Author Topic: False economy-gaskets  (Read 3617 times)
Offline Rich A
« on: March 08, 2019, 12:34:55 PM »
I reused the valve cover gaskets for my Bassa too many times. The gaskets got stuck onto the covers and I've had to use multiple applications of gasket remover, which has to be toxic, and do a fair amount of scraping to get them off.
Don't do this!
Rich A
« Last Edit: March 08, 2019, 12:44:54 PM by Rich A »
Re: False economy-gaskets
« Reply #1 on: March 08, 2019, 02:55:29 PM »
valve cover gaskets .....    :thewife:
« Reply #2 on: March 08, 2019, 02:57:23 PM »
Extreme Guzzi Content!  :bow:
« Reply #3 on: March 08, 2019, 03:02:48 PM »
Using a heat gun or propane torch, heat the rocker cover until the gasket bubbles and/or smokes. They scrape off easier while "hot".
Offline bigbikerrick
« Reply #4 on: March 08, 2019, 03:55:51 PM »
I have had good luck with the green thicker gaskets, greasing them when first installing. The  cheaper black thinner gaskets dont hold up very well for me. Some day I am going to try the silicone gaskets on the Guzzis that need valve adjustment,
Rick.
Online Vagrant
« Reply #5 on: March 08, 2019, 04:12:38 PM »
green ones sprayed with Pam.
Offline ken farr
« Reply #6 on: March 08, 2019, 04:53:11 PM »
....one of those, HEY, why didn't I think of that..... :bow:
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Online Perazzimx14
« Reply #7 on: March 08, 2019, 05:22:25 PM »
What gasket remover did you use. If it’s Permatex gasket remover you might as well used distilled water.
Aircraft paint stripper is what you need to chemically remove dried on gaskets.
Offline roadscum
« Reply #8 on: March 08, 2019, 05:32:06 PM »
It's been said that the cheapest thing on a Guzzi is the nut on the seat.  Hmmm, maybe it's the truth. :evil:
Paul
"The only true wisdom is in knowing you know nothing " - Socrates
Paul M. in SW Florida: 318 miles, 11 curves and not a Guzzi dealer in sight!
Offline Rich A
« Reply #9 on: March 08, 2019, 05:33:15 PM »
Permatex--it's an old can and has the methylene chloride. Still took multiple applications to get the baked on gaskets off. In fairness, those gaskets were probably on the bike for over 50K mi and only seeped a tiny bit.
Rich A
« Last Edit: March 08, 2019, 06:31:17 PM by Rich A »
Online Perazzimx14
« Reply #10 on: March 08, 2019, 05:47:18 PM »
Permatex. In fairness, those gaskets were probably on the bike for over 50K mi and only seeped a tiny bit.
Rich A
A long time ago Permatex took methylene chloride out of their formula and not it is truly is as worthless as pouring distilled water on an old gasket hoping it'll dissolve or loosen.
There are still chemical gasket removers out there that contain methylene chloride like 3M gasket chisel. But its expensive and hard to find. Fortunately every auto parts store or Walmart in North America have "Aircraft paint stripper" that contain  methylene chloride that eats away in short order old gaskets. The gel is the best spread it on with  Q-tip or flux brush and it stays put. Let it sit for a few minutes then wipe the old gasket away. Repeat a time or 2 more for really stubborn baked on pieces.
Offline Chet Rugg
  • Administrator
  • Chet & Rusty ( 99 Bassa )
« Reply #11 on: March 08, 2019, 05:54:12 PM »
tried them silicone gaskets once. I didn't like them at all. torque um down swishy out is all I can report.
Chet Rugg
99 Bassa
01 Cali Special
100,000 miles
« Reply #12 on: March 08, 2019, 05:55:21 PM »
Trust me, you're MUCH  better off with leaky gaskets than inhaling methyl chloride...ain't worth it....
Online Wayne Orwig
« Reply #13 on: March 08, 2019, 05:57:11 PM »
Scotchbrite Roloc in an angle grind.
Got that setup years ago and use it to clean up everything like that.
Offline guzziownr
« Reply #14 on: March 08, 2019, 06:12:02 PM »
Zip-Strip paint remover.
Look for the words "Methalyne Chloride"  "Toxic" and  "Dangerous". That's the one you want.
I coat both sides of each gasket with Never-Seez prior to installation and after each valve check.
« Reply #15 on: March 08, 2019, 06:28:06 PM »
You don't torque um down.  <shrug> They are used on cheesy stamped metal million dollar aircraft valve covers after carefully straightening them with a peen punch. Snug them up. That's all. Never leak. Last a long time.
Online Perazzimx14
« Reply #16 on: March 08, 2019, 07:01:08 PM »
I'm sure the fatty foods and alcohol I've consumed are by far and away worse than the 1/2 tsp of methylene chlodide contianing gel I use to remove a set of head gasket residue once every 4 years.
« Reply #17 on: March 08, 2019, 07:54:35 PM »
I know, I know...we both ride too fast to worry about cholesterol...and yet
https://www.cbsnews.com/news/dangerous-paint-stripper-chemical-methylene-chloride-ban-on-hold/
« Reply #18 on: March 09, 2019, 12:48:58 AM »
For square fins just get a pair of Valpolini gaskets, Rick and Gordon carry them I think, they’ll last a very, very long time.
« Reply #19 on: March 09, 2019, 01:07:35 AM »
 Good grief , what are you guys doing to these poor gaskets , I have never had one stuck so bad that a little bit of coaxing wouldn't come off . Of course a little anti seize helps .
