Author Topic: Tell me about the SP 1000  (Read 6852 times)
Offline Gusable
« on: April 25, 2019, 08:40:27 PM »
Recent bike for sale here made me “ look “ at SP 1000 models. ( I’d like to buy that one but cannot at this time) anyway just a good ol tonti bike? Looks cool.  Saw one at the lindale rally years ago.  The red and white is super good looking.   The ergos can be cramped?  All SP have Nikisil cyl’s?  Thanks!
1994 California 1100
Offline Gliderjohn
Re: Tell me about the SP 1000
« Reply #1 on: April 25, 2019, 08:59:35 PM »
Limited experience here...I have a T-3 with the SP1000 upper fairing. I have had just a few miles on a stock SP1000. When my wife could still travel we did a lot of double up miles quite comfortable on a T-3 with luggage and all. The SP has a longer wheel base so there is more room than the T-3, but I found the bike to still be quite nimble. The SP fairing works very well and actually gave my T-3 about two mpg better than naked. And yes, the red and white is the best looking and fastest looking one. :wink: Not sure about the cylinders but others here will know.
East Mountains, NM
Offline Tusayan
« Reply #2 on: April 25, 2019, 09:08:34 PM »
I had a red/white SP for a few years in the 90s, with 36-mm carbs and upswept Bub pipes.  In that form it was basically a Le Mans with a big effective fairing.  Yes it's better suited for (I'd judge) riders of 5'10" tall or shorter.  For me, taller than ideal for the SP, my LeMans was more comfortable so eventually I sold the SP.  I did ride it well into Canada and Mexico as well as the US and enjoyed it.
IIRC the round barrel SPs were the last iron barreled bikes.
« Reply #3 on: April 25, 2019, 09:56:19 PM »
The 1000SP would have iron liners up to ~ '81, and then Nigusil after that.
Offline Gusable
« Reply #4 on: April 25, 2019, 10:15:35 PM »
The iron liners are reliable? Not the flaky chrome?  I only have experience with the Nikisil cylinders ( I’m getting my EV back in cpl of weeks!!
« Reply #5 on: April 25, 2019, 10:43:19 PM »
The iron liners were/are very durable. None of the 949 cc engine ever had chrome bores.
Offline Perazzimx14
« Reply #6 on: April 26, 2019, 04:45:40 AM »
If its my 1980 SP100 in Blue you are looking at judging by the almost zero interest its generating I'll still probably have it when you ready to buy :wink:
Offline Roy gardner
« Reply #7 on: April 26, 2019, 04:56:18 AM »
I run a Convert with a Spada handlebar faring, no leg shields or knee pads. Its the padding on the rocker covers that us tall, 6'1, guys find a drag. I have also binned the Convert boards & fitted pegs lower & further forward than a Spada set up. The early SPs used LM foot peg hangers, later types, sometimes labelled SP NT, used what look like T3 foot peg hangers because they put the riders pegs a bit further forward & the pillion pegs a bit lower. You will see a difference in muffler upsweep if you compare pics of both. I have also fitted pullbacks & bars from a Royal Enfield with more downturn at the ends for my comfort. My hands are still comfortably in the fairing.
SP & Convert use the same round motor with iron liners, they do big miles. Wheel base of round barrel Spadas is the same as round barrel LM, same frame, forks & cast wheels.
MGNOC L112
1973  850 GT (sold 1979)
1974  160 Stornello (bought new 1978)
1972 V7 Sport, (bought 1979, still running strong)
1977 Convert (bought 2009)
1974  850T (ComposT, pawned to buy Vincent parts!
1985? LM 1000 (saved from a savage, has become hotrod Convert)
Offline larrys
« Reply #8 on: April 26, 2019, 08:05:02 AM »
I bought a red and white one new in '83, sold it with 60K miles in '02. It had one of the soft clutch hubs that I addressed when it had about 30K miles on it. Well, the engine's out, tranny off, let's have the flywheel lightened. Gee, the cam chain is worn, let's put in some Agostini gears. Well, we're in that deep, we'll put in a Manfred Hecht cam. If we're putting in a hotter cam, we'll pull the heads, refresh the valves and put in some heavier valve springs. Add some Bub mufflers, K+N's and rejet the carbs. When I was done with all that I had a machine with a vastly different personality from before. It was no longer comfortable at legal speeds. Flying down the highway at 80+ was much more fun. All in all, it was a good sport touring bike for it's era. Would I consider another? Nope. YMMV.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
« Reply #9 on: April 26, 2019, 08:31:59 PM »
It was/is a *great* sport touring bike.. if you are Italian sized. I am. The fairing is one of the best ever. The earlier ones have more of a LeMans riding position. Solid bike.
Offline Gusable
« Reply #10 on: April 26, 2019, 10:48:50 PM »
They are for sure good looking.
Offline guzzista
« Reply #11 on: April 26, 2019, 11:16:40 PM »
My 1983 SP is a bit of a unicorn. White and Red. Most of the NT models here in the US were Red and White. The White and Red was known in Italy (unofficially) as the Marlboro version. The bike had been dead in the water since  1987, when a jump start with the key on caused  the Dyna ignition to go on  permanent misfire.  An old friend had purchased and stored thinking he would get it running right when he retired. Unfortunately he passed away and never got to it. I acquired it from his widow and have been at it for the past couple years. Lemans 1 footpegs setup,  B10 cam, chain and  tensioner, tires, brake hoses ,suspension, lots of other miscellany, and last; Hi Comp pistons, Ported LM heads and PHM 40's. As Chuck mentioned , being Italian sized helps being comfortable on the SP. No regrets so far, just looking forward to  do some long distance travel on it.
« Last Edit: April 26, 2019, 11:18:45 PM by guzzista »
Offline stratoguzzi
« Reply #12 on: April 27, 2019, 09:58:46 AM »
<br /
They were always my favorite.This one is a SPNT even tho it is painted in a earlier paint pattern.Last of the round fins.Nobody wants to buy it so it sits in my living room as "art".
2007 CalVin
1984 SPNT
Online Tkelly
« Reply #13 on: April 27, 2019, 11:48:20 AM »
Was my favorite long trip bike.Light compared with my current Stelvio, great gas mileage andhandling and plent of power.I'm 6'2 and had no problems .
« Reply #14 on: April 28, 2019, 04:11:34 PM »
I have an '80 ice blue model.  Pretty much stock.  K&N's and Dyna ignition.  Super dependable and a mile killer for touring.  If you're 6' or taller, it would be cramped.  The fairing is pretty much the best that I've ridden behind for mileage and weather protection.  It's my bike for summer solo touring on the U.S. mainland.  Not sure if I'll sell it.  I have a 1400 Cal Touring to replace it but still not sure about selling it.  I could use it in Hawaii since I ride solo most of the time.
Offline Gusable
« Reply #15 on: April 28, 2019, 06:16:08 PM »
I sho’ nuff like the pics!
« Reply #16 on: April 28, 2019, 08:28:29 PM »
:smiley:
Offline guzzista
« Reply #17 on: April 28, 2019, 10:43:48 PM »
I hear you Chuck. Fitting a SP fairing on my Cali 1100 just about now
« Last Edit: April 28, 2019, 10:47:59 PM by guzzista »
