Author Topic: DOH! O2 wiring  (Read 1617 times)
Offline ediehl
    • EricDiehl
DOH! O2 wiring
« on: June 24, 2018, 02:29:45 PM »
After I bought my 2012 Griso a year or so ago, I removed the Power Commander, with the intent of replacing the Quad D exhaust with the Termignoni. Now I'm finally getting around to the latter, and IO can't remember where those 6 tinned wires in the O2 harness are supposed to connect! I have a dim memory of thinking, when I removed the Power Copmmander, that it would be easy to reconnect the color-coded O2 wires there, but I've yet to figure out wherr that connector is! Well, I guess I'll remove the fuel tank and look there. Argh--dreaded memory loss!
'09 Stelvio NTX
'16 Eldorado 1400
'09 Triumph Tiger 1050 SE
'08 Goldwing
'13 KTM 990 SMT
'01 Buell S3T
'13 Ducati Hyperstrada 812
'03 Kawasaki ZRX 1200R
Offline Kiwi Dave
    • Guzzi Gander Ltd
Re: DOH! O2 wiring
« Reply #1 on: June 24, 2018, 03:11:34 PM »
Can you not get the information from the Dynojet website?
Offline ediehl
    • EricDiehl
Re: DOH! O2 wiring
« Reply #2 on: June 24, 2018, 03:56:13 PM »
I ~think~ I was being confused by the Power Commader/Autotune hardware. I assumed that the O2 sensor I had was from the stock Termignoni exhaust, but after lookeing around some more I'm wondering if it came with the Autotune module. The first pic below is where I think I'm supposed to plug the O2 sensor in (a connector behind the starter), and the 2nd pic is what the connector on the end of the O2 sensor I have looks like. I'll do a bit more investigation, but at this p[oint I'm thinking I just need to purchase a stock O2 sensor
'09 Stelvio NTX
'16 Eldorado 1400
'08 Goldwing
'13 KTM 990 SMT
'01 Buell S3T
Re: DOH! O2 wiring
« Reply #3 on: June 24, 2018, 04:02:15 PM »
I have the instructions if you need them. I installed and set that stuff up also. It is in PDF, can send it to Email.
Online Bisbonian
  • Living the Dream
Re: DOH! O2 wiring
« Reply #4 on: June 24, 2018, 04:05:30 PM »
If you have the Autotune then the O2 sensor will be a wide band sensor specifically for that application. You would have replaced the stock O2 when the Autotune was installed.
beetle
Re: DOH! O2 wiring
« Reply #5 on: June 24, 2018, 04:13:43 PM »
Yes, the stock O2 sensor is a 4-wire unit. That plug you found behind the starter is the correct one.
Offline ediehl
    • EricDiehl
Re: DOH! O2 wiring
« Reply #6 on: June 24, 2018, 04:21:13 PM »
Thanks much! I've abandoned the Power Commander and Autotune, and am going back to the stock setup with the Termignoni pipe (and pretzel, which the Quad D didn't use), and then I'm going to fiddle with Guzzi Diag to get a good tuning.
'09 Stelvio NTX
'16 Eldorado 1400
'08 Goldwing
'13 KTM 990 SMT
'01 Buell S3T
Offline Kiwi Dave
    • Guzzi Gander Ltd
Re: DOH! O2 wiring
« Reply #7 on: June 24, 2018, 08:31:53 PM »
..... and then I'm going to fiddle with Guzzi Diag to get a good tuning.
If you want a quicker way with great results, you might consider purchasing a map already tweaked at http://www.griso.org/.
