Author Topic: Dan Brown vs Wixom bags  (Read 7322 times)
Re: Dan Brown vs Wixom bags
« Reply #30 on: May 15, 2019, 10:04:19 PM »
Got my Pelican cases mostly mounted up this evening.
Offline T4halo
« Reply #31 on: May 16, 2019, 06:12:08 AM »
I like those. Very strong and water tight. Everything I deployed with was carried in Pelican cases.
T4
7th & 10th SF retired
Offline bigbikerrick
« Reply #32 on: June 05, 2019, 11:18:36 AM »
Looks good Charlie! Nice ,clean mounts you made. Do you have a bottom mount/support, or are they held just by the 2 top mounts?
Rick.
« Reply #33 on: June 05, 2019, 01:32:33 PM »
Rick.
Top mount is a length of MDS filled cast nylon bar slotted to fit down over 3/16" steel flat stock. There's a bottom bracket consisting of more 3/16" flat bent into an inverted "L", which attaches at the muffler/passenger peg tab of the frame and to the 'bag via a stud, washers and wingnut.
Upper bracket:
Slotted nylon bar bolts to the cases:
Unfinished bottom mount:
« Last Edit: June 05, 2019, 01:33:00 PM by Antietam Classic Cycle »
