Author Topic: V9 Roamer Handlebars  (Read 4809 times)
Offline Red
« on: May 20, 2019, 10:21:36 AM »
Thoughts on V9 Roamer handlebar swap? V7? Bobber? Or others? (My T100's are perfect, but not the V9s!)
After putting on over 200 miles on it yesterday, I realized that the stock handlebars were designed for the "cruiser feet forward" original design.  But the V9 really is a standard with the proper peg position on the later production.
The stock bars are 34" wide with a hefty rise, something best fit for a heavy Touring Bike, not a very light flick-able motorcycle. (T100 is 32" low rise)
Like all motorcycles, it is best ridden snug to the tank (with my knees a couple of inches from the heads); but then I am confronted with the huge bars that make me sit upright on a hard seat instead of slightly leaned in. I appreciate
 your thoughts!
72 XS 650 Original Owner
76 XLCH Sportster
14 Road King
16 Street Triple R
17 Bonneville T100
17 Moto Guzzi Roamer
Offline mjptexas
Re: V9 Roamer Handlebars
« Reply #1 on: May 20, 2019, 10:42:38 AM »
Here's a picture of my former V9 with Rizoma risers and a Rizoma tapered bar.  Dramatically changed the riding position - lower, more forward lean.
Mike
Mike
'18 R Nine T Urban GS
'17 Griso
'16 XL1200 Roadster
'15 Monster 821
'14 Cali Custom
'14 Vespa GTS300 Super
'15 Vespa Primavera
'75 CB400F
'76 CB550F
Offline Red
« Reply #2 on: May 20, 2019, 02:08:14 PM »
Mike
They look great Mike! Any issues with bar end weights? Is there a size/weight I should be looking for, or am I overthinking it. Thanks!
76 XLCH Sportster
14 Road King
16 Street Triple R
17 Bonneville T100
« Reply #3 on: May 20, 2019, 03:34:14 PM »
If you like the Triumph bars, buy a set and install them on your Guzzi.
I did just that on my 2010 V7 Classic:  Installed Triumph Thunderbird Sport bars because I liked the bend.
Offline mjptexas
« Reply #4 on: May 21, 2019, 09:44:13 AM »
As I recollect, I put the heaviest weights in that Rizoma offered.  You will need new bar-end weights as the Guzzi ones do not work.
Also, the switches are bit finicky to mess with so be really, really careful with them if you switch the bars.
I also bought a drill guide that clamps on the bars to drill the required holes.
« Last Edit: May 21, 2019, 09:46:36 AM by mjptexas »
Mike
'17 Griso
'16 XL1200 Roadster
'15 Monster 821
'14 Cali Custom
'15 Vespa Primavera
'75 CB400F
'76 CB550F
« Reply #5 on: May 21, 2019, 11:48:16 AM »
 your thoughts!
I sat on the new V9 Bobber Sport in the dealership and I was like, "Wow, this feels like a standard instead of a cruiser."
What I like to do is sit on the bike while it is in a stand and with my feet on the pegs close my eyes and put my hands where I think they should be.  Get my wife to take a couple of photos and then you have a good idea of what you need other than the stockers.
Offline Red
« Reply #6 on: May 21, 2019, 08:51:58 PM »
I just swapped bars on a 76 Sportster yesterday and foolish me thought this would be just as easy.  Finicky switches and drilling holes? I will screw it up for sure, maybe have to farm it out.
I was thinking the same thing as soon as I posted it Rocker59, just get the same Triumph bars I enjoy.  I'll have to check V7 ergs because that should have the correct holes and bar end weights.
Thank you!
76 XLCH Sportster
14 Road King
16 Street Triple R
17 Bonneville T100
Offline kballowe
  • - Kevin the Great -
« Reply #7 on: May 22, 2019, 07:37:24 AM »
I bought my 2017 Roamer in January.
It came with an additional (complete) set of foot controls, and with 900 miles on the bike so far - that extra set of controls are still in the box, and tucked away on the shelf.
This bike came from Cadre Cycles in Cincinnati.  They changed out the handlebar arrangement by using a set of Griso risers.  This setup fits me well, and is comfortable.
« Last Edit: May 22, 2019, 07:40:05 AM by kballowe »
Offline tris
« Reply #8 on: February 05, 2022, 02:01:51 AM »
Sorry for resurrecting an old thread, but I have a similar issue with my Roamer
Did you get it sorted Red?
I'm trying to get my head around the geometry,  but does rolling the bars forward,  bring you forward or does it do something strange?
Cheers
1993 TW125 "POS" - Resting
Offline chuck peterson
« Reply #9 on: February 05, 2022, 06:00:59 AM »
I did a bar swap like on a similar design Nevada
Transformed it. Leaning slightly forward now instead of holding a broomstick while leaning slightly backwards
From wider to narrower width
From higher to lower rise
From a flatter bar to a little more bend
Bar end mirrors
I almost want to go down a size in tire width too, from 110/90 I’m thinking of a 90/90, like a T or T3. The front seems a little overreactive at below 15mph until you stop
Your cables can become a challenge. They might be too long when you get a narrower bar..
I played w the bars a long time before drilling holes for the control levers. Where your fingers fall will change quite a bit when you lean forward more…personal preference but with a new bar you get to set those angles yourself
I love it!!
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline greer
« Reply #10 on: February 05, 2022, 06:21:09 AM »
Would something like a V7 bar be a good starting point?  I like to position my levers just so.  Time and time again I've cut the handlebar nubbins out of the switch gear to avoid the fuss of drilling holes in the bars.  If needed, a round of electrical tape on the bar will have the switch gear fitting tight as ever.  You'll have your choice of 7/8" bars.
Sarah
Offline Moparnut72
« Reply #11 on: February 05, 2022, 08:25:36 AM »
The Triumph bars may create an additional issue.  I am not sure about the T100 but my T120 has 1" bars. Was a problem when I wanted to install Oxford heated grips. I had to use some intended for Harleys. I am not crazy about the larger diameter of the grips but I suppose I will get used to them.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline tris
« Reply #12 on: February 05, 2022, 09:29:28 AM »
Cheers, Everyone
I think that I'll see if I can work out the rise and pull back are on the existing bars and see what options there are
Offline Zenermaniac
« Reply #13 on: February 08, 2022, 08:09:51 PM »
The Roamer risers arch slightly back toward the rider. Wonder if they could be turned around and so pull the bars more forward a bit.
Offline tris
« Reply #14 on: February 09, 2022, 12:07:59 AM »
I think that if you did that,  the tips of the bars would point forwards which would be a bit weird
That being said I wielded the spanners last night and rolled them forward.
Moved about 2" and could go a bit more.
I'll report once I've ridden the bike some miles
« Last Edit: February 09, 2022, 12:08:57 AM by tris »
Offline Zenermaniac
« Reply #15 on: February 10, 2022, 09:29:14 AM »
Turn the risers around, not the bars. Lol.
Offline tris
« Reply #16 on: February 11, 2022, 05:54:51 AM »
I knew that  :embarrassed: :embarrassed: :embarrassed:
That will teach me to read things properly!
