My way of getting grips off:Heat grip a little with a heat gun.Run a screwdriver between the grip and the bar (or throttle drum) from the bar end up the length of the grip, chasing the screwdriver with WD40 through the long applicator snout.As you twist the screwdriver and massage the warmed grip the WD40 spreads and suddenly an easy twist and pull brings it off.
:1: ..gives me just long enough wet and slippery, but then goes away after....
