Author Topic: Battery Woes Not Charging  (Read 5541 times)
Offline davedel44
« on: March 23, 2019, 02:32:23 PM »
Replaced battery on 2013 V7 Stone last May.
Replaced it again yesterday, bad cell, battery replaced free.
Seems like this bike eats a battery each season.
Read thread about Voltage regulator overcharging so I ran tests.
Let new battery discharge to 12.26v.
Turned on key 12.25v.
Start  10.5v then 12.55v at idle.
12.76v at 2000rpm
12.78v at 4000rpm
Key off battery holding at 12.49v.
Shouldn't be jump up voltage to about 13+ to charge then level off?
Dave is often confused.
Galveston
« Last Edit: March 26, 2019, 09:53:03 AM by davedel44 »
Bambino- 2013 V7 Stone
Re: Battery Woes
« Reply #1 on: March 23, 2019, 03:30:06 PM »
12.76v at 2000rpm
12.78v at 4000rpm
IF, the battery at rest is 12.26V, it is discharged a good bit. You need to charge it, or let the motorcycle charge it, before the voltage rises to 14V+.
Offline pehayes
Re: Battery Woes
« Reply #2 on: March 23, 2019, 03:54:51 PM »
And what battery brand/model are you using?
Offline malik
Re: Battery Woes
« Reply #3 on: March 23, 2019, 04:20:40 PM »
My V7C recharges at 14.3V @ 3,000 rpm, and from memory the 2014 Special does the same.
Offline davedel44
Re: Battery Woes
« Reply #4 on: March 23, 2019, 05:27:10 PM »
I'll ride it tomorrow to charge it up.  I assumed that the voltage regulator would feed a low battery at 13+ volts to charge it up.
You could fill a book with what I dont know about mechanicing.
Guzzita down the street has offered to wire up a  voltmeter so I can keep an eye on things.
Offline davedel44
Re: Battery Woes
« Reply #5 on: March 23, 2019, 05:29:41 PM »
Some cheap replacement from Oh Oh Rielys.  Had to save some cash cause I got my eye on a used sump spacer. :smiley:
Dave
Offline davedel44
Re: Battery Woes
« Reply #6 on: March 23, 2019, 05:30:28 PM »
Re: Battery Woes
« Reply #7 on: March 23, 2019, 07:53:30 PM »
You need some revs to get full output.
An easy way to monitor is a simple gauge that plugs into your SAE battery lead.  Tape it to the tank (painters tape) and it's easy to monitor for as long as needed.  Battery Tender makes one-I use an Optimate product that's a bit more complex.  Both were very reasonable to purchase.
Offline pehayes
Re: Battery Woes
« Reply #8 on: March 23, 2019, 08:09:08 PM »
An easy way to monitor is a simple gauge that plugs into your SAE battery lead.  Tape it to the tank (painters tape) and it's easy to monitor for as long as needed.  Battery Tender makes one'
Like this.  Have one.  Works  treat!
Re: Battery Woes
« Reply #9 on: March 24, 2019, 09:58:17 AM »
If the battery is in good shape, just needing a charge, it can hold the alternator voltage low until it starts accumulating some charge.
Putting a voltmeter on and riding it is a great idea.
Offline davedel44
Re: Battery Woes Not Charging
« Reply #10 on: March 26, 2019, 10:33:53 AM »
Voltmeter ride results.  No reading over 12.2.
NEW QUESTION:  Any way to test voltage directly at stator?
Two yellow wires coming from two metal tabs.
Thanks,
Dave
Offline Old Jock
« Reply #11 on: March 26, 2019, 01:33:29 PM »
You can by measuring the voltage across the 2 yellow wires BUT what you will measure is AC volts and it will be high, probably 30 VAC + dependent on revs
I don't know what alternator or charging system is on the modern bikes.
Usually Alternators work or they don't and to test you would need the workshop manual to tell you what the voltages should be at various RPMs too check it
The easiest way is what Wayne is telling you, or get a good battery from somewhere, charge it fully off the bike measure the standing voltage and if it's good, then put it in the bike and measure the charging votage
There isn't a way, that I know of to measure if the charging voltage is good with a questionable battery in the circuit...........G o On ask me how I know  :rolleyes:
The usual other stuff applies, check all the earths at Reg/Rec and battery to frame are good, check the connection where the Reg/Rec measures the system voltage is good (although this would tend to overcharge that undercharge)
« Last Edit: March 27, 2019, 04:42:53 AM by Old Jock »
Offline davedel44
« Reply #12 on: March 27, 2019, 05:58:39 PM »
Got together with long time Guzzita Charlie Semore and checked continuity and voltage at stator, then continuity in wiring to battery.
Most likely culprit rectifier/voltage regulator.  Ordered today from Harpers.
Hope to be on road again next week.
Dave less confused in Galveston
« Last Edit: March 28, 2019, 06:39:33 AM by davedel44 »
Offline davedel44
Re: Battery Woes Not Charging.
« Reply #13 on: April 10, 2019, 05:14:09 PM »
IT'S ALIVE  :thumb:
Installed new regulator from Harpers.
Battery is now charging
Dave
Back on the road in Galveston
« Reply #14 on: April 10, 2019, 05:38:07 PM »
 Cool  :thumb:
Offline zebraranger
« Reply #15 on: April 10, 2019, 07:21:47 PM »
12.76v at 2000rpm
12.78v at 4000rpm
Both of my bikes at idle charges at 14.1 to 14.3 V, including the Griso. Your 12.5 at idle isn't right, and 12.7 @ 4000 RPM isn't either.
Offline Old Jock
« Reply #16 on: April 11, 2019, 01:32:49 PM »
I agree your voltages sound correct BUT when charging a discharged battery as Wayne pointed out earlier the battery can drag the system voltage way down which may look like a system problem but is simply a poor/discharged battery dragging down the voltage
The battery acts like a reservoir that is why when chasing charge issues the first thing to do is install a good fully charged battery before making any measurements
Offline acguzzi
« Reply #17 on: April 11, 2019, 01:53:24 PM »
As long as a battery is not overdischarged it should jump up over 13V in seconds. Agreed it may not get up to 14 but almost any charge current should get it over 13.
