Author Topic: Ignition switch disassembly 98EV  (Read 11270 times)
Online JoeB
« on: January 21, 2018, 12:08:46 PM »
Cleaning electrical connections on a 98EV. Pulled the ignition switch and thought I'd ask how it comes apart before I destroy it. New territory for me. Have contact cleaner and some Deoxit. Anything else I should do?
free image hosting reviews
Online JoeB
Re: Ignition switch disassembly 98EV
« Reply #1 on: January 21, 2018, 02:26:48 PM »
Got cap off. Pretty clean. Do I call it good, spray some deoxit and pack a little petroleum jelly in it?
Or is there something on the other side of the white terminal disc that should be looked at?
« Last Edit: January 21, 2018, 02:27:21 PM by JoeB »
« Reply #2 on: January 21, 2018, 02:59:09 PM »
Deoxit is fine stuff.
Offline yogidozer
« Reply #3 on: January 21, 2018, 04:33:55 PM »
were you having a problem, or just killing time during winter?
Offline malik
« Reply #4 on: January 21, 2018, 04:58:29 PM »
If it's much the same as the V7C ignition, there's something on the other side. Mine played up, & when disassembled I found that heat (how'did that get in there?) had deformed the white plastic that supported the contacts so it no longer worked properly. It looked like those white plastic bits SHOULD be available to someone in that niche trade to rebuild, but I thought it too hard to chase down & settled for a replacement switch - & the lock set was not significantly more expensive than a new switch (& it was in stock & the bare switch wasn't).
« Reply #5 on: January 21, 2018, 06:58:20 PM »
I've gotta assume (never had one apart) that the part that needs looked at is on the other side.  :smiley: Probably be brass. Wire brush it, vaseline it, and put it back together.
Maybe something like this?
2017-03-16_04-59-44 by Charles Stottlemyer, on Flickr
« Reply #6 on: January 21, 2018, 09:05:36 PM »
You need to remove the white plate, its held in by 3 clips (part of the outer body), one is different from the other two, unclip that one and tilt the plate out.
The grease goes hard, just wipe it out, I don't like to use solvents incase it attacks the plastic parts, just replace the grease with plain old petroleum jelly aka Vaseline.
When you put it back together, i don't think its possible to get it wrong, try to fix the wires to the back cover, its important the wires don't flex at the solder joint or they will quickly snap off next to the solder.
« Last Edit: January 21, 2018, 09:10:26 PM by Kiwi_Roy »
Offline Motomoto
« Reply #7 on: January 21, 2018, 10:15:08 PM »
Dielectric grease.  Vaseline melts at 37C / 99F; and on a suitable wick, like a cotton ball, (or fabric insulation) makes a handy fire starter.
« Last Edit: January 21, 2018, 10:29:49 PM by Motomoto »
« Reply #8 on: January 22, 2018, 05:01:13 AM »
Deoxit is safe for plastics.  It's wonderful stuff.
Online JoeB
« Reply #9 on: January 22, 2018, 08:25:39 AM »
Thanks all. Yogi, yes it's a winters project, am retired and have all the time I want. Also have some plans this summer and with it being 20 yrs. old a little TLC couldn't hurt.
For those, like me, who have never seen the guts here's a crappy photo.
The under side of the white disc had a thin grey layer of crud on it. The small half plate inside holding the copper contacts falls out easily during disassembly. This half plate can go back in either way so note orientation.
Roy, if there's any possibility  to do it wrong I'm your man.
« Last Edit: January 22, 2018, 08:29:32 AM by JoeB »
« Reply #10 on: January 22, 2018, 08:32:44 AM »
I know I keep harping on this, but these machines are getting old, and the electrical systems are not water/corrosion proof. Take all the connectors apart, De Oxit. Relay bases below..
Stolen from another site.
Need I say more?
« Reply #11 on: January 22, 2018, 09:04:05 AM »
Where did you here that nonsense, electricians have been using Petroleum Jelly aka Vaseline on sliding contacts for at least 60 years that I know of and probably long before my time. Cotton balls and fabric insulation on the other hand may not be a good idea. Several of the members who know something about dielectric grease on the other hand are dead against it for contacts.
Sent from my shoe phone!
« Reply #12 on: January 22, 2018, 09:53:21 AM »
Kingoffleece said "Deoxit is fine stuff", Chuck
When I went to purchase some I was confused by the various options available
Which one do you guys recommend?
« Last Edit: January 22, 2018, 09:55:31 AM by Kiwi_Roy »
« Reply #13 on: January 22, 2018, 10:45:57 AM »
Wayne recommends DeOxit Gold. It's called that because of the price.  :smiley: It's formulated for "electronics connections and contacts"
A little goes a long way, though.
« Reply #14 on: January 22, 2018, 10:46:11 AM »
And on a moving contact that will arc, like an ignition switch, dielectric grease will turn into abrasive silicon dioxide. One of the worse places to use dielectric grease.
