Author Topic: Norge timing case gasket reusable?  (Read 169 times)
Offline John in PA
  • Guzzi Hero
  • ML & me
« on: May 09, 2019, 10:42:16 AM »
Have to swap an oil pump for a buddy on a low-mileage (only 8K) 2007 2V Norge this Saturday.  I overlooked the possibility that I might need a replacement chest gasket on hand in case I damage the original. This engine comes stock with the improved steel reinforced gasket. Anyone know the likelihood that it will be reusable?  I have the option of overnighting one from a well-known supplier (thanks, Rick!), just trying to decide  whether a careful individual  is normally not going to have an issue with messing up that gasket and reusing it.
Alas, also well acquainted with Mr. Murphy and his Law...  :sad:   ;-)  JW
John Wells
Hollidaysburg, PA
Buncha Guzzi's
  • Guzzi Hero
Re: Norge timing case gasket reusable?
« Reply #1 on: May 09, 2019, 12:12:38 PM »
I have seen the rubber come off of them w/you pop it off. I'd be safe. I'd say 60/40 chance it will need one, old style ones still work too.
Offline Huzo
  • Guzzi Hero
« Reply #2 on: May 09, 2019, 04:52:26 PM »
I just did the one on my ‘07 Norge and took Pete’s advice regarding this question.
He said that clearly a new one was the go, but he’s re used the original metal one with a dose of copper gasket spray in the past.
I did as he said and had no problems at all.
20 Ounce Stainless Steel Double Insulated Tumbler with donation credit
