Author Topic: Uh-Oh, Lario  (Read 19271 times)
Offline injundave
Uh-Oh, Lario
« on: March 17, 2019, 10:42:15 PM »
Looks like I am now a Lario owner. I saw this on the Book of Faces today. The previous owner's son borrowed it and it lost power so he pulled over. He and a friend then spent half an hour trying to bump start it with the result that one piston and valve is knackered. Not sure about the head. The price was good and I will go to bring it home later in the week. From the owner's memory its a 1989 model.
« Last Edit: March 17, 2019, 10:43:28 PM by injundave »
1975 850 T3
2019 V85TT
Re: Uh-Oh, Lario
« Reply #1 on: March 18, 2019, 02:07:12 AM »
Now whotcha gone and done Dave. :evil:
Offline malik
Re: Uh-Oh, Lario
« Reply #2 on: March 18, 2019, 02:12:50 AM »
Nice one, Dave. Another just right for UnZud's roads. Let us know if you need anything. There's one in bits in the Shed here, and a frame coming to be fitted with all the Breva bits. Martin (jacksonracing) has posted here with segments of his Lario fettling.
Offline jacksonracingcomau
Re: Uh-Oh, Lario
« Reply #3 on: March 18, 2019, 07:01:57 PM »
welcome to the dark side
do nothing without pulling cam
my one off to tas again today, new tyre just on
any news re case Mal ? I’m just about convinced top end is proven, should start building the roller tappet one soon
Offline injundave
Re: Uh-Oh, Lario
« Reply #4 on: April 04, 2019, 04:12:05 PM »
An update. This arrived this morning. For it's age, according to the spec plate on the steering head its a 1988 model, its in surprisingly good condition cosmetically. The paint looks as though it needs a cut and polish to bring it right back. As yet I haven't been into the engine. I am going to leave it until my wife has seen it, after all she made me buy it because she thought I needed a project after finishing the V50 for my daughter. I have been reading Chuck's and Jim's posts again regarding refurbishing their Larios and talking to Brian about how to make the top end reliable. Looking forward to some fun!
« Last Edit: April 04, 2019, 04:15:43 PM by injundave »
1975 850 T3
2019 V85TT
Offline JACoH
Re: Uh-Oh, Lario
« Reply #5 on: April 04, 2019, 05:53:57 PM »
What are those things on the mufflers, heat shields?
Online Chuck in Indiana
Re: Uh-Oh, Lario
« Reply #6 on: April 04, 2019, 06:15:37 PM »
The look stock to me.. cant see too well with this tablet.
Offline Roebling3
Re: Uh-Oh, Lario
« Reply #7 on: April 04, 2019, 07:21:15 PM »
Injun Dave: Do you know the manufacturer of the fairing?  R3~
Offline injundave
Re: Uh-Oh, Lario
« Reply #8 on: April 04, 2019, 09:39:40 PM »
What are those things on the mufflers, heat shields?  They are heat shields of some kind. The only thing I can think of that they would protect is saddlebags. They are way too far back to do anything for the pillion's feet.
Injun Dave: Do you know the manufacturer of the fairing?  It looks like it has been there forever. The indicator lenses are factory. I just went and had another closer look at the fairing. Some of the mounting hardware looks a bit home made so, maybe, its not an original fixture.
« Last Edit: April 04, 2019, 11:10:00 PM by injundave »
1975 850 T3
2019 V85TT
Offline huub
Re: Uh-Oh, Lario
« Reply #9 on: April 05, 2019, 12:21:12 AM »
nice Buy, there is some info available on how to make them last a bit longer.
keep us posted with your results..
my daily transport lario ( with close to 100.000 km) is developing a interesting vibration at higher revs,
i think i will be changing a camshaft soon.
Offline injundave
Re: Uh-Oh, Lario
« Reply #10 on: April 05, 2019, 11:55:40 PM »
So, this afternoon, a wet and cold one, the first such day this year, well it IS autumn after all) I got out in the shed, put the Lario up on my work bench and started stripping the left side. The tank and side covers came off first and then the valve cover.
Rockers off. Single valve springs! Why did I think they had doubles?
Head off. Oh dear!!!
Piston off.
The head is a real mess.
upload images
New cylinder required.
Not a good picture but there is damage to the cam, specifically the second lobe from the left.
And while I was there I came across this interesting breather arrangement.
The top and bottom hoses come from the rocker cover. The middle one goes down to the sump and the two big ones on the rear side vent under the rear fairing. Tomorrow I will remove the oil pan and pull down the right side. I hope all is well in there.
