fork seal change info 2002 jackal
Topic: fork seal change info 2002 jackal (Read 4448 times)
troyhamilton
Dr frankie
February 26, 2019, 05:25:18 PM »
My seals are leaking. i want to change them myself is ther a tutorial or video so i can learn this? I know they are differnt than the ones on my 850-1 and I hear they are complicated. oh and we need a tech section badly!
Last Edit: February 26, 2019, 05:48:47 PM by troyhamilton
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
Mr Revhead
Gaggle Mentor
Re: fork seal change info 2002 jackal
Reply #1 on:
February 26, 2019, 07:21:33 PM »
Have you got the work shop manual?
I'm about to do mine on my 03 EV. They look pretty standard as long as you're not disassembling the cartridge, which you don't need to.
troyhamilton
Dr frankie
Reply #2 on:
February 26, 2019, 09:59:11 PM »
i googled it lol. never thought to look at my guzzi ology book...duh
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Mr Revhead
Gaggle Mentor
Reply #3 on:
February 26, 2019, 10:56:01 PM »
:thumb:it's a handy book
s1120
Reply #4 on:
February 27, 2019, 05:55:08 AM »
I found this when looking for service info for my Stone..
http://motoguzzimaintenance.wikifoundry.com/page/Moto+Guzzi+Metal+Stone+Fork+Seal+Replacement
Not a vid, but might help.
Paul B
Perazzimx14
Reply #5 on:
February 27, 2019, 06:31:47 AM »
There are 2 ways fork seal let oil past
1. Dirt gets under the sealing lip holding it open and allowing oil to pass.
2. The sealing lip is cut or damaged allowing a breach for the oil to pass.
Lots of time the real culprit of a leaking seal is scenario #1. So if you can clean the dirt oil and allow the sealing lip to contact the fork leg the leak/weep goes away. Look on youtube at "seal mate" videos to get an ideal of how to clean them. You can make you own "seal name" from a plastic bottle, film negative of any thin semi rigid piece of plastic.
If you have to replace the seals is best to remove the fork leg from the triple. Totally disassembly the forks and clean all parts thoroughly so you can inspect for wear or broken parts. After cleaning and inspection if parts are worn or failed replace them then reassemble the forks with fresh seals and oil and ride captain ride.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Kev m
Not your normal Hombre
Yo from Medford, NJ
Reply #6 on:
February 27, 2019, 06:37:12 AM »
Assuming the 02 is the same as my old 00 I don't recall anything special about it.
I definitely didn't bother to remove the fork legs from the trees.
But it was quite a while ago now.
troyhamilton
Dr frankie
Reply #7 on:
February 27, 2019, 07:33:17 AM »
thanks guys!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
JoeB
Reply #8 on:
February 27, 2019, 07:36:53 AM »
Early EV.
https://motogoose.com/tech-tips/ev11-fork-seal-replacement/
BrotherJim
Gosling
Reply #9 on:
February 27, 2019, 12:27:22 PM »
As mentioned, nothing complicated about the stock forks on an '02 CalStone. I would consider draining them and taking them completely apart (one at a time, of course) and inspect while giving everything a good clean before installing the new seals and reassembly.
Short Time Livin'...
'02 Moto Guzzi California Stone
Mr Revhead
Gaggle Mentor
Reply #10 on:
February 27, 2019, 12:59:22 PM »
Also quite important to change your fork oil. Mines done 68ks and I don't know if it's ever been done. But just recently I played with the settings and found there is no difference at any setting! Oils rooted
troyhamilton
Dr frankie
Reply #11 on:
February 27, 2019, 04:04:09 PM »
i plan to change by oil too. no telling how long its been there.
may be full of trash.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
LowRyter
Reply #12 on:
February 27, 2019, 05:25:27 PM »
all I can say is that I ordered the upper and lower bushings and seals from Harper's and my mechanic did the work.
troyhamilton
Dr frankie
Reply #13 on:
February 27, 2019, 05:32:57 PM »
I am a mechanic. but i just wanted to make sure i was doing it right, new terratory for me.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
giusto
Giusto il canne del Como
Reply #14 on:
February 27, 2019, 06:33:35 PM »
Try this
http://www.thisoldtractor.com/mg_manuals/workshop_manual_california_update_en_de_ne.pdf
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
troyhamilton
Dr frankie
Reply #15 on:
February 27, 2019, 07:52:56 PM »
i just downloaded it, thanks
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
giusto
Reply #16 on:
February 27, 2019, 09:48:59 PM »
Sure thing
Keep Greggs Website "this old tractor" guzzi in your favorites....you'll find a ridiculous amount of information there.
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
