Author Topic: Installation Prep for "Paper" Gaskets  (Read 7816 times)
Offline leafman60
« on: April 12, 2019, 07:33:00 AM »
I am curious about the opinions from our august body of experienced mechanics regarding preparation of "paper" type engine gaskets for installation.  We are talking about "paper" fiber type gaskets used for crankcase joining, cylinder base gaskets etc for engines like the venerable Guzzi motors. Cylinder head gaskets, molded polymer gaskets, o-rings or gaskets with factory deposited sealing beads are not included.
Do you install such gaskets dry?  Wipe them with motor oil?  Wipe them with grease?  Or, do you go beyond the cusp and spray or coat them with sure-nuff sealants like RTV, Hylomar, Hi Tack etc ????
Offline Groover
    • Scooteropolis
Re: Installation Prep for "Paper" Gaskets
« Reply #1 on: April 12, 2019, 07:51:46 AM »
I'm old school I guess, maybe it's not good, but I kind of wet them with motor oil or 2-stroke oil, I just put some oil on my fingers and go over them, not soaking them necessarily. That's for the flatter paper type used for intakes and cylinder bases and if all the surfaces are perfect. For the puffy newer green gasket types for say valve covers or older asbestos types used for exhausts and such I put them on dry. I'm blending experiences here, not all based on Moto Guzzi engines. I'm referencing two-stroke engines as well.
Edit: At times I've had some issues with sealing, especially intake leaks on two-strokes, and I've resorted to this product instead of using oil on the paper gasket and I and I highly recommend it. It will definitely make a good seal. https://www.napaonline.com/en/p/BK_7651210
Other times I've also had some issue with buggered up surfaces on crankcases, and in those cases I've resorted to the red gummy type sealants in conjunction to the regular gasket. That's sloppy and I don't like it, but it has solved problems in my past life (teenager)
« Last Edit: April 12, 2019, 08:03:19 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline larrys
« Reply #2 on: April 12, 2019, 08:15:56 AM »
I have had good luck with putting a real thin coat of Permatex black silicone on one part, then sticking the gasket to it. Then another real thin coat of the same stuff on the gasket.
YMMV.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline acogoff
« Reply #3 on: April 12, 2019, 08:17:03 AM »
    Grease of the type that just happens to be at arms length.  Slight film is all you need.
Marshall County Minnesota USA
Offline Don G
« Reply #4 on: April 12, 2019, 08:35:24 AM »
On pan and valve cover gaskets I use Never Seize on the side going to the case or head. DonG
Offline kballowe
  • - Kevin the Great -
« Reply #5 on: April 12, 2019, 09:34:24 AM »
^^^^    THIS    ^^^^
Offline cloudbase
« Reply #6 on: April 12, 2019, 11:40:54 AM »
I brush both sides with a thin film of anti-seize paste.
« Reply #7 on: April 12, 2019, 12:00:56 PM »
I had an old time Guzzi dealer tell me the way to prepare paper gaskets was to dampen them with water.  I don't remember his name but it was when we took a KC10 tanker to the Dayton air show in the mid '80s. I've not tried it yet but he made sense and it may be right. I generally use oil or grease.  I believe useing silicone gasket sealer is a maintenance error anyplace on a Guzzi. It's better used on implement gearboxes.
« Last Edit: April 12, 2019, 12:18:45 PM by John A »
Offline TOMB
« Reply #8 on: April 12, 2019, 12:08:33 PM »
Some of the paper gaskets like those in the rear diff cover need to be soaked in water to swell up so the cover can be installed with out tearing the dry gasket..
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #9 on: April 12, 2019, 12:12:22 PM »
Thin film of grease.
« Reply #10 on: April 12, 2019, 12:20:20 PM »
What I do or don't put on gaskets/gasket surfaces depends on where the gasket is located and the type of gasket. I can't think of any "paper" gaskets on early big block engines except perhaps the "distributor" on Tontis. The rest are a fiber of some sort or composite. Transmission and rear drive do have paper gaskets though.
Offline Toecutter
« Reply #11 on: April 12, 2019, 12:26:00 PM »
I LIGHTLY (like... the thinnest layer possible) grease one part surface of the two being joined, leaving the other dry. Place the gasket on the greased surface, then mate the parts.
I don't care if one side sticks... as long as the other doesn't. That's where tears happen.
« Reply #12 on: April 12, 2019, 05:19:06 PM »
TOMB
This. Another example is the endcase gasket for big block five speeds. I just drop them into warm water before installation and the small amount of expansionas the paper swells means the holes line up nicely.
With kingerlite type head and base gaskets I just install them dry.
