Author Topic: Breva 1100 starting issue resolved  (Read 2668 times)
Offline flower_king001
« on: December 29, 2018, 04:52:21 PM »
Hi,
 Been having issues on and off since I purchased my Breva 1100 a little over a year ago. I put in a new Motobatt battery last fall and the MPH starter fix along with a new relay for good measure. All seemed good and then again trouble...well I found that the ground to the flimsy stud behind the starter cover was loose and also slight corrosion on the battery terminals. Cleaned the terminals and applied a slight film of petroleum jelly.  All seemed ok and gave it an occasional trickle charge. Yesterday bike would not start but it's been weeks since I last road (EV is my main winter bike) so placed on slow charge and a few hours later bike started and went for a 150 mile ride. This morning bike would NOT start again! Dear Lord...
I'm starting to regret buying this Breva and should have bought a Honda ST1300 but my heart/soul and pride would not let me.
So I checked battery voltage and it was good as well as a load test. Checked cables and ground again and all was well. Fuse and relay checked good and also bench tested the starter as well. So off to Walmart of all places and purchased a 24 inch/4 gauge battery cable. I left the other ground on and also installed this one to the stud off the gearbox right behind the starter. BINGO....started several times without a problem!
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Re: Breva 1100 starting issue resolved
« Reply #1 on: December 29, 2018, 06:41:11 PM »
Even Honda's have problems!! I'll bet the stock wire is all green inside.
« Reply #2 on: December 29, 2018, 10:18:27 PM »
Stock wire inside looked good...main problem not being able to get a good bite/torque on the ground bolt under the plastic starter cover.
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #3 on: December 29, 2018, 10:50:54 PM »
Yea, Guzzi's better idea(not) a 6mm deal instead of 8 or 10 where you could get good torque on it.
« Reply #4 on: December 29, 2018, 11:04:51 PM »
Yes, photo attached of one of Guzzi's better ideas! Use one fragile bolt to ground two wires and while we're at it hold down the (much needed)  :wink: plastic starter cover.
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
