1) make sure the tire is warm if you are in a cold climate2) make sure there are no casting nubs folded under at the tire rim interface (can cause leaks)3) If you cant get to initially seat, try a rope or strap around the circumference and tighten4) I have used tons of air to seat beads. Not recommended by the manufacturer, but I have gone up as high as 120 pounds. Wear ear protection in case it blows.
Or this:https://www.youtube.com/watch?v=KTaSvS0yNWI Patrick HayesI Have done many tractor and 18 wheeler tires! once we were doing a huge tractor tire. our bosses wife called the shop into eat lunch. someone forgot to remove the quick connect chuck! after 15 minutes the huge tractor tire exploded, part blew out a wall and the rim went thru the roof. someone got fired. im just glad no one got hurt maimed or killedFremont CA
Only thing I'd say is that I'm a bit surprised that some folks use "tire lube" that isn't really tire lube, is sub-optimal for the job, and/or can leave moisture behind that can corrode and oxidize.A lifetime supply of the right stuff (P80 or RuGlide) costs about the same as a bucket of chicken legs, works first time every time, and doesn't leave problems behind for the next guy .... ?Lannis
