Author Topic: V7 cam  (Read 13737 times)
Offline Yodastien
V7 cam
« on: May 06, 2019, 12:03:46 PM »
Does any one know if there is a cam I can get for my V7 racer?  I would like a little bit more power
Offline Frenchfrog
Re: V7 cam
« Reply #1 on: May 06, 2019, 04:57:01 PM »
This place  lists two different high lift cams for small blocks.They have different valve timing too probably. One is from Scola who did a lot of tuning work on racing big blocks
Offline Yodastien
Re: V7 cam
« Reply #2 on: May 06, 2019, 08:41:52 PM »
Wich Place?
Offline Frenchfrog
Re: V7 cam
« Reply #3 on: May 07, 2019, 02:10:28 AM »
Re: V7 cam
« Reply #4 on: May 07, 2019, 02:15:36 AM »
Getting more anything from a Herron head smallblock is like getting blood from a stone and an excercise in futility.
Offline tomasland
Re: V7 cam
« Reply #5 on: May 07, 2019, 03:47:06 AM »
Hi there. Can you tell approximately how much power the new block can give us? I just wont to understand whether this is necessary or not. Thanks.
Re: V7 cam
« Reply #6 on: May 07, 2019, 06:58:05 AM »
Tomas - just out of curiosity, what year (model) racer? If it's a Heron head the conventional wisdom is that with the amount of money you might spend on say a second bike (like a used Ducati) you still won't be as fast as said second bike.
NOW I also get the impression that the Hemi heads breath better and there might be more of a benefit to trying this on a V7III.
Of course if you HAVE a I or II and then BOUGHT a III you would instantly gain about 25% more power. Just saying.
Re: V7 cam
« Reply #7 on: May 07, 2019, 09:32:09 AM »
 No snark intended , seeking any significant power increase from a Heron head Small Block is an exercise in futility . Don't believe the dyno charts from anyone trying to sell you aftermarket performance parts for a Heron Head Guzzi , nothing but snake oil . Some years ago the shop that looks after Billy Joel's Guzzis performed thousands of dollars in engine mods , skimmed the head , different cam , exhaust , etc . Seem to remember they picked up maybe 2 HP at near redline  :shocked: :laugh:
Offline Yodastien
Re: V7 cam
« Reply #8 on: May 07, 2019, 01:06:06 PM »
I am looking at the 4v conversion but i have considered ordering the new v3 cylinders and heads and some big bore pistons
Re: V7 cam
« Reply #9 on: May 07, 2019, 01:27:26 PM »
 You can't bore Nikasil cylinders . Seriously , just wait for the V85 engine in a roadster .
Re: V7 cam
« Reply #10 on: May 07, 2019, 01:39:56 PM »
I don't think it would be that simple...
Re: V7 cam
« Reply #11 on: May 07, 2019, 02:14:36 PM »
 It isn't , except for someone like Pate , or Steve , or Martin . Those guys can do all kinds of amazing stuff us mere mortals are incapable of  :shocked:
Offline Frenchfrog
Re: V7 cam
« Reply #12 on: May 07, 2019, 02:50:18 PM »
I'm going to have to take down a 650 lump sooner or later and suspect that the piston to head clearance could be tightened up a bit.The inlet and outlet ports could probably be cleaned up a touch too. There won't be much at all in hp gains but I'm convinced that blueprinting engines is a good thing and seeing how far out my big block components was surprising.Putting in a cam with higher lift would liven things up a bit as the standard small block ones are as much lawnmower as it's bigger brothers.
Offline Kristian
Re: V7 cam
« Reply #13 on: May 07, 2019, 04:02:35 PM »
After loads of cash, time, and frustration, you'll end up with a . . still very slow bike.
Re: V7 cam
« Reply #14 on: May 07, 2019, 05:50:15 PM »
I believe there is a major difference between the smallblock and big blocks in terms of head design and the is the limiting factor. The heron head.
That is why I wonder if there is more to be found messing with the new V7III and its Hemi head.
Offline Frenchfrog
Re: V7 cam
« Reply #15 on: May 08, 2019, 02:23:33 PM »
It's for a 650 NTX Kristian....enduro bike  with the gear set from the 500's  so not chaseing after more kph, just want to perk it up a bit more. Probably won't bother with the cam but the rest costs hardly anything other than time and will improve performance for sure .
As for going for the v7 111 lump kev it's more a matter of finding one.If one is available for a good price then sure, why not !
Offline jacksonracingcomau
Re: V7 cam
« Reply #16 on: May 08, 2019, 07:00:34 PM »
of course it is about what you can find, we are Guzzisti !
Lario top ends if you can find, even with std cam & carbs absolute chalk and cheese v heron heads still superb fuel economy
v9 wreck or leftover another good start
esp. cos of rear drive getting rid of coupler
I have to have one of them for my hot lario, can’t see coupler lasting long with any serious power through it
Offline sign216
Re: V7 cam
« Reply #17 on: May 08, 2019, 08:18:43 PM »
I am thumbs up on the Heron heads.  The stuff of vintage fighter airplanes and race cars.
