Author Topic: Headlight  (Read 1399 times)
Offline bete
Headlight
« on: April 28, 2019, 09:25:55 PM »
So I just bought a 03 stone  :thumb:  the headlight is frosted over badly,  is there a led replacement lens that will fit the stock bucket ?
Offline larrys
Re: Headlight
« Reply #1 on: April 29, 2019, 07:21:45 AM »
My Cal 1100 had that issue. I bent up a piece of heavy coathanger wire, taped some cotton cloth to it dampened with some alcohol, and cleaned the inside of the lens through the headlight bulb hole. Was a bit tricky, but cleaned up nicely.
Necessity is the mother of invention!
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline tris
Re: Headlight
« Reply #2 on: April 29, 2019, 08:31:37 AM »
Not an LED but the Wipac Quadoptic Light unit fits straight in - should be a S6011 for a right hand dip (right side driving)
It transformed the light on my old Cali to a proper "see where you're going light"!
It doesnt look "period" but if you're thinking of LEDs I guess that wont worry you too much
Tris
1993 TW125 "POS" - Resting
Offline bete
Re: Headlight
« Reply #3 on: April 29, 2019, 09:49:43 AM »
Great,  I will try to clean it, if that doesn't work I will go with option 2.  Thanks guys.
Offline BrotherJim
Re: Headlight
« Reply #4 on: April 30, 2019, 12:40:15 PM »
It isn't difficult to separate the reflector from the lense.  Remove the metal clips between the chrome trim ring and reflector with a pair of pliers, noting how they fit in there and the position of the lense.  Once you've done that, separate the parts and clean away!  Replace in reverse order.
Short Time Livin'...
'02 Moto Guzzi California Stone
Re: Headlight
« Reply #5 on: April 30, 2019, 03:58:21 PM »
Go through the back hole.  Clean it off from the using chopsticks or forceps or long needle nose pliers and rubbing alcohol.  The heat from the bulb and it's reaction to ozone creates the haze.
