Author Topic: V50-III rocker arm rail torque?????  (Read 1854 times)
Offline not-fishing
« on: August 12, 2018, 07:21:11 PM »
My son's doing a valve adjustment screw replacement on the V50-III we resurrected.  We purchased parts for the repair and now I want to make sure the rocker arm rail goes back at the right torque specs.
Does anyone know the torque specs for the rocker arm rail nuts?
thanks,
Mark Younger
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Re: V50-III rocker arm rail torque?????
« Reply #1 on: August 12, 2018, 08:40:16 PM »
thanks,
Mark Younger
M10-1.5 nuts with 17 mm hex? Those are also the head nuts. 30 ft. lbs.
Offline not-fishing
« Reply #2 on: August 13, 2018, 12:15:09 PM »
Thanks Charlie, I relayed it to my son.
We kept pulling up pictures showing a torque wrench on the rocker "spindle" that referenced the head torque but didn't make the connection.
Now we know.
This should cure his frustration with the one valve always loosening up on him after he had set clearances.
Mark
Griso 1100
Rosso Corsa Lemans
