Author Topic: V7ii headgasket  (Read 2805 times)
Offline Beowulf
V7ii headgasket
« on: April 30, 2019, 02:14:54 PM »
Ok. So my bike is out of warranty for some time now. I developed a leak believe it or not on both headgaskets that i attribute to my poor now closed dealer experience. I tried retorquing with the values on this site that were provided. Still leaks. Carefully checked fill levels.
Im a cheapskate.....so i plan i doing this myself. Nearest dealer is in Austin. I bought headgaskets from mg cycle. Advice? Things to watch out for? Any specialty tools? Thinner socket for back engine bolt?
Thanks in advance.  I read everything i can dig on here before posting. So if i missed something please bring it to my attention.
Im thinking this looks pretty simple.
« Last Edit: April 30, 2019, 02:15:54 PM by Beowulf »
Offline malik
Re: V7ii headgasket
« Reply #1 on: April 30, 2019, 04:07:56 PM »
Cheapskate! What cheapskate? You paid good money for those fancy gaskets, didn't you? You didn't cut up some secondhand blotting paper (remember that stuff), did you. It's not as if it's an MZ. You're good to go.
You have found Pete Roper's post on re torquing the heads? Yes? I don't know about the II, but some V7s have  an o-ring on one of the rear studs - watch for it & if there, remember which stud it goes back on, take a photo or 3.
Offline Vagrant
Re: V7ii headgasket
« Reply #2 on: April 30, 2019, 04:32:33 PM »
Take your time then do again at 600 miles. U can bet the dealer didn't.
Offline sign216
Re: V7ii headgasket
« Reply #3 on: April 30, 2019, 05:12:48 PM »
I wrote this tutorial on torquing the headgaskets on the early V7 bikes.  It might have a good tip or two.
Joe
P.S. And at least one of the photos has some artistic merit.
https://www.flickr.com/photos/sign216/albums/72157627672086548
« Last Edit: April 30, 2019, 05:13:44 PM by sign216 »
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline Beowulf
Re: V7ii headgasket
« Reply #4 on: April 30, 2019, 05:23:08 PM »
Thank you that's handy on the photos. I will keep you posted. I didn't see anything about an o ring on the v7ii but its possible i missed it.
Re: V7ii headgasket
« Reply #5 on: May 01, 2019, 01:00:16 AM »
O-ring is between barrel and block I think?
Offline malik
Re: V7ii headgasket
« Reply #6 on: May 01, 2019, 02:22:21 AM »
Knew there was one somewhere there.
Re: V7ii headgasket
« Reply #7 on: May 01, 2019, 04:50:48 AM »
Me too! :grin:
Offline Beowulf
Re: V7ii headgasket
« Reply #8 on: May 01, 2019, 05:38:51 AM »
Well i looked again and the darn thing is there, its just really small on the parts catalogue. GU61027200 if anyone is interested. Thanks glad you brought it up.
Offline sign216
Re: V7ii headgasket
« Reply #9 on: May 01, 2019, 05:59:06 AM »
I recall Richardson in Guzziology said smallblocks were prone to leaking at this joint, i.e. between the cyl and the block.  I'm talking about the base gasket.  He recommended a specific gasket sealer as the best one for this problem; Permatex Super 300.  I've used it for this, and it worked for me.
Richardson said: during manufacturing a drilled stud hole can break into an oil passage, causing base gasket leaks. The fix is to clean the hole, seal stud with Loctite, and reassemble w Permatex Super 300 on the gasket. I refer you to Guzziology for photos and details.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline Beowulf
Re: V7ii headgasket
« Reply #10 on: May 01, 2019, 01:21:43 PM »
Dave of Galveston Guzzi fame has kindly lent me his Guzziology book. I will be reading that section tonight.
Offline Beowulf
Re: V7ii headgasket
« Reply #11 on: May 01, 2019, 07:19:31 PM »
As far as the orings go,  can i source a local equivalent or should i buy the ones blessed by guzzi for some reason?
Offline davedel44
Re: V7ii headgasket
« Reply #12 on: May 02, 2019, 05:51:53 AM »
Be out of pocket for a while LA State Rally then Cedarvale, but happy to assist when I get back.  If you run into problems while I'm rallying, feel free to call because I'll be hanging out with a bunch of guizziti that have a lot more wrenching experience than me.  Then of course there is always Charlie Semore just down the block he'd be glad to help as always.
You're becoming quite the Guzzi mechanic so I'm sure you'll have no problems.
Like I told you when we first met, Guzziti help Guzziti, this forum is a prime example.
Good Luck,
Dave
Island famous :rolleyes:
Somewhere off the coast of Texas.
« Last Edit: May 02, 2019, 05:53:41 AM by davedel44 »
Bambino- 2013 V7 Stone
Offline Beowulf
Re: V7ii headgasket
« Reply #13 on: May 02, 2019, 01:21:55 PM »
Well i appreciate the help.  The tutorial was very handy.  Half way done. I will get the other side tonight.
warhammer 40000 simulator
Offline sign216
Re: V7ii headgasket
« Reply #14 on: May 02, 2019, 07:20:38 PM »
Glad the tutorial was of some help.  Let us know how everything works out.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline Beowulf
Re: V7ii headgasket
« Reply #15 on: May 03, 2019, 05:54:04 AM »
Alright i left the base gaskets alone. It leaked from the base a bit when i took off the heads. I used permatex on the headgaskets both sides. Learned permatex 300 and aviation permatex are the same thing. (Im a novice)
I torqued both sides according to the numbers provided. So hopefully that will do it. Crossing my fingers the base gaskets wont leak. Was a bit of mess but cleaned it up and adjusted the valves.
Loved the tool provided davedel44 for valve adjustment.
Right now im cleaning my headers from rust. That beautiful salt air.
Offline Vagrant
Re: V7ii headgasket
« Reply #16 on: May 03, 2019, 06:17:13 AM »
just think of how much fun you would be having doing this job had it been any other brand.
Offline Kev m
Re: V7ii headgasket
« Reply #17 on: May 03, 2019, 06:38:41 AM »
eeeeeeehhhhhhhhhhhh h?!?
Good Luck?
Offline Beowulf
Re: V7ii headgasket
« Reply #18 on: May 04, 2019, 03:49:56 PM »
The bike is all back together. My exhaust gaskets had disintegrated. Replaced those. Tightened everything up. So far so good no leaks.
