Author Topic: Gas in crankcase  (Read 5948 times)
Online frozengoose
  • To eaches his onus...
    • smiles from nowhere
Gas in crankcase
« on: May 23, 2019, 02:02:02 PM »
After riding the 850T between snow/rain storms, decided to take the 650 (v65sp) out. Since I'm too cheap to buy two batteries, switched it over from the T, put some air in the tires, and rolled it out of the garage to check the oil since that side of the bike was against the wall. When I unscrewed the oil cap, a plume shot out, covering the apron with a gas/oil mix. So put the plug back in, got a pan, and drained a couple more quarts of the pungent liquid. At first I thought I'd forgotten to close the petcocks last fall, but no, they were in the off position. So I guess I need new petcocks. MG sells a repro pecock that's pretty inexpensive, anyone have experience with them?
Later I talked to my mechanic neighbor and he says he always closes the petcocks on his Harley, even when he stops for just a few minutes. And in the fall he drains the gas from the tank. I always filled it up cause I thought there'd be less problems with fumes and gas degradation over the winter. Anybody have thoughts on that?
Big Jon
Jerry Zee
Offline grebmrof
Re: Gas in crankcase
« Reply #1 on: May 23, 2019, 02:20:39 PM »
If gas has drained past the petcocks and into the carbs and then on into the engine, I think it also means that the float bowl needle valves are letting fuel out of the float bowls and on into the engine, past the rings and down into the sump.  Someone will be along shortly to correct me, I'm sure.  New petcocks and maybe time to rebuild and refurbish the carbs too?  Whenever I think the problem I'm having is carb related, it is usually ignition...but in this case I really do think it is the carbs and the petcocks.
For winter I always fill the tank after putting in the correct proportion of Stabil, then run the bike for 25-35 miles, retop the tank in the garage, close the petcocks and call it a day.  I also used to squirt some oil into the cylinders and crank it over a few times with a rag over the spark plug hole - while this makes some blue smoke in the spring, it goes away and I go on my way.  Also, instead of ethanol gas, I sometimes use 100% gas and no Stabil - that will last a lot longer than ethanol plus Stabil.
'08 Triumph Bonneville T100
Offline bigbikerrick
« Reply #2 on: May 23, 2019, 02:40:24 PM »
Everything grebmrof said is correct. You need to replace the float needle valves, as well as the petcocks. I have no personal experience with the petcocks from MG cycle, but everything those guys carry is  usually very good stuff.
Rick.
Online frozengoose
« Reply #3 on: May 23, 2019, 02:53:35 PM »
Yeah, I left out that part out about the float needles. The neighbor said while they're undoubtedly worn, the bike has 40k miles, the petcocks are likely the main problem since it hadn't happened before. He said just replace the petcocks and keep'em closed when not riding. Then rebuild the carbs next winter.
Thanks for the input.
Big Jon
Jerry Zee
Offline stubbie
« Reply #4 on: May 23, 2019, 07:47:09 PM »
Don't forget to change the oil. :thumb:
« Reply #5 on: May 23, 2019, 08:41:01 PM »
I'd be rebuilding the carbs now, rather than waiting until Winter.
Online frozengoose
« Reply #6 on: May 23, 2019, 10:58:02 PM »
And that's because what exactly? The bike ran fine last fall, there was no sign of float needle problems then.
What's your opinion of the BAP petcocks. They seem to be the only ones readily available and were not highly rated on another forum.
Thanks, Jon
Big Jon
Jerry Zee
Online Tom H
« Reply #7 on: May 24, 2019, 12:59:03 AM »
The tips of your float needles could be worn out or just dried out and not sealing. If you want, you could wait and see if they seal. I would just replace them. Fairly easy and fairly cheap.
Offline Guzler
  • 1977 850 T3
« Reply #8 on: May 24, 2019, 01:26:46 AM »
petcocks galore: https://www.treatland.tv/new-puch-peugeot-motobecane-vespa-moped-parts-s/88.htm?searching=Y&sort=3&cat=88&show=99&page=1&f-petcock=66
« Reply #9 on: May 24, 2019, 08:38:18 AM »
Thanks, Jon
Because the float needles and/or floats obviously aren't doing their job and riding it like that could lead to far larger issues.
I've used the BAP petcocks on a number of projects and haven't had any issues with them at all.
Online frozengoose
« Reply #10 on: May 24, 2019, 10:46:32 AM »
Big Jon
Jerry Zee
Offline Two Checks
« Reply #11 on: May 24, 2019, 10:48:36 AM »
Cheap....er frugal fix....Briggs & Stratton inline fuel shutoff. About 5 bux a piece.
Works on my bikes and my home made bench tank.
1987 1000 SPII "Il Duce' II"
Online frozengoose
« Reply #12 on: May 24, 2019, 11:04:03 AM »
Here's the link to the forum that talked about BAP petcocks. Maybe just the style for Nortons was bad?
https://www.accessnorton.com/NortonCommando/bap-petcock-warning.11643/
My neighbor, who's been a mechanic for 40 years and has worked on everything from airplanes to heavy equipment, was adamant that the carbs were probably ok since it took 6-7 months to leak down. But I probably won't ride it until they're fixed. As long as the 850's running, it's NBD, just one more project on the list!
« Last Edit: May 24, 2019, 12:30:23 PM by frozengoose »
Big Jon
Jerry Zee
Offline Two Checks
« Reply #13 on: May 24, 2019, 11:15:22 AM »
But they aren't okay. It was proven by the crankcase being full of fuel.
Btw before you crank the engine pull the plugs and spin the engine-don't do it with the plugs still connected!
If you don't do this you risk hydrolock and bending a rod.
« Reply #14 on: May 24, 2019, 11:24:29 AM »
For fuel to get into the crankcase, BOTH the petcocks and the needles and seats are crying out.
