Author Topic: 1997 1100i Sport Vin check?  (Read 2554 times)
Offline GuzziFuria
« on: April 08, 2019, 01:05:33 PM »
Ciao All,
Is there any way to check that the engine # matches the Vin # for this 1997 1100i Sport ??
Grazie
Carlo
Offline Lumpy Idle
Re: 1997 1100i Sport Vin check?
« Reply #1 on: April 08, 2019, 01:20:39 PM »
ohh, interesting. i am not concerned about mine but i would still like to know what the procedure amounts to.
'97 1100Sporti
'76 850T3
"You cannot successfully determine beforehand which side of the bread to butter."
--- Anonymous
« Reply #2 on: April 09, 2019, 09:07:43 AM »
Ciao All,
Grazie
Carlo
Look at the steering head and note the VIN.  Then look at the engine and note the numbers stamped on the side.
The last six numbers should match.
« Last Edit: April 09, 2019, 09:09:44 AM by rocker59 »
Offline GuzziFuria
« Reply #3 on: April 09, 2019, 06:45:28 PM »
Ooohh Thanks... This is very Important...  As they don't on the 1997 1100i Sport I'm looking at...  This can explain why the oil cooler is missing...
An engine swap...
Are you absolutely, 100% sure, that this should apply to the all 1100 Sport, especially to the 1997 1100i??  Not that I doubt your expertise, but for me this is a first Guzzi post 1980 and therefore my lack of knowledge...
Molto molto Grazie!!!  This is greatly appreciated!!!
Carlo
« Reply #4 on: April 09, 2019, 07:00:30 PM »
I do not think engine numbers always reflect the vin number.. don't know about your Sport but have seen Tonti frames with unmatched numbers.
Online Tom
« Reply #5 on: April 09, 2019, 07:13:21 PM »
As long as the frame no. matches the title, you're legal.  If the engine no. does not match the frame then the engine was changed out.
Offline GuzziFuria
« Reply #6 on: April 09, 2019, 08:22:21 PM »
If I am not mistaken, For the pre-1980 Guzzis, such as Loop, Tonti frames, in the US, engine # matches the frame #.  It was decided that the engine# should also be the frame#, and so an aluminum vin plate was riveted (stamped with same # as engine), on top of the "real" VIN# or frame # which was always different and stamped into the steel...  This can very well be seen in the US V7 Sports for example...
In Europe, they decided to keep the actual steel stamped Frame # as the VIN# and link it to the engine different #.
Therefor was wondering if it somehow still was the case, ie for this 1997 1100i Sport; last 6 VIN digit must match the 6 engine digits...
« Last Edit: April 09, 2019, 08:29:53 PM by GuzziFuria »
Offline GuzziFuria
« Reply #7 on: April 09, 2019, 08:27:53 PM »
It is exactly how you state it...
Also Engine looks newer, cleaner that the rest of the bike, that also caught my attention...
The oil cooler is missing, which I find very odd for a 1997 1100i Sport, since they all had it...
famous poems sun
« Reply #8 on: April 09, 2019, 08:43:23 PM »
Carlo,
I'm sorry.  I misspoke.  Engine number will not match.  I just checked my Sport 1100 to confirm.
I bought my Sport 1100 new, so I know it hasn't been mucked around with.
Offline GuzziFuria
« Reply #9 on: April 09, 2019, 09:13:46 PM »
Carlo,
No worries...  Good to know for sure...  Now still an incentive to buy again;)))
Still wonder why no oil cooler...
Offline Turin
« Reply #10 on: April 09, 2019, 09:45:46 PM »
There was a recall because of the oil cooler lines failing on some bikes. Perhaps it was bypassed?
1985 Sidlow Guzzi
Offline GuzziFuria
« Reply #11 on: April 09, 2019, 10:56:28 PM »
Woooo  that's super info...  Invaluable....  Many Thanks!!!
Online Perazzimx14
« Reply #12 on: April 10, 2019, 05:11:30 AM »
The mention of title is not a big deal either as long as the vehicle is 15 years old or older and the VIN comes back clean. For $48 + 6% on the NADA fair value VT will issue a valid registration that can be converted to a title buy states that issue titles.
From mailing in the 4 pieced of paper work to having a VT plate and registration in my hand as 14 days.
