Author Topic: Exhaust popping  (Read 4945 times)
Offline Ringosdad
  • 07 Norge
Exhaust popping
« on: May 16, 2019, 04:03:23 PM »
My Norge is popping on deceleration. I have a mistrel exhaust. Anybody know a good fix?
Never look straight up at a bird
Re: Exhaust popping
« Reply #1 on: May 16, 2019, 04:34:40 PM »
 Beetle map , Beetle map , Beetle map .
Re: Exhaust popping
« Reply #2 on: May 16, 2019, 05:01:19 PM »
Yes, Beetle has the 'touch' you might say. I just got one to put in a G. Excellent costumer service also.
Offline lucian
Re: Exhaust popping
« Reply #3 on: May 16, 2019, 05:54:46 PM »
Had the same issue with my Griso with a termi pipe. A beetle map totally transformed the fueling from bottom to top. If you need help to load it he will help with that to. We are fortunate to have him here . See the link below to see more of what he does to make life more enjoyable for us with FI guzzi's
https://wildguzzi.com/forum/index.php?topic=96957.0
Offline giusto
  • Giusto il canne del Como
    • photobucket
Re: Exhaust popping
« Reply #4 on: May 16, 2019, 05:56:18 PM »
Hey Pappa Ringo, let's see the girl
I just bought an 08 Norge last week...fly and ride from North Dakota...a wonderful 1100 miles
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Offline Bulldog9
Re: Exhaust popping
« Reply #5 on: May 16, 2019, 07:01:26 PM »
Plus 100 on the Beetle map. Something to keep in mind is that the Norge seems to pop and burble a little more on overrun then other Guzzi's even in stock state.
MGNOC#23231
Online Ncdan
Re: Exhaust popping
« Reply #6 on: May 16, 2019, 07:02:17 PM »
Make sure all exhaust connections are tight and no leaks.
Offline Buckturgidson
Re: Exhaust popping
« Reply #7 on: May 16, 2019, 07:13:48 PM »
Congrats, 2V Norges are the bomb. My exhaust burbles, who cares?
"It's not your job to be as confused as Nigel." -Spinal Tap.
"Wagner's music is better than it sounds." -Mark Twain
'24 V100 Mandello, Violetta, bianco polare.
'07 Norge, Rosina, the classy one
Offline cappisj1
Re: Exhaust popping
« Reply #8 on: May 16, 2019, 07:48:52 PM »
Check your “collector” or “two into one” pipe. If it’s cracked it will pop on deceleration. I had mine welded. Popping significantly reduced. Ran better too. The beetle map is my next adventure.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
Pizza Guzzi
Re: Exhaust popping
« Reply #9 on: May 17, 2019, 01:23:20 AM »
Well I don't have a Norge but I do have Mistrals and Beetle map on a V7 111 and zero decel popping. In my experience Marks not happy until you are 👍
Glenn.
Offline randy yocum
Re: Exhaust popping
« Reply #10 on: May 17, 2019, 06:47:59 AM »
That's a good point,on inspection my 2 into 1 collector pipe on my 2007 Norge I found it was severally cracked almost in two.luckily it was easy to remove ,and a quick weld job remedied the situation,I'm ready to ride again.
2012 Stelvio NTX
2007 Norge
1998 EV
1981 V-1000 G-5
1997 Ducati 900ss
1983 XL 600R bought new
1978 XS 1100
Re: Exhaust popping
« Reply #11 on: May 17, 2019, 07:49:29 AM »
dB killer installed, or not ??
Re: Exhaust popping
« Reply #12 on: May 17, 2019, 08:20:37 AM »
The reason you will get popping on the overrun with standard mapping on W5AM Guzzis, and probably others, is simple.
Ignoring facts like cracks in pipes or failed gaskets the system works so that when you go to a negative throttle, (Sub 5* of opening.) with factory mapping no matter what the engine speed the ECU will continue to deliver the correct amount of fuel to maintain idle.
Unfortunately, because the engine is pumping harder at higher crank speeds more air gets pushed past the throttle plates so the mixture becomes incombustibly lean but as the engine cycles residual mixture from previous failed cycles will hang around and then every few cycles the mix will become combustible and ignite. When that happens the moment the exhaust valve starts to open the hot gasses exiting the combustion chamber will ignite the previously unburnt charge/s in the exhaust causing the backfiring.
With Mark's maps the fuel is cut entirely on a negative throttle until the crank speed drops to less than, (I think, generally.) 2,700 rpm. With no fuel being delivered there is nothing being pumped through the engine to combust either in the combustion chamber or the exhaust pipe. Hence no 'Popping'.
This system does mean that there is a slight, but noticeable, increase in engine braking and if one is running down a hill and decelerating on a negative throttle, at 2,700 rpm there is a slight lurch as the fuel kicks back in. It's not intrusive or, in the ordinary course of events, even noticeable. There is a long speed limited hill going into Queanbeyan though that finishes at the beginning of the 60 KPH zone. I often amuse myself by rolling down that hill in sixth gear and trying to judge it so that I get the 'Fuel Lurch' at the same point just before the 60k speed sign. I'm pathetically easily entertained though! :boozing: When it does cut back in though, depending on temperature and how serious I am about a fully closed throttle, get one small 'Pop' as the fuel cuts back in but only if I'm being a lazy slob and ambient temperature is between about 25-27*C as seen by the dash! :grin:
Offline M0T0Geezer
    • The Ones I Rode
Re: Exhaust popping
« Reply #13 on: May 17, 2019, 08:22:51 AM »
Ditto that, and specifically: Carefully check the "Y" exhaust collector for cracks (leaks) - Item 13.
'Geezer
Wisdom from the road:
Offline Ringosdad
  • 07 Norge
Re: Exhaust popping
« Reply #14 on: May 17, 2019, 01:47:59 PM »
Offline Bulldog9
Re: Exhaust popping
« Reply #15 on: May 17, 2019, 03:21:17 PM »
Thanks Pete, probably the best explanation I've seen on overrun popping.
MGNOC#23231
