Author Topic: 96 Cali 1100i speedometer bulb?  (Read 147 times)
Online flower_king001
  • Guzzi Hero
« on: May 05, 2019, 06:03:39 PM »
Hi,
 Trying to replace the blown speedometer bulb on a 96 Cali 1100i. There is a allen bolt on the back side of the chrome cover that I assume comes out and the cover slides off? Problem is the screw just keep rotating.
How does one remove the speedo/tach from the instrument housing?
Suggestions or tips  most appreciated...
« Last Edit: May 06, 2019, 03:34:01 AM by flower_king001 »
1971 BMW R90/5
1986 Moto Guzzi Lemans IV
1996 Cali i 1100
1998 Moto Guzzi EV
2007 Moto Guzzi Breva 1100
  • Guzzi Hero
Re: 96 Cali 1100i speedometer bulb?
« Reply #1 on: May 06, 2019, 03:41:35 AM »
All I could find is how to replace bulbs in the housing but not how to remove the actual speedo or tach housing.
Help?
thanks
1971 BMW R90/5
1996 Cali i 1100
1998 Moto Guzzi EV
  • Guzzi Hero
« Reply #2 on: May 06, 2019, 08:07:24 AM »
It's been over 15yrs since I messed w/those dashes. If I remember correctly, you have to take apart the square dash and it's bolted to it's mount.
Online Tom H
  • Guzzi Hero
« Reply #3 on: May 06, 2019, 11:44:31 AM »
If your 1100I is like my 2004 EVT, the speedo has a "cup" with 2 allen screws to hold the cup on. If so...
The screw goes into a nut that is rubber mounted to the speedo. If the rubber has failed, the screw just turns.
To remove the cup, you need a very small 6mm?? wrench to hold the nut on the back. I use what I think are called ignition wrenches. You reach in through the speedo cable opening and hold the nut.
Even with good rubber, I still use a wrench to hold the nut when I need to take the cover off.
If you need a pic, I can take a few latter today.
20 Ounce Stainless Steel Double Insulated Tumbler with donation credit
