Yep.
Ok, thanks for the kill switch tip. I have 5v "feed" on the yellow wire, on the black it seems to be working as described. At idle it's about .2 v and steadily goes up to 5v as I roll the throttle. Not saying it's still not faulty but that's what I am getting.
No, it has never been mapped, no power commander. It started out of the blue a while back, just getting around to messing with it. Where can you get the TSP? Someone told me you had to get them from Guzzi, I read somewhere else there was also a cross number off a Harley?
Take the oem tps off, pop the cover off and inspect the inside. My be dirty. Most likely has a bad contact finger or bent. Easy to replace the tps. 470-500 mv @ idle.
Another test is if there is a dead spot on the throttle. Then the TPS is bad.OR, someone put a really bogus map in your ECU. Has anyone remapped the ECU or installed a power commander type device?
I've used the Harley one.. but the bike kept trying to turn into a bar every time I passed one.. other than that, it worked fine.
I've used the Harley one.. but the bike kept trying to turn into a bar every time I passed one.. other than that, it worked fine.The "correct" one is available for around $90 I think, but don't remember where. <shrug>
I finally got around to ordering and installing a new TPS...(I have a lot of projects). Just wanted to confirm that it was the TPS, I installed it and it works great, no more dead spot, idles fine etc. However, I went through no procedure to set it up. If it runs fine, is there any reason to?Thanks
Just be glad a bunch of tattooed floozys didn’t attempt to climb on the back😂
It you don't set the TPS, you usually are too rich or lean. You will carbon up the plugs pretty quick, or be unhappy with the idle.If you adjusted it for a nice idle speed, you may be close enough. Hard to imagine that you just screwed it on, and it was good enough. It is a pretty touchy setting.
You may be running rich or lean the mV at any throttle position determines how much fuel is added among other things,Setting the TPS is normally done with the throttle plate fully closed, not held off by the idle stop or throttle linkage.With it fully closed set the mV to 150, this is the reference point, it never runs in this position because as soon as you set the idle speed with the idle stop screw the TPS is much higher about 450 from memory.Why fully closed @ 150, this value ensures that the TPS is not banged up against the end of its travel, it's a fixed reference point that never moves.Some procedures tell you to now adjust the idle screw to give you a certain mV, in reality you are adjusting the idle stop to 1100 RPM the new mV value 450+/- is what it is.Now all you need to do is balance the throttle bodies to make sure both cylinders are sharing the load somewhat equally
I always thought that made sense.. Everything I read when I did mine said to set the idle with a VOM, and I always fought too high idle RPM... It made sense to set it to RPM as long as the baseline setting was right, but I was fighting so many engine control issues I didnt want to start causing more issues. I already had so many red Herrings to chase after.