If you needle valves are rooted, then there’s nothing to stop the float bowls overfilling when you’re riding.
Online frozengoose
« Reply #15 on: May 24, 2019, 11:43:46 AM »
OK, I get it. Don't ride bike, bad for engine. Will fix, eventually, when the more pressing projects are done. Summers are short up here and work on stuff like that gets prioritized. But I will pull the plugs and check for gas in the cylinders. One interesting thing was that when I tried to drain the rest of the gas from the tank, nothing came out when the taps were turned on, but then about a quart drained when I turned to reserve. Shouldn't it all have drained out if the petcocks were leaking?
Big Jon
Jerry Zee
« Reply #16 on: May 24, 2019, 11:52:31 AM »
Well, all the umming and arring in the world will mean nothing much, because it’s all conjecture.
You could fill the tank and put @ couple of hoses on the taps, turn them on and see what happens, but you’re gunna’ have to trace the system through anyway.
The beaut thing about these sort of dramas, is that if you work through methodically, you can SEE the problem.
Online frozengoose
« Reply #17 on: May 24, 2019, 12:13:47 PM »
Well that's often true, sometimes when fixing things there's a eureka moment when it all becomes clear, but other times, not so much. But that's a good idea to check out the petcocks before removing them.
Thanks, Jon
Big Jon
Jerry Zee
Online cliffrod
« Reply #18 on: May 24, 2019, 12:31:42 PM »
Even though the fuel usually exits from the same spigot on modern petcocks, Main and Reserve intake circuits on a petcock are separate circuits. It's not odd for one to work properly and the other to fail- probably more common than for both to fail at the same time.  At least that's what happens when mine have died in the past.   Sounds like the reserve circuit still works.  That's why fuel remained after the rest of it leaked out via the main circuit and fell to/below the level of the petcock's main circuit intake stack/tube.
Check to see what's bad so you don't waste resources or short summer time, but I would also recommend not riding this bike until you have this problem sorted.  Good luck.
Online frozengoose
« Reply #19 on: May 24, 2019, 12:52:58 PM »
OK, that makes sense. Thanks, Jon
Big Jon
Jerry Zee
« Reply #20 on: May 24, 2019, 01:27:02 PM »
Thanks, Jon
Yeah it’s funny isn’t it.
Sometimes you have apparently conflicting symptoms that could have a hundred causes, but when you find the reason, EVERYTHING that you saw suddenly becomes perfectly clear.
 The cause will always make sense of the symptoms..
But.
The symptoms won’t always make sense of the cause.
« Last Edit: May 24, 2019, 01:29:11 PM by Huzo »
Online frozengoose
« Reply #21 on: May 24, 2019, 01:50:57 PM »
But.
That's true, mechanicing in general can be kind of zen like, but don't want to go too far down that road. Never could finish reading that book.  Jon
Big Jon
Jerry Zee
« Reply #22 on: May 24, 2019, 01:54:16 PM »
Yes but if a book is written and nobody reads it..
Does that mean it does not tell a story...Grasshopper ..?
Online frozengoose
« Reply #23 on: May 24, 2019, 04:35:56 PM »
Well I was referring to Zen and the Art of Motorcycle Maintenance, of course, which in IMHO is an overly long, totally over rated book. I think the grasshopper thing was from a David Carradine / Kung Fu show about Chinese Taoist Buddhist or something, I never watched that program. Zen is Japanese I think. Anyway, while it's definitely important to pay attention to what you're doing, you don't want to over think things or you'll never gett'em done. But maybe I'm over thinking this?
Getting back to the float needles, I'm not sure why my neighbor was so adamant about not rebuilding the carbs, but we talked about it for quite a bit and he didn't budge from saying that it wasn't necessary. But like I always sez, to eaches his onus
Big Jon
Jerry Zee
Offline Two Checks
« Reply #24 on: May 24, 2019, 04:52:11 PM »
Quote from: Huzo on Today at 01:54:16 PM
That's what the pictures are for...
On my Cal III the petcock has no reserve. Just on and off with the control being in the R side cover. I gutted it and made a block off plate. Then I installed the aforementioned Briggs shutoff valve.
Good luck with your repairs!
Online frozengoose
« Reply #25 on: May 24, 2019, 05:02:15 PM »
You got that right. Lots of times the pictures in the shop manual, or even the parts book, can be more helpful than the text. I'm still looking at petcocks, not sure which kind to use. And will replace the float needles, of course! Thanks for your comments, Jon
Big Jon
Jerry Zee
Offline Diploman
« Reply #26 on: May 24, 2019, 05:20:49 PM »
I put a set of these BAP petcocks on my refreshed V50 II.  They work flawlessly and are inexpensive.  Curiously, they are identical to the OE petcocks fitted in 1980 - so it must have been a good, solid design, no need to change.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=30&products_id=682
2015 KTM 390 Duke
« Reply #27 on: May 24, 2019, 05:46:26 PM »
 :thumb: This has been my experience a well.
Online frozengoose
« Reply #28 on: May 24, 2019, 05:52:08 PM »
OK, thanks, I may just order the BAP's from them, along with gaskets sets and float needles, of course! I think they're closed for the weekend, so have some more time to over think things.
Big Jon
Jerry Zee
« Reply #29 on: May 25, 2019, 07:59:36 AM »
I have been doing the "long winter's nap" on bikes out in California for years. Here's what I do:
Putt to the local gas station
Put in 2 oz Stabil
Fill er up
Putt back
Close non leaking fuel shutoff  :smiley:
Drain carbs
Put on center stand
Put block under engine to keep front tire off the concrete.
Put wrench on negative battery cable and unhook it.
Put my worries on the doorstep..
It's sat as long as a year this way without issue
 :grin:
