What is your current blood pressure?
.....Having high BP sucks but not knowing you have it is much worse.
It's called the silent killer.
And there's the thing. I was only at the doctor initially as a good friend suggested that I should get a check up - as I rarely see the Doc Hence I'm interested in the symptoms as whether it was something I should have noticed
Well - I had to wear a blood pressure monitor for a day and low and behold I have high blood pressure and am immediately going on to the tabsIts always been at the top limit, but not being a smoker and a light drinker only not considered a big issue. Now at the age of 58 it appears it is!!As far as I was concerned I was fine - what are the obvious symptoms?????Any tips, thoughts for the other suffers on this forum?CheersTris
