Author Topic: Fork oil for 45mm right side up forks  (Read 4257 times)
Offline Petrus Rocks
« on: March 18, 2019, 03:51:38 PM »
I just transplanted a set of 45mm MG adjustable forks onto my 85 Tonti frame.  I see 485cc per leg as a spec but no height measurement.  Also MG calls for 10wt oil.  Anyone use something different?
Online John A
Re: Fork oil for 45mm right side up forks
« Reply #1 on: March 18, 2019, 04:05:29 PM »
actually I like to use motor oil.  I learned from some racing types that forks cant read so they don't know if you don't put in high zoot fork oil or not.  Ive been using 15/50.
Online Perazzimx14
« Reply #2 on: March 18, 2019, 04:06:26 PM »
ATF also works a treat
Rough Edge racing
« Reply #3 on: March 18, 2019, 06:14:42 PM »
 Fairly big gap between 15/50 and ATF , usually described as a 7.5 weight oil....considering forks run much cooler than an engine or transmission...it's still a big difference...
Online Perazzimx14
« Reply #4 on: March 18, 2019, 06:37:13 PM »
15/50 might be a bit excessive or have all dampening and slooooooooooooooooo ooo rebound. I've run straight 30w oil in the forks of my Eldorado with success.
Offline Rick4003
« Reply #5 on: March 18, 2019, 10:25:01 PM »
I just looked into getting some new fork springs for mine and Wilbers recommend 7.5w oil with their fork springs.
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
Rough Edge racing
« Reply #6 on: March 19, 2019, 05:08:08 AM »
 Pete, since the forks assembly on the bike now is from a heavier machine than your "cafe" Tonti, perhaps a slightly lighter oil might be better to prevent harsh dampening...Maybe 5 weight fork oil instead of the slightly heavier ATF.. I'm assuming the 45 mm forks were not under dampened on the original bike...
  For those interested, the 45 mm later forks on the 80's Tonti frame bike look very nice, a more balanced look with the large Guzzi engine...The original 35 mm forks look like they belong on a 250cc bike in comparison... :grin:
« Reply #7 on: March 19, 2019, 08:10:47 AM »
Good point Tony.
image uploader
Here's a before and after.  Steering stem triples, and bearings all fit right on.  Using the old Borrani rims I will have to make a spacer to center the wheels.  A simple bracket will allow me to use the old calipers.  I have a set of four pot Brembos that will go well with larger discs.
« Reply #8 on: March 19, 2019, 08:17:30 AM »
Didn't realize that was a such a crappy picture...
