Author Topic: V11 Spot map  (Read 1219 times)
Offline rich4822
V11 Spot map
« on: May 09, 2019, 02:46:32 AM »
Anyone able to explain the big peaks and troughs in the V11 Sport ECU Fuel map?
 For example at 2000 rpm tps 48, is a peak of 193, which drops off at higher and lower rpms and higher and lower tps.
There is also a low fuelling trough at 4000 rpm at wider TPS values.
Offline Murray
Re: V11 Spot map
« Reply #1 on: May 09, 2019, 05:09:36 AM »
Ride by emissions test is done at about 4000rpm.
Re: V11 Spot map
« Reply #2 on: May 09, 2019, 10:36:54 AM »
Don't anything about maps and graphs but dyno runs show those bikes have big torque hole at 2k rpm.
Quite easy to not notice it by running up the throttle.
