Author Topic: 850T. Should I get the U Joint rebuilt, if so by who?  (Read 2811 times)
Offline NCAmother
« on: July 07, 2018, 09:38:58 AM »
I have a basket case 850T that has been sitting for 10 years.  I believe I should get the U Joint rebuilt, can anyone recommend a good shop/mechanic? Thanks,
Nate
Howdy
Re: 850T. Should I get the U Joint rebuilt, if so by who?
« Reply #1 on: July 07, 2018, 09:48:34 AM »
What makes you think it needs rebuilt? Sloppy?
Offline NCAmother
« Reply #2 on: July 07, 2018, 09:53:15 AM »
It's not sloppy, but I've been scared straight by some U joint failures.  So if its still tight, just use it? Thanks!
Howdy
« Reply #3 on: July 07, 2018, 10:22:41 AM »
wouldn't hurt to take it apart and grease it. troublesome but worth it.
Offline NCAmother
« Reply #4 on: July 07, 2018, 10:33:51 AM »
Thanks John :)
Howdy
« Reply #5 on: July 07, 2018, 10:35:23 AM »
John Chicoine in MA. <jchicoine@verizon.net> $150 return shipping included last I had one done.
« Reply #6 on: July 07, 2018, 02:26:02 PM »
Use a new carrier bearing, it's on of those things that if you can see it, put in a new one
« Reply #7 on: July 07, 2018, 04:57:09 PM »
Plus One
He also has all the parts fore the sugar cube petcocks.
He felt sorry for me and sent me a bible.
Online Perazzimx14
« Reply #8 on: July 08, 2018, 06:25:44 AM »
Plus One
Same dog bit me. John did excellent work on the u-joint for my T3, fast turn around, priced very reasonable and I too got a bible.
Would not hesitate to use this service again.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline huub
« Reply #9 on: July 08, 2018, 01:22:59 PM »
do it yourself , you are looking at 20 dollar worth of parts , and it is a pretty simple procedure
start looking at agricultural parts, the bearings are used for power take off shafts.
as a example on my side of the pond:
https://www.amacoo.nl/aftakas-aandrijving/kruisstukken-voor-aftakassen/kruisstuk-20x44-by-py-05-41
Offline guzzista
« Reply #10 on: July 08, 2018, 03:20:33 PM »
On that subject : http://theujointstore.com/tus1m1.html
In my case, the 850T joint was  easy, comparable to all the automotive ones I have done over the past 30+ years. The T3/ LM/SP OTOH ,due to the difference in crosses  etc, was a PITA and I would either have John C. do it or purchase new
« Last Edit: July 08, 2018, 03:30:09 PM by guzzista »
« Reply #11 on: July 08, 2018, 04:26:44 PM »
^^^^^I've had good service from the ujoint store..
Just the same, I wouldn't rebuild it unless I suspected it of "needing" it. U joints can run for a long time, and I'm lazy.  :grin: :boozing:
