Author Topic: Keihin Carbs  (Read 4748 times)
Offline Roy gardner
Keihin Carbs
« on: May 10, 2019, 04:16:17 AM »
I have been digging around in the search facility of this esteemed forum for info on Keihin carbs. I see a bunch of stuff regarding FCRs but I have an engine with 39mm CR Specials fitted.  It is a 1000 LeMans Mk IV which I acquired. When it came to me it had foam pods, which I detest, so when I fitted it into my Convert I fitted a standard LM air box & filter. It also had large diameter aftermarket headers & open megaphone exhaust with crossover under the gearbox. It did go quite well. I now run standard headers & Cali 1100 mufflers, and standard Convert cam.
It starts & idles well, pulls solidly through the rev range if using 1/3 to 1/2 throttle, but if the throttle is opened with enthusiasm, it bogs, then rolling off the throttle gives it some pick up and it takes off again.
Anybody else using CR Specials who could give me some ideas for jet numbers?
Current  settings;
 Float height;14 mm as recommended by several internet sites.
Main Jet; 135
Idle,(slow running) jet;58, screws open 2 turns off seat
Slide; 20 (Smallest cut out available)
Needle; 5179, 2nd notch from top.
I lifted the needle one notch, to 2 recently, made a small improvement, 2 notches, to 3, was too far.
MGNOC L112
1973  850 GT (sold 1979)
1974  160 Stornello (bought new 1978)
1972 V7 Sport, (bought 1979, still running strong)
1977 Convert (bought 2009)
1974  850T (ComposT, pawned to buy Vincent parts!
1985? LM 1000 (saved from a savage, has become hotrod Convert)
Offline mtiberio
    • TiberioRacing
Re: Keihin Carbs
« Reply #1 on: May 10, 2019, 08:50:30 AM »
lifting needle was the wrong direction (unless you mean moving the clip to a higher notch, in which case you are lowering the needle). You want to lean out the needle and/or main jet.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Roy gardner
Re: Keihin Carbs
« Reply #2 on: May 11, 2019, 03:36:34 PM »
Thanks Mike, definitely lifted the needles, from full bottom to 1 ring up. 2 up was too far.
The way it bogs with the slides wide open, then surges as they are eased down again tells me it is too lean, getting a gutsfull of air, not enough fuel, then the slides dropping reduces the air to match the fuel that has been drawn in. Thoughts????
MGNOC L112
Offline Tony F
Re: Keihin Carbs
« Reply #3 on: May 11, 2019, 04:45:17 PM »
I see from the picture in the tyre thread that the carbs have Sudco stickers on them so they probably came from Sudco as a kit. You could try asking Sudco for jetting recommendations for your engine spec which probably differs from what the carbs were originally spec'd for. On my SP I have flat slide mikunis which were originally supplied by Sudco in a kit for and airhead BMW and they were helpful in sorting out the change.
It does sound like a needle/needle jet issue. 5179 seems like a mid range needle according to the (extensive) Sudco catalogue. Did it run cleanly right through the range in the spec it was when you bought it? What ignition system are you running?
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Offline Roy gardner
Re: Keihin Carbs
« Reply #4 on: May 12, 2019, 04:30:39 AM »
Thanks Tony. I didnt realise they offer that service. I have looked at their site, looks positive. Ciao
MGNOC L112
Offline guzzimatic
Re: Keihin Carbs
« Reply #5 on: May 12, 2019, 12:00:39 PM »
What do the plugs look like? From your description you took a hotrodded motor and choked it down,stock air box,smaller headers,Convert cam,so you have way too much carb for a sorta mild motor...I would guess the plugs would be black,carbon fouled... I am not sure if a LeMans IV motor would ever run right with this combination of mismatched parts...I would say a pair of 30 or 32mm Dell'ortos would match the intake and exhaust restrictions,kinda like a CX100.
