Author Topic: 1979 G5  (Read 3455 times)
Offline twodogs
1979 G5
« on: December 06, 2018, 02:56:12 PM »
Hi all, I had to remove my front wheel and now I'm putting it back on and my book calls for 100 to 108 ft  lbs of torque on the axle, seems like a lot to me, does that sound right. Any help would be greatly appreciated. Thanks.
Bruce
1983 Honda CB1100F
2024Triumph 400 Speed x2
Re: 1979 G5
« Reply #1 on: December 06, 2018, 03:00:37 PM »
German torque. Gutentight.  :smiley: I believe Pete sez, "until you fart." I don't use a torque wrench. If I was guessing I'd say I put about 80 ft. lbs. on it.
Online Cam3512
Re: 1979 G5
« Reply #2 on: December 06, 2018, 03:05:44 PM »
German constipation?  Farfrompoopin
Re: 1979 G5
« Reply #3 on: December 06, 2018, 04:17:19 PM »
Tighten it to a torque that will allow you to remove it with whatever tools you carry on a trip. In my case, the tool is the original "dog-bone" wrench and the torque figure is ~ 70 ft. lbs.
Re: 1979 G5
« Reply #4 on: December 06, 2018, 06:22:45 PM »
Yeah, the dog bone and a big rock will knock her loose.  :smiley:
Offline twodogs
Re: 1979 G5
« Reply #5 on: December 07, 2018, 06:22:48 AM »
Thanks guys, the reason I asked is after I mounted the wheel and tighten it up it seems like it is really dragging, it probably just the pads on the rotors, but it don't hurt to ask  :boozing:
Bruce
1983 Honda CB1100F
Re: 1979 G5
« Reply #6 on: December 07, 2018, 08:19:51 AM »
Was it dragging before you put the calipers back on?
Offline Roebling3
Re: 1979 G5
« Reply #7 on: December 07, 2018, 08:34:27 AM »
Re: What Chuck has said.
I've sometimes found shim washers, betwixt the caliper & the flanges on the fork leg, to get proper clearances. If you don't expect to see them they can easily vanish and leave a puzzle.  R3~
Offline twodogs
Re: 1979 G5
« Reply #8 on: December 07, 2018, 09:27:49 AM »
I put the shims back where they came out but as usual I did not spin the wheel before I buttoned it back up. Doh.I put it back up on the lift getting ready to take the left head off to replace the o rings and gasket, I'll take the caliper off when I get it back off the lift. I always have to do it twice, you think I would learn  :boozing:
Bruce
1983 Honda CB1100F
Offline bodine99
Re: 1979 G5
« Reply #9 on: December 07, 2018, 10:33:14 AM »
Bruce
Not reading fig-newtons instead of footypounds??
Offline twodogs
Re: 1979 G5
« Reply #10 on: December 07, 2018, 10:50:31 AM »
Sorry about the poor pic.
« Last Edit: December 07, 2018, 10:51:47 AM by twodogs »
1983 Honda CB1100F
Offline wirespokes
Re: 1979 G5
« Reply #11 on: December 07, 2018, 11:28:55 AM »
Loosening the axle nut then spinning the wheel should tell you if the bearings are being overly compressed or if it's just brake drag.
Offline twodogs
Re: 1979 G5
« Reply #12 on: December 08, 2018, 05:58:22 AM »
When ever I take it off the lift I'm going to redo it and only retorque it back to 80  and check everything out a little bit better  :bike-037:
1983 Honda CB1100F
