Author Topic: dual sport tires for 2.15x18 rims  (Read 2534 times)
Offline mtiberio
    • TiberioRacing
« on: April 15, 2019, 11:38:49 AM »
Living in the desert these days, and I ride a lot of graded dirt roads. Was wondering about folks choices for dual sport tires to fit an Eldorado. Really any experience with early big twin Guzzis using 2.15"x18" wheels would be appreciated.
Is there a reasonable source for the GoldenTyres that come on the v-7 stornello in this country? Anyone use Michelin Anakee Wilds?
Thanks,
Mike
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Perazzimx14
Re: dual sport tires for 2.15x18 rims
« Reply #1 on: April 15, 2019, 12:10:46 PM »
I'd slap a set of Shinko 244 in 3.00 x 18 and ride like the wind. At $33 per tire they are affordable and the wear decent well and have good road manners.
« Reply #2 on: April 15, 2019, 12:18:39 PM »
Did you mean 4.10-18? Even that size is rather narrow, 244s seem to "run small". I was running a 4.60-18 on the rear of my XT500.
With a recommendation from Nick Adams, I bought a set of 4.00-18 Duro HF308s for my V700 "Tutto Terreno" project. I wouldn't call them "60-40" tires, but they should do what I need them to.
« Last Edit: April 15, 2019, 12:20:02 PM by Antietam Classic Cycle »
Offline mtiberio
    • TiberioRacing
« Reply #3 on: April 15, 2019, 01:03:37 PM »
Charlie, was the 4.60 mounted on a 2.15" rim? Comparable to a 110? a 120? Was it oversized for said rim?
those Duro HF308s are rare  (but findable) in 18" sizes.
« Reply #4 on: April 15, 2019, 02:37:00 PM »
From memory,the Xt had a WM3 rear rim (2.5"), but it could have been WM2 (2.15") as that was 6+ years ago. The 4.60 was close but not quite the same width as a 120/90. Shinko recommends a 2.15" rim size:
https://www.shinkotireusa.com/product/244-series-tire/211927
I bought my HF308s on Amazon for $92.00/pr. including shipping. They've gone up in price a bit since then.
Offline Perazzimx14
« Reply #5 on: April 15, 2019, 02:44:09 PM »
The stock rear tire on a DR650 is a 120 it is very common to put on a 5.10 rear in place of a 4.60 (aka 120)
Offline Toecutter
« Reply #6 on: April 15, 2019, 02:57:28 PM »
Heidenau K60
Offline stubbie
« Reply #7 on: April 15, 2019, 07:36:09 PM »
I use Metzeler Tourance dual purpose on my ADV bike. Not sure if they do the size your after though.
Rough Edge racing
« Reply #8 on: April 16, 2019, 06:25:34 AM »
 I like the Shinko 705's as seen on one of my Triumphs several years ago...The rear is a 120/85-18 on a WM-3 rim...It fit nicely ...Obviously a vintage Triumph is a easier handling thing on unpaved roads than your Guzzi but take a look... The 705 Shinko's had excellent stick on pavement although a bit noisy...Not like I could hear them over the Triumph engine clatter ...........
Offline guzziownr
« Reply #9 on: April 16, 2019, 08:35:05 AM »
705s here as well.  Shinko calls it a 70/30.