1975 850 T3
2019 V85TT
Offline malik
Re: Uh-Oh, Lario
« Reply #11 on: April 06, 2019, 01:13:31 AM »
Seriously nasty. I hope your sump is in better shape than the Nevada's -
Yes, that's one of the big end bearings in the top left.
Re: Uh-Oh, Lario
« Reply #12 on: April 06, 2019, 02:11:40 AM »
Dave
talking to Mal the other day, if you decide to put his 2. valve top ends on , and if your rh head is good which almost certainly is
I would like to buy all the lario bits,  both mine did rh side so rh head and piston / barrel exactly what I need for #2
might need to fly over and swap bits but due an unzed visit anyway
pm me if it sounds like a plan
Offline huub
Re: Uh-Oh, Lario
« Reply #13 on: April 06, 2019, 08:58:34 AM »
Head off. Oh dear
that is what a dropped exhaust valve looks like.... been there a couple of times.
the head should be salvageable, , will need some welding , machining and new seats.
i wonder if a cylinder from a two valve engine could be modified to fit , i am running out of cylinders.
apparently yours already had all the factory mods done ( wide cams , single valve springs. )
interesting to see it still dropped a valve
i would be curious what valve was fitted, can you check with a magnet if the exhaust valves  are stainless steel?
first bach was two piece steel,
the second type of valves were one piece stainless, with lash caps to stop the rockers hammering into the valves
the latest  valves should be stainless ( so not magnetic) with just the top of the valves magnetic due to the stellite top.
Offline kevdog3019
Re: Uh-Oh, Lario
« Reply #14 on: April 06, 2019, 11:25:21 AM »
For the upper end of these engines you need upper end parts. Lots of weak areas and eventually your weakest link will give.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline injundave
Re: Uh-Oh, Lario
« Reply #15 on: April 06, 2019, 11:58:37 PM »
Back to the shed this morning. We changed from Daylight Saving Time to NZ Standard Time last night so I have a theoretical extra hour to play with. First things first, I stripped the toasted head.
The valve springs are single but not progressive.
I tested the valves and found them all to be magnetic so indications are that they are the factory two-piece? Then I started on the right side.
I can still see the cross-hatching in the cylinder.
A short while later I had the frame separated from the rest of the bike.
<br
Lots more work saw the sump off. This is what we found in the bottom!
The damage to the cam lobe is more apparent in this photo.
While I was doing the spanner work my amazing wife was busy with degreaser and a selection of brushes. Here is the result.
Its almost 5.00pm. Time for food and, more importantly, a hot shower. More tomorrow.
« Last Edit: April 07, 2019, 12:00:10 AM by injundave »
1975 850 T3
2019 V85TT
Offline huub
Re: Uh-Oh, Lario
« Reply #16 on: April 07, 2019, 01:43:24 AM »
a broken camchain tensioner, first time i see one of those.
apparently somebody just removed the inner valve springs , in a efford to stop the valves from snapping.
used to be a pretty  common mod
unfortunately he did not  change the valves.
« Last Edit: April 07, 2019, 02:56:31 PM by huub »
Offline dguzzi
Re: Uh-Oh, Lario
« Reply #17 on: April 07, 2019, 04:49:14 PM »
Such a nice looking bike...wonder how a newer engine might fit.  I know its a sacrilege.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Re: Uh-Oh, Lario
« Reply #18 on: April 07, 2019, 06:47:56 PM »
single springs look same as oe on the v75 head I found in France, really odd bit is the +.7 mm preload spacer they also fitted, proper wtf moment
cheapest easiest thing to do
not sacrilege if he sells me lario bits to recycle
that should make swap a pretty painless e$perience esp as Mal has one , only Tasman Sea is in the way
Offline injundave
Re: Uh-Oh, Lario
« Reply #19 on: April 07, 2019, 11:12:46 PM »
I have been finding some odd and bizarre things about this bike. The breather system was one, but this one is really weird
The clutch actuator arm was extended and the other piece raised the rear anchor point for the outer clutch cable. Not what you might call an elegant solution, but it really begs the question "Why?" When I removed the sheet metal extension I found the original lever beneath, in perfect condition. All I can think of is that there may, sometime in the past, have been s difficulty in obtaining a clutch cable and that this enabled something else to be used.
I have been right inside. The sludge trap was clean and, although showing some small bright inclusions, the main bearings show little sign of wear. I think that the engine went bang and stopped before there was time for anything nasty to get pumped through. The oil pump looks pristine and had no detritus in it. Even the oil filter had no bits in it although the wire screen was covered.
There is no detectable up & down movement in the big ends. The big end bolts are so tight that my 10mm socket, although a good fit, wants to round off the nuts, so I have not yet been able to inspect the bearing shells.
