Author Topic: New 20 spline Convert/Cal II Auto couplers available  (Read 2477 times)
Offline Groover
    • Scooteropolis
Re: New 20 spline Convert/Cal II Auto couplers available
« Reply #1 on: May 13, 2019, 04:59:43 PM »
Thanks for posting. Which ones is the 6/32 sidecar gears? I thought those were 7/37?
Also, and since we are sort of on the topic.. :evil: How are people mating convert automatic transmissions to regular final drives if the splines are different on those (10 teeth I believe). Is there an adapter? Say I wanted to put a convert transmission on a medium length swing arm bike with a 10tooth shaft and final drive, how would that be done?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #2 on: May 13, 2019, 05:10:43 PM »
cut one each coupler in half and weld together a 10/20 coupler.??. BUT I don't think the ratios on any of the 5 speed will work to good as a Convert drive.
Offline mtiberio
    • TiberioRacing
« Reply #3 on: May 14, 2019, 09:30:59 AM »
For a convert (9:34 rear gears) almost all the rear drives from 5 speeds are geared too short. The single exception is an 8:33 rear end which comes out to be the "sidecar" gear set for Converts. Early ones were fine spline, bolt on. Newer ones are coarse spline. You need a split coupler and you have to shorten the pinion spline.
I have had a number of couplers welded over the years. I even had a long one made so I could use a Lemans III swing arm on a Convert. That one snapped and left me stranded (possibly due to the long unsupported mass of the drive shaft and play in the splines). When I have a short one done, I use the counter bored end of the 20 spline coupler, and have the 10 spline end turned down for an interference fit and then welded. Much stronger.
« Last Edit: May 14, 2019, 09:34:14 AM by mtiberio »
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline mtiberio
    • TiberioRacing
Offline ccoli
  • What? Me Worry?
« Reply #5 on: May 14, 2019, 10:18:43 AM »
Would using parts from 2 different ujoints work?  Like a 20 spline yoke to fit the trans and a 10 spline yoke to match the LMIII shaft.
Wisconsin MGNOC Rep
Offline brider
« Reply #6 on: May 14, 2019, 11:44:27 AM »
http://www.mgcycle.com/index.php?main_page=product_info&cPath=35&products_id=5338
You're kidding. I recently paid well over a hundred bones for a NOS one on ebay, then paid a nice member here another significant % of that for a good used one when I thought I lost the new one.
Tempted to buy another one, though....
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
« Reply #7 on: May 14, 2019, 02:28:13 PM »
If the caps of the joints are the same diameter one could build a "hybrid" u-joint.
Offline bigbikerrick
« Reply #8 on: May 14, 2019, 06:15:49 PM »
Thanks for the heads up on that Charlie. I paid around $150. for a NOS one over a year ago, from a seller on ebay. Its nice to know new , aftermarket ones are available now, for a reasonable price.   :thumb:
Rick.
Offline Roy gardner
« Reply #9 on: May 15, 2019, 04:38:59 AM »
That's exactly what I am planning to do when the LemonVert motor goes back into the 1000 LM frame and gets a 7:33 FD for side car work.
I'm pretty sure that the "big", post T3, UJ's share the same cup size & spacing.
Thanks for posting the link, better get me two, one each for the LemonVert & the "standard Round Barrel SoloVert.   :laugh:
MGNOC L112
1973  850 GT (sold 1979)
1974  160 Stornello (bought new 1978)
1972 V7 Sport, (bought 1979, still running strong)
1977 Convert (bought 2009)
1974  850T (ComposT, pawned to buy Vincent parts!
1985? LM 1000 (saved from a savage, has become hotrod Convert)
Offline mtiberio
    • TiberioRacing
« Reply #10 on: May 15, 2019, 08:50:59 AM »
I have had this done. John Chicoine can do it.
Offline Roy gardner
MGNOC L112
Offline Groover
    • Scooteropolis
« Reply #12 on: May 16, 2019, 08:13:44 AM »
The medium shaft is 180mm (LM3,4,5 Mille, 1000s), which seems the one they don't have.
1980 Vespa SI Moped
