Author Topic: CONVERT parts info needed  (Read 3210 times)
Offline TOMB
« on: June 10, 2018, 09:36:33 AM »
Searched the on line dealers an looking for some part numbers couldn't find what I was looking for, so here go's.
Can anyone provide the part numbers for a complete seal kit for a Convert transmission ? That would be for the Hyd. side and Gearbox side. Seals and "O" Rings.
Or would each part need to be ordered seperatly?
My existing parts book doesn't show anything for the complete seal / "O" ring kit.
Thanks in advance.
TOMB
« Last Edit: June 10, 2018, 09:37:50 AM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Re: CONVERT parts info needed
« Reply #1 on: June 10, 2018, 10:44:43 AM »
I thought MG Cycle had a kit like that but maybe not. I always had to order it all separate. I may have a list like that in my parts book from doing them 15yrs ago, I'll check.  You don't like being a parts guy? Just part of the job w/you run a 1 man shop.  I find real paper books work better than PDF copies.
Offline TOMB
« Reply #2 on: June 10, 2018, 11:05:26 AM »
I don't mind being a parts guy however when a convert comes through once every 15 years I don't keep those parts around I have plenty of other parts for big block Guzzis but anyway I appreciate any help you can offer thank you very much
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
« Reply #3 on: June 10, 2018, 11:36:06 AM »
Found the book, no notes. I never kept Vert parts in stock although they came through regularly. I just put in an order, always within a few days had it.
I can make you a list if you want, pretty easily.
« Last Edit: June 10, 2018, 11:39:57 AM by guzzisteve »
« Reply #5 on: June 10, 2018, 12:30:27 PM »
When GF was there, MI had a paper template they made with the order of installation, the imprint of each o-ring, and the part itself  taped over the imprint.  That's as close to a "kit" as I've seen.  I doubt the template still exists.  They dumped a lot of good ideas on account of they made too much sense.
Offline TOMB
« Reply #6 on: June 10, 2018, 01:02:17 PM »
 Guzzisteve.
That list would be very helpful.
Thank you for the offer
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
« Reply #7 on: June 10, 2018, 02:13:50 PM »
You need 1 of ea.
Tried to put it in order front to back. If you have a parts book, page is drawing number, and location = #
« Last Edit: June 10, 2018, 02:19:25 PM by guzzisteve »
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #8 on: June 10, 2018, 03:45:37 PM »
Guzzisteve.
TOMB
I scanned the parts manual into a pdf.  If you would like a copy, PM me your email address.
Offline TOMB
« Reply #9 on: June 10, 2018, 04:17:06 PM »
Kiwi steve
PM sent
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
« Reply #10 on: June 10, 2018, 04:54:36 PM »
When I flipped open my note pad to make the list another piece of page fell out, a list of everything (seals,orings,lock washers) to do a 5 speed. Made it for Wavedog last year.   I just started the notepad thing in 07, I used to just put them in the manuals and parts books.
Offline dsrdave
« Reply #11 on: June 10, 2018, 05:58:24 PM »
Moto international has the kit for all seals needed.  Nice quality, everything fits and a fair price.
Offline mtiberio
    • TiberioRacing
« Reply #12 on: June 11, 2018, 12:07:52 PM »
Paul Linn made a list (that one posted may be his). Did you check the yahoo MGConvert group? It would be there under their files or photos section.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline mtiberio
    • TiberioRacing
« Reply #13 on: June 11, 2018, 12:10:36 PM »
Paul's doc was under files...
Convert transmission seals, bearings and o-rings
O-rings
Item # 3 p/n 90706600 (quantity 1)
Item # 8 p/n 90706158 (quantity 1)
Item # 9 p/n 90706473 (quantity 1)
Item # 21p/n 90706188 (quantity 1)
Item # 44 p/n 90706222 (same as Eldorado fork top plug o-ring) (quantity 1)
Item # 48 p/n 90706108 (quantity 1)
Transmission externals:
Item # 3 p/n 18161150 crush washer (quantity 1)
Item # 5 p/n 12008400 crush washer (quantity 1)
Item # 6 p/n 90404563 seal 45x60x7 (quantity 1)
Item # 15 p/n 90402838 seal 28x38x7(quantity 1)
Item # 23 p/n 95100709 crush washer (quantity 1)
Item # 28 p/n 18200350 Gasket (quantity 1)
Item # 29 p/n 90401630 seal 16x30x7/6.5 (quantity 1)
Item # 30 p/n 90403547 seal 35x47x7 (same as 4 & 5 speed output shaft seal) (quantity 1)
Item # 36 p/n 10528900 crush washer  (quantity 2)
Transmission internals:
Item # 5 p/n 90402535 seal 25x35x7 (same as 4 speed input shaft seal) (quantity 1)
Item # 6 p/n 92201220 ball bearing on clutch hub shaft (quantity 1)
Item # 19 p/n 92218421 ball bearing (quantity 1)
Item # 20 p/n 92201420 ball bearing (quantity 2)
Item # 31 p/n 92256218 roller bearing (quantity 2)
Item # 32 p/n 92201425 ball bearing (quantity 1)
Clutch
Item # 15 p/n 18082350 external tang discs (quantity 6)
Item # 16 p/n 61082200 internal splined discs (quantity 5)
« Last Edit: June 11, 2018, 12:11:15 PM by mtiberio »
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #15 on: June 12, 2018, 03:44:59 PM »
Owner called Harper's, we had it all in stock and it's on the way.
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Offline TOMB
« Reply #16 on: June 13, 2018, 10:35:49 AM »
Thanks Curtis.
I'll probably need the same for my Convert to have on hand  when the need arises.
TOMB
TOMB
CENTRAL CONNECTICUT
1980 CX100 50 MILES
MGNOC # 2723
