02, 2018, 03:17:03 PM »
You would have to use dye and a black light on aluminum, magnaflux only works on ferrous metals .  DonG
