Author Topic: V7 III break in service  (Read 2955 times)
Offline Thirtyaughtsix
« on: May 07, 2019, 09:52:36 AM »
I have the service manual in front of me and plan on going by that and doing everything myself. However, are there any tips, tricks, things I should watch out for or do additionally?
2019 V7 III Stone " Murci "
1975 850T " Guzziaughtsix "
Offline Siamese
Re: V7 III break in service
« Reply #1 on: May 07, 2019, 03:05:01 PM »
I just got done with my first service.  No surprises.  One of the reasons I got they v7iii is the access to the valves for adjustment.  They were a snap.  Of course, you'll need to get the rear wheel off the pavement to be able to turn it to rotate the engine.  As long as you have a way to lift, I don't think you'll encounter any difficulties.
Online sign216
« Reply #2 on: May 07, 2019, 03:40:07 PM »
I wrote a couple of tutorials for the first series of V7.  They might have a tip or two.
Joe
https://www.flickr.com/photos/sign216/albums/72157627672086548
https://www.flickr.com/photos/sign216/albums/72157626993357143
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #3 on: May 07, 2019, 05:51:33 PM »
Joe
As these things slowly change that's getting less and less relevant.
Offline usedtobefast
« Reply #4 on: May 07, 2019, 06:33:47 PM »
Oh boy, let's see
... the valve clearances are different in the 2-3 places they appear (manual, vs. sticker under seat, vs. service manual maybe) ... I went with intake of 0.10mm and exhaust at 0.15mm (they are also listed at .15mm intake and .20mm exhaust in some places).
... oil quantities are off a bit ... I ended up at 1.8 in the engine (vs. stated 2 I believe) ... 450cc in the place where the gears slide around (vs 500cc)
... no need to re-torque the V7 iii heads, that is a ii and older thing
... if you really don't want to lift the rear end off the ground, you can roll it forward in gear to get to TDC.  A bit awkward, but if you don't have a stand you might try the odd awkward approach.   :grin:
Overall very easy to do.
I also bought the "kits" at AF1 ... they come with OEM filter, o-rings, washers, and factory recommended oil brand and weight.  (They are in Austin, TX)
« Last Edit: May 08, 2019, 06:47:16 PM by usedtobefast »
2017 V7 iii Racer
2017 Griso
2016 Stornello
2000 Red Quota
Offline egschade
« Reply #5 on: May 08, 2019, 06:15:05 AM »
Oh boy, let's see
... if you really don't want to lift the rear end off the group, you can roll it forward in gear to get to TDC.  A bit awkward, but if you don't have a stand you might try the odd awkward approach.   :grin:
+1 as this mirrors my experience. It's very straightforward.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
« Reply #6 on: May 08, 2019, 01:49:37 PM »
Oh boy, let's see
No re-torque huh? I didn't see that coming. Cadre sells kits too, I got the same exact thing but with the addition of a bottle of solvent. I didn't ask but does this have a specific purpose or is it a just in case thing? I feel like I'm overthinking it
« Reply #7 on: May 08, 2019, 02:38:23 PM »
Retorqing ended with the introduction of the Hemi heads (and corresponding new gasket materials). That's been news since the intro of the V9, what was that 2016 or 2017?
« Reply #8 on: May 09, 2019, 12:06:13 AM »
Hell I have no idea, I really didn't start following the newer stuff religiously until about a year ago when I knew I could afford one. I wouldn't have been reading too deeply in 16-17
« Reply #9 on: May 09, 2019, 08:24:07 PM »
But not need to re-torque is a good thing.
I actually never could grasp the idea of the re-torque anyway.  I mean if a bolt is supposed to be xxNm , why not put the torque wrench on it, set to xxNm, and see if it clicks or needs a bit of a turn.  Never understood the loosen and re-tighten thing.
2017 V7 iii Racer
2017 Griso
2016 Stornello
2000 Red Quota
« Reply #10 on: May 09, 2019, 09:09:39 PM »
Certain gasket materials would further compress after some heat cycles. Resetting head torque under those conditions would help ensure the clamp load on those gaskets and prevent future leaks.
Or stated another way, if the gaskets compressed more under heat expansion then when the motor cooled the heads would no longer be able to snug and bolt torque would be loose compared to spec.
« Last Edit: May 09, 2019, 09:11:28 PM by Kev m »
