Author Topic: Digiplex 2ts 500a swap for 2ts501a??  (Read 2096 times)
Offline izzug otom
« on: July 03, 2018, 09:24:23 AM »
I just wondered if anyone hear would know if a digiplex 2ts501a would work as a suitable swap to test if there's a fault with my digiplex 2ts500a.
The 501a is from a 2002 Nevada carb, whereas the 500a is on my Cali 1100carb '95.
I can't seem to find any info on this anywhere.
Cheers, Izzug
Offline yogidozer
Re: Digiplex 2ts 500a swap for 2ts501a??
« Reply #1 on: July 03, 2018, 11:51:16 AM »
The mapping is likely to be different, but that's not necessarily a bad thing.
Example, I put a digiplex from a Strada in my 95 "spot" 1100. the dreaded flat spot was gone and the gas mileage increased.
Many hae changed the carbs to Keihin's thinking the dellortos were the problem.
So, if were me, and I was pretty sure the box was bad, I'd give it a try.
*** just saw this. this place sells a unit that replaces either. So thinking you have a good chance the 500a will work.
https://www.manta.com/cp/mxjkkdn/51de041765d5efc8250003c9/moto-guzzi-digiplex-2s-ignition-unit
Offline izzug otom
« Reply #2 on: July 03, 2018, 02:51:08 PM »
Interesting mate, thanks very much. I feel confident I won't do any damage trying it at least.  :wink:
Offline yogidozer
« Reply #3 on: July 03, 2018, 02:58:13 PM »
mapping should be the only difference
« Reply #4 on: July 03, 2018, 03:12:34 PM »
I would be looking into the timing on the previous model small block. That will tell you if the timing is close to that of your big block. They are not close to being the same.
It looks like Carmo is repairing w/same as what yours is mapped.
« Last Edit: July 03, 2018, 03:20:04 PM by guzzisteve »
Offline yogidozer
« Reply #5 on: July 03, 2018, 03:52:57 PM »
guzziology has those numbers, but the link shows a replacement digiplex that covers both models.
guessing the op has access to the 501a, both are carb. bikes. think it's worth a try. The Strada digiplex and the spot also had different numbers, and the Strada one actually worked much better on spot.
Offline izzug otom
« Reply #6 on: July 03, 2018, 06:10:35 PM »
Sorry mate I don't follow this at all.  :wink:
« Reply #7 on: July 03, 2018, 06:34:39 PM »
The link that Yogi put up, it is a digital repaired board. It should be the same timing as what you have stock.
Offline yogidozer
« Reply #8 on: July 03, 2018, 06:47:19 PM »
yeah, but they are $434. I thought he had someone who had a 501A, he could try.
Offline izzug otom
« Reply #9 on: July 03, 2018, 10:36:03 PM »
Yes, I have a spare 501A on the shelf.  :wink:
« Last Edit: July 03, 2018, 10:42:00 PM by izzug otom »
