Mike, thanks for the extensive test ride report. You were in a great area to test the new bike!.....Having experienced a lot of bikes, how did you perceive the "feel" of the V85 motor compared to non-Guzzi V twins and parallel twins? Then how about to the other big block and small block Guzzi's you've ridden?
Did the big block 850 make as much power?
That said, the V85 TT boasts looks that the GS and KTM could only hope to achieve, capturing 80s retro charm, alongside superb build quality. Everywhere you look, the Guzzi feels like a quality product and there are no panel gaps or cheap plastics to contend with. What’s more the tubular steel frame and tubing that surrounds the clock housing make the bike feel rugged and capable and you can’t help but feel special when you ride it.
Mcn does not give Guzzi a fair shake. I’ve been a subscriber on and off again for over 20 years. They ripped almost every Guzzi they tried in that time. I’m not a Pollyanna, but neither am I a hack, unfortunately mcn has an axe to grind when it comes to Guzzi, which is weird because I’m certain an inordinate number of subscribers own Guzzi.
