Author Topic: stranded by my guzzi for the first time in about 10 years  (Read 3121 times)
Offline lazlokovacs
« on: March 14, 2019, 07:04:15 PM »
recently had front wheel on my lemans removed and powdercoated
routine run from London to Paris and back again,
weird wobble on braking,
inspection revealed a front wheel bearing (left hand side) that was happily disintegrating
quite scary on the superslab
guess the professional mechanic decided it wasn't worth 20 dollar putting some new bearings in there
and I guess he just re-used the old ones after having pulled them out?
guess its good to be reminded that I should never let other people touch my bikes
ride safe!!
Offline giusto
  • Giusto il canne del Como
    • photobucket
Re: stranded by my guzzi for the first time in about 10 years
« Reply #1 on: March 14, 2019, 07:18:10 PM »
I guess you're right.
Glad you're not in a pile along the roadway
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
« Reply #2 on: March 14, 2019, 10:02:46 PM »
I had one disintegrate on my EV, spat out all the balls. The wheel was quite happy traveling home 60 miles with just one.
Since then I always carry a spare on a trip, I may not be able to change it on the roadside but at least I have one to put in.
I don't recommend All Balls, go with a good NA brand, I put a new set in my Griso
Imagine my surprise when I took the wheel off just 8,000 km later.
0ne of the bearings had siezed and chewed out the shaft.
https://image.ibb.co/deOG7p/IMG-0850.jpg
« Last Edit: March 15, 2019, 10:53:12 AM by Kiwi_Roy »
« Reply #3 on: March 14, 2019, 10:13:50 PM »
I stick new ones in every other tire change unless they are good enough to go another one. And if you take a bearing out, put a new one in.
« Reply #4 on: March 14, 2019, 10:18:24 PM »
A good plan to follow, bearings are so cheap, a fraction of the tire price.
Offline Hittman
« Reply #5 on: March 14, 2019, 10:50:55 PM »
Always always always replace a bearing if you take one out.
« Reply #6 on: March 14, 2019, 11:41:56 PM »
is that you, Jack ? Glad you survived winter!     :grin: :shocked:
Offline lazlokovacs
« Reply #7 on: March 15, 2019, 05:26:33 AM »
the plot thickens
turns out that the garage masked the bearings and left them in during the powdercoating
um.......
that seems crazy to me!!! grit and 400 degrees dont mix too good with bearings
any opinions out there?
I feel like they have dealt me a wrong un
Offline Zoom Zoom
« Reply #8 on: March 15, 2019, 05:47:51 AM »
IMHO, yes what they did was not the smartest thing to do. They should know better.
Now as what to do about it? I'm really not sure. To walk in and demand restitution would be the knee jerk reaction, but if it were me under the circumstances, I would try to impress upon them how their negligence could have cost you your life based on their very poor decision to cut corners. I don't know if you found grit in the bearing or not but the prolonged heat alone would be enough to compromise the seals and grease on the bearings.
Somehow, you need to diplomatically get them to get their head out of their a** before they actually cause someone to get hurt. If as a result of that they offer you some compensation then I would take it and go about your life. The eventual outcome of a meeting like that would determine weather I ever returned to or recommended them.
This is something that I feel needs to be face to face!
John Henry
Offline Stevex
« Reply #9 on: March 15, 2019, 07:55:59 AM »
the plot thickens
um.......
You've learnt the hard way.
Whenever I've had wheels powder coated or painted, I fully prep the wheel myself...remove weights, discs and bearings; protect threads with old bolts.
Never trust anyone to engineer your bike, that way you'll never be disappointed.
« Reply #10 on: March 15, 2019, 09:47:16 AM »
They probly left the bearings in to help mask the bearing seat.  It would then be up to the mechanic installing the wheel to be responsible for the decision to reject the bearings.  They are powder coaters,  not responsible for condition of the bearing at wheel installation
« Reply #11 on: March 15, 2019, 10:57:56 AM »
Really! why would you expect the powder coaters to look after the bearings
They are painters not mechanics  :violent1:
« Last Edit: March 15, 2019, 10:59:03 AM by Kiwi_Roy »
