Author Topic: Stelvio - one cylinder  (Read 1882 times)
Offline bettythebear
« on: May 23, 2019, 02:05:21 PM »
Hey all, the other day I started up to leave a breakfast joint and something didn't feel right. It felt like it was only firing on the left cylinder. I shut it back down, gave everything a tap, tried again, and it worked just fine. Knowing that I'm not the best mechanic in the world, is there anything I should check? Bike only has about 5000 miles.
2011 v7 Classic
Offline pyoungbl
Re: Stelvio - one cylinder
« Reply #1 on: May 23, 2019, 03:17:53 PM »
Spark plug wires/caps were a known issue.  Maybe Leafman60 will chime in with the NGK replacement part.
'13 V7 Special (red/white)
Offline Dilliw
« Reply #2 on: May 23, 2019, 03:47:13 PM »
His excellent write up.
https://wildguzzi.com/forum/index.php?topic=61267.0
George Westbury
Austin, TX
Offline severely
« Reply #3 on: May 24, 2019, 07:08:41 AM »
Double down on the connection issues. My Stelvio had a secondary wire NEAR the coil and drove me nuts with misfire, bad idling etc. Yes it is a PITA to remove the covers the first time but I'll bet your issue is similar to mine. Good luck. :bike-037:
« Reply #4 on: May 24, 2019, 07:51:17 AM »
Thanks guys, I'll look into it. I know my aux lights are good, as AF1 had taken care of that before they sold it to me. I definitely haven't ridden as much as I was hoping since I got it in Sept, but it definitely caught me off guard the other day.
I'm also going to try a new map to go with the Mistral I put on. It's not terrible, but I definitely feel like it could be better. The mistral sounds better than stock when underway, but has an odd little puff/chuff noise when idling. Honestly, neither the Norge I had, nor this Stelvio sound as good as the v7 with mistrals on it.
2011 v7 Classic
Offline Guzzistaracing
  • Norwegian with a love for all Italian
« Reply #5 on: June 07, 2019, 02:56:59 PM »
Did a repair on a Stelvio some years ago and it turned out to be a defect injector. You could try to take both out and check that both gives a nice spray.
Ex.85�suzuki katana
 85`Le Mans 1000
`?? 1100 sport
`51 Ariel KH500
`07 Griso 850, black
`71 Nuovo Falcone civile
`78 BMW R100RS
`98 Centauro
`07 Norge
Current:
`99 Quota
`84 V65