Good for Guzzi for sticking w them.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline SmithSwede
  • I don't want a pickle
Re: V7 cam
« Reply #18 on: May 08, 2019, 09:21:23 PM »
I too like the Heron heads.   Just cool, weird, old stuff.
And to the OP.   No disrespect.  But there is really no earthly reason to try to hot rod a small block.   The stock motor is very tractable, reliable, durable, and enjoyable.   I think it’s a peach.  Enjoy it for what it is.
It will cruise at 85+ mph all day.   Will out accelerate virtually all cars.
If you really want another 3, 5, 7 horsepower, get a more powerful bike.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline huub
Re: V7 cam
« Reply #19 on: May 09, 2019, 12:14:13 AM »
a good blueprint , raised compression,  pipe and bigger carbs make a huge difference to a V65,
i used to run a V65TT with these mods.
right now i would love a hot camshaft for my lario, but it is not worth the 500 euro guzziepiu is asking for theirs..
Offline sign216
Re: V7 cam
« Reply #20 on: May 09, 2019, 08:31:11 AM »
I reference the book Racing Engine Preparation by Clive Trickey.  Pages 22 - 24 where he recommends the Heron head and points to their successful use by the Ford and Cosworth racing engines.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline Furbo
Re: V7 cam
« Reply #21 on: May 10, 2019, 04:30:31 PM »
Try This:
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline Furbo
Re: V7 cam
« Reply #22 on: May 10, 2019, 04:34:33 PM »
Have a Domi myself. Brought it over from Italy last year...rode it to work today. There's ALOT of aftermarket for the engine as it's the same as the US spec XR650L.
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline F-22
Re: V7 cam
« Reply #23 on: May 26, 2019, 01:13:26 PM »
Meanwhile, I think the heron head Moto Morini 350 may have been the most powerful 350cc in the 70's, possibly even in the 80's (supposedly a bit over 40hp on the sport). I own a standard GT model, and there's definitely a big difference between it and a V35 Guzzi. Also got a Kanguro (enduro) model overbored to 400cc (but kept it at low compression), and I swear it seems to accelerate a lot better than my 750 Breva. Probably has a lot to do with the flywheel weight too... But if you go into theory, with two valves per cylinder, a Heron head has some advantages too (more squish, better burn, higher intake speeds...). My friend also raced with a 350 Morini, overbored to 500cc, with milled Yamaha R1 pistons inside, and that thing is just amazing for a 500cc two cylinder bike...
But of course, here's a stock morini piston:
And here is what a V7 uses:
I doubt a Guzzi is anywhere near as tuned as it could be, and there aren't many people who'd make decent performance parts for a heron setup.
« Last Edit: May 26, 2019, 01:17:38 PM by F-22 »
Offline sign216
Re: V7 cam
« Reply #24 on: May 26, 2019, 04:45:27 PM »
F-22,
Here's a picture of the V7 big bore (820cc)  piston from R.A.M. of Italy.  The valve cutouts here, and on the orig V7 are smoother and less abrupt than the Morini.  I think it's better, although I admire Morini's output and performance.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Offline SmithSwede
Re: V7 cam
« Reply #25 on: May 26, 2019, 06:34:35 PM »
Always wanted a Moto Morini 3 1/2.   Seemed like an Italian version of a Yamaha RD-350, except 4 stroke. And a bit more civilized.  Maybe one day.
Offline Penderic
Re: V7 cam
« Reply #26 on: May 26, 2019, 07:14:43 PM »
Why fret about small horsepower gains?
But you got some room to add a lot more foot/pounds ...
  :grin: of torque.
Offline F-22
Re: V7 cam
« Reply #27 on: May 28, 2019, 02:04:55 AM »
F-22,
Joe
I just think a 750cc Guzzi with a Heron head could still easily do ~70hp, if a much smaller bike managed to make over 100hp/litre. Not sure what the big difference would be. I also heard the Morini engineers spent a lot of time on getting the ports just right. I don't think Guzzi ever really wanted to pull more performance out of those engines (except for the new V85TT, that one seems decent, although it has the new heads), and even the hemi head V7's aren't exactly high performance... They might have only went that way to make the engines more conventional, since noone uses heron design anymore.
« Last Edit: May 28, 2019, 02:05:27 AM by F-22 »
Re: V7 cam
« Reply #28 on: May 28, 2019, 10:54:03 AM »
Not high performance but still the V7III makes about 20% more rwhp than the V7C and complies with stricter emissions standards. That's not insignificant.
Offline sign216
Re: V7 cam
« Reply #29 on: May 28, 2019, 04:12:47 PM »
Heron, all the way.  It accentuates low-mid range torque, best for real world riding.  As opposed to magazine/race track tests that are all about high rpm performance.
Do you want to live in the real world, or live just to satisfy some red-line cowboys.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