big Jim Walker bikes:'08 Norge,02'DR650,'84LeMans III,,'78 honda cb750k,'78 BMW R100S,'77 Ducati 860GT ES,'77honda XR75, '76 GUZZI convert,'75 850T cafe[project],'75 RD350 yamaha,'74 NORTON commando,'72 750 Norton flattrack replica,'72 250 Rickman-Montesa,'72 XL250 Honda Mosport[first bike
Offline bodine99
Re: Keihin Carbs
« Reply #6 on: May 12, 2019, 03:22:12 PM »
Its rich
Offline Roy gardner
Re: Keihin Carbs
« Reply #7 on: May 13, 2019, 04:42:35 AM »
Thanks. I was a bit concerned about the "soft" cam, but it's quite punchy in the mid range & still runs out to 100MPH+ comfortably if I ease the throttle open. The air box is a stock LM one, not the horrible old Convert one. :laugh:
I have contemplated fitting a pair of 36 Dellortos I have earmarked for the Round Barrel motor but I am sure I can get the Keihins to work properly with a bit more fiddling. I think 30 or 32's would be worse with those monstrous valves.
It is hard to read plugs with the fuel we have here these days. They are always black & sooty, even 98 octane in my standard V7 Sport.
I had the carbs apart recently to check the float heights then adjusted the idle screws. It is leaner at idle now, reluctant to idle until its had 30 or 40 seconds of holding the throttle just open, whereas previously it started & idled immediately from cold with throttle dead shut.
I think that if the carbs were too big, the airflow through them at idle would be so slow that it wouldnt pick up fuel???
MGNOC L112
Offline Roy gardner
Re: Keihin Carbs
« Reply #8 on: May 13, 2019, 04:45:44 AM »
Its rich
Thanks, so are you suggesting that its getting a gustful of fuel & not enough air then easing the throttles back is slowing the fuel supply down to match the air flow?
Should I go for a bigger slide cutaway or smaller main jets?
MGNOC L112
Offline Roy gardner
Re: Keihin Carbs
« Reply #9 on: May 15, 2019, 04:49:34 AM »
So, I communicated with Sudco, nice fellow called Chad replied with this;
"That is just a big carburetor. So if you get on it quickly at a lower RPMs there is lack of vacuum signal. Basically, the motor isn't sucking hard enough to draw the fuel out of the bowls. You can try going richer on the slow jet and needle to help compensate for that but it won't 100% complete go away. You just have to be a little slower on the throttle till the RPMs are up."
I asked if that is why the standard 40mm Dellortos have accelerator pumps,
He replied; "Exactly, accelerator pumps are there to compensate for that lack of vacuum signal."
So I guess thats why others use Keihin FCR's accelerator pumps?
Guess I'm flogging a dead horse. Need to look for a pair of standard 40mm  LM1000 Dellortos. I do like the light throttle feel, :sad: but I know the Dellortos can be made better   :grin:
MGNOC L112
Offline Dukedesmo
Re: Keihin Carbs
« Reply #10 on: May 15, 2019, 08:30:34 AM »
Not Guzzi related but I have 41mm FCR carbs on my Monster and whilst they run great, it will bog down if the throttle is cracked open too quickly, especially if in neutral - when in gear it generally responds OK but it also has a light flywheel and so is more responsive than a (my) Guzzi.
As above they're big carbs that work best at a decent RPM when the flow is good and as such air speed at low RPM is slow, causing poor throttle response which is one reason that Ducati were early adopters of fuel injection for v-twin race bikes.
Le Mans II
Ducati 916
Ducati M900
Re: Keihin Carbs
« Reply #11 on: May 15, 2019, 08:35:27 AM »
Why not source a couple of FCR39s for the project??  The Keihin FCRs are much better than the Dellortos can ever be.
Offline Turin
Re: Keihin Carbs
« Reply #12 on: May 15, 2019, 11:22:41 PM »
I have FCR 41's m my Lemans SE and they pull from down low, even if you snap open the throttle. no bogging at all. Thing is, I'm running a racing camshaft with high compression pistons.
I'm thinking that lawnmower cam is a step in the wrong direction. A lumpier cam will cause the motor to suck in and expel more air, using more of the carbs potential.
BTW, the B10 from the Lemans 1000 wasn't very radical to begin with.
1985 Sidlow Guzzi
Offline Roy gardner
Re: Keihin Carbs
« Reply #13 on: May 16, 2019, 04:31:59 AM »
Yea, so about the cam...  :laugh: I took out a locally ground cam that was supposed to be a copy of the factory P3 LM race cam. You could ask;how did that grind come to be on a Convert cam??