One cam follower has wear on the flat face but all the others appear fine.
The clutch looks great. The gearbox seems to be selecting all the ratios it came with. The drive shaft and UJ are all fine.
I have a lead on a left side cylinder, head and piston and should know by the end of the week if it is all available. I toyed with the idea of using twp-valve V65 bits. In some ways this may be a very good idea but I do like the idea of 4 valves per cylinder. I have never ridden a Lario and would like to try it. We shall see.
1975 850 T3
2019 V85TT
Re: Uh-Oh, Lario
« Reply #20 on: April 07, 2019, 11:58:55 PM »
if you ever come to melbourne welcome to have a go on mine
 but there are many things beyond the myths that need sorting, took me a while before I was happy to button it up and treat it as designer intended.
very surprising 3 tappets still good, basically the whole story is told there, cam, adjuster and valve tip damage all symptoms
both my engines had been welded up and “rebuilt”
both worse than factory original, pins pulled ready to pop
Either way you go check lh rod for straight, one of mine badly twisted ie big end not facing same direction as little end
Offline Frenchfrog
Re: Uh-Oh, Lario
« Reply #21 on: April 08, 2019, 02:35:56 AM »
The clutch arm was probably extended to make the pull lighter dave..hope you can sort the bike out easily.
Offline stubbie
Re: Uh-Oh, Lario
« Reply #22 on: April 08, 2019, 03:34:39 AM »
Is that what they call valve displacement? :thumb:
Re: Uh-Oh, Lario
« Reply #23 on: April 08, 2019, 03:01:02 PM »
Holy pistons Batman! :wink:  A bit of damage going on in there Dave. :shocked:
Offline stubbie
Re: Uh-Oh, Lario
« Reply #24 on: April 08, 2019, 07:34:51 PM »
Not sure if they are the same heads but Niks Euro Bits has left hand heads for a v65.
Re: Uh-Oh, Lario
« Reply #25 on: April 09, 2019, 10:53:35 AM »
Nope. 4V heads are beginning to be scarce on the ground.
Offline injundave
Re: Uh-Oh, Lario
« Reply #26 on: February 09, 2021, 08:46:46 PM »
It has been almost two years since I last posted here. In that time much has happened with the Lario. I finally got it to run late in 2019 after a major engine rebuild - valves, springs, collars, keepers big-end and main bearings, cam chain and tensioner etc.
It was fitted with a Newtronic electronic ignition system which seemed to work sometimes. I changed the coils, plugs and HT cables, cleaned the carbs numerous times but it never quite ran right. In the meantime I found an original bikini type fairing and a set of unobtanium front indicators so I had a bike that looked right but still did not run well. I tried to ride it to a friend's house about 50km from here. I got half way there when the gearbox siezed solid in third and I had to bring it home on a trailer. The second-hand gearbox I found was NOT cheap!
Late January this year I bought a DynaS ignition system. The advertising blurb says that all electronics are contained under the timing cover, in other words, no black boxes hidden up under the tank. The system consisted of the plate (which replaces the old points), a magnetic rotor , two coils and HT cables, plug caps etc, a short piece of red wire for the power feed to the system and a small bag of hardware (terminals etc).
I had to make some brackets to mount the coils but, that aside, fitting was extremely easy. The plate connects to the coils with only one wire to each, switched power goes to each coil and the previously mentioned piece of red wire is spliced into one of the power feeds to the coils and plugs into a third wire from the plate.
I set the timing at 7 degrees BTDC and pushed the start button. The engine started immediately and settled into an idle at 1000rpm. Throttle response is instantaneous and acceleration is much improved. Even in 4th gear acceleration is surprising.
Tomorrow morning I an taking the bike for a Warrant of Fitness, a mechanical check required by law every 6 months and I will then relicense it for a few months to really try it out. So here it is.
« Last Edit: February 09, 2021, 08:48:41 PM by injundave »
1975 850 T3
2019 V85TT
Offline SLDMRossi
Re: Uh-Oh, Lario
« Reply #27 on: February 09, 2021, 08:49:38 PM »
Offline lucian
Re: Uh-Oh, Lario
« Reply #28 on: February 09, 2021, 09:06:05 PM »
Love a happy ending!  Beautiful bike and must be a blast to ride, good luck with the check up. Do they have to put a finger up the tailpipe?
Offline Scout63
Re: Uh-Oh, Lario
« Reply #29 on: February 09, 2021, 09:56:38 PM »
Bravo InjunDave.  That bike will treat you well.
Ben Zehnder - Orleans, MA USA