20+ years ago a local Guzzi nut rounded up 10 or so cams from amongst mates  with a promise of getting the P3 grind done at a great price. I didnt jump in because I wasnt going to disturb my V7 Sport for something it didnt need. However, I was asked by a couple of blokes to assemble their engines with these hot cams. When I put a degree wheel over them they were shocking, the variation between lobes was anything between 3 & 5 degrees for 3 and about 8 for the fourth! The numbers related to nothing particularly, it wasnt B10, P3 or V7 Sport, just random everything in between.  It transpired that the grind had been applied to a Convert cam which I obtained, yep, it was as bad as the others, the grinder operator was consistent. I ran it for a while, and actually saw 59HP on the dyno with the Keihins. Predictably, the power was all near the top of the rev range, and although the response improved from the changes made with needles on the Dyno, it was a death trap at really low revs, it would drop its guts crossing an intersection. Putting the 25-52 lawn mower Convert cam in made it much more rideable, and economical.
Before I disturb that motor, I have promised myself that I will have the hot rod cam built up & re-ground by a reliable shop to the proper B10 LM grind. You are right, it is not particularly radical, but it does give nice power, I do like riding standard LM 1000's.
And if that works well, I will get another done the same for my Round Barrel Convert motor which will inherit LM II heads & 88mm high comp pistons to match & 36mm LM carbs.
Rocker; Why not source a couple of FCR39s for the project??
Because I would need to start again, I am sure you guys would all help with jet, needle & slide info, but I am familiar with Dellortos & have stuff on the shelf to fit,as you do.  :grin:
MGNOC L112
Rough Edge racing
Re: Keihin Carbs
« Reply #14 on: May 16, 2019, 06:11:08 AM »
 My opinion, bigger carbs, when jetted properly. can work just fine with a bit of restraint on the twist grip.. Roll the throttle open, not snap it open like a kid with his first dirt bike...
  OP, what type exhaust and mufflers? the problem you describe does sound like reversion, a momentary over rich situation caused by the effects of intake,cam and exhaust not working together.Air drawn through the carb is expelled and then drawn back in causing an over rich air fuel mixture in a particular RPM range, generally around midrange..It's normally not a factor on stock engines..but...long exhaust length can contribute as alternations to the intake tract length..
Re: Keihin Carbs
« Reply #15 on: May 16, 2019, 07:31:34 AM »
Makes sense.
Offline guzzimatic
Re: Keihin Carbs
« Reply #16 on: May 16, 2019, 10:07:25 AM »
He stated that he is using Cali 1100 mufflers and stock headers...
Offline Furbo
Re: Keihin Carbs
« Reply #17 on: May 16, 2019, 11:17:38 AM »
What he said.
You have a big valve engine with a small valve engine cam, restricted intake and exhaust - What exactly were you wanting in putting a LM 1000 engine into a 'vert??? Why not round up a CAL II/III engine instead? The B10 Cam (standard for LM 1000) is designed for large valve engines. It can work in small valvers (I stuck a B10 into a Cal II motor with 40' Dels) with more open air and exhaust. Seems you taken the heart of a 440M runner and put it in the body of a Semi Pro Bowler.  :thewife:
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline Roy gardner
Re: Keihin Carbs
« Reply #18 on: May 17, 2019, 03:46:53 PM »
What he said.
Because my original Round Barrel Vert motor had death rattles from the pistons & I am a Guzzi owner, I had that collection of stuff laying around and it was a way to keep the bike running until I overhauled the RB.  :laugh:
I agree, it's time to get the spare cam made into a B10  :grin:
And I have scored a pair of 40mm LM Carbs for sensible money locally.
MGNOC L112
Offline Sheepdog
Re: Keihin Carbs
« Reply #19 on: May 17, 2019, 04:04:28 PM »
I would enrich the idle mixture screws (out) another 1 1/2 rotations.
Re: Keihin Carbs
« Reply #20 on: May 17, 2019, 05:03:16 PM »
Pushrod, I know nothing at all about those carbs.  Are they just a normal carb or are they a CV type?
