Author Topic: question:alternator rotor bolt  (Read 10213 times)
Online nc43bsa
Re: question:alternator rotor bolt
« Reply #30 on: May 28, 2019, 08:32:00 PM »
Just don't do as I have (more times than I'll admit to) and leave the wrench in the alternator bolt when you crank the engine.   :angry:
« Last Edit: May 28, 2019, 08:32:28 PM by nc43bsa »
1990 MilleGT
Offline Roy gardner
« Reply #31 on: June 01, 2019, 03:48:35 PM »
That's what I figured. So there's no pressure to get it out - it's not like you can't ride it in the meantime.
It's common knowledge to turn the engine using that bolt, but I never thought it was a good idea. I definitely wouldn't without the spark plugs removed, and by the time you've done that, one side's valves could already be adjusted via rotating the rear wheel.
Possibly the "common knowledge" came from the BMW manuals. My R90S factory propaganda recommended it. However, BMW probably purchased good quality hard bolts, I have experienced some Guzzi alternator bolts made of something about as hard as cheddar cheese.  :grin:
MGNOC L112
1973  850 GT (sold 1979)
1974  160 Stornello (bought new 1978)
1972 V7 Sport, (bought 1979, still running strong)
1977 Convert (bought 2009)
1974  850T (ComposT, pawned to buy Vincent parts!
1985? LM 1000 (saved from a savage, has become hotrod Convert)
Offline 750S3
« Reply #32 on: July 15, 2019, 04:00:00 PM »
Managed to get the bolt out and replaced it.
It’s all good. Here at Peggy’s Cove, Nova Scoria
Puch125
Honda250
Kawasaki750
Ducati 900GTS
Moto Guzzi 750S3
Moto Guzzi Griso 8VSE Tenni
Online nc43bsa
« Reply #33 on: July 15, 2019, 04:28:13 PM »
Which removal method ultimately worked?
(for future reference)
« Last Edit: July 15, 2019, 04:28:55 PM by nc43bsa »
1990 MilleGT
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #34 on: July 15, 2019, 04:33:51 PM »
If all fails, here is a the tool: I think you can get it other places too, but that's what it looks like. https://www.ebay.com/i/382756854837?chn=ps
This is a tool for alternator removal.  The Seller indicates that the tool is made of stainless steel (does not specify the grade, type)...
Isn't stainless steel a lot softer than the hardened steel required to pop the rotor off the taper?  I would think that this tool is NOT what you want.
My 850T5 came with a Moto Guzzi-supplied tool.  I am wondering if the quality (and specifically the hardness) is up to the job?  Has anyone used the Guzzi tool?
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
jwinwi
« Reply #35 on: July 15, 2019, 05:51:34 PM »
One of the best feelings ever. Congratulations!
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #36 on: July 15, 2019, 10:33:05 PM »
Any opinions or thoughts?
Offline Matt Story
  • Flint, MI
« Reply #37 on: July 15, 2019, 11:11:15 PM »
Stainless is typically softer than steel alloys.  Maybe there are some exotic alloys that aren't.  That product looks like a common bolt that has been turned down.  That said, I have bought a number of things from the seller BSANUT and have never been disappointed.  What I did for my rotor removal tool was find a long 1/4-20 alloy SHCS (grade 8 or better) and chop off the head so the rod is 1/4 x 2" lg.  This is a nice clearance diameter to slip it into the crank thread.  Then use an M8 bolt threaded into the rotor to push against it - not necessarily the rotor bolt.
'75 850T - First & only owner
'77 Honda CB750 Supersport
'02 BMW R1150RT
Flint, MI
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #38 on: July 15, 2019, 11:21:14 PM »
Many thanks; that's helpful.  Also, your comment on not necessarily using the alternator bolt (i.e. don't over-use it... use it only for its intended purpose) - that likely has merit :). Again, thanks.
My '85 850T5 only has about 4,500 miles on it.  The alternator has never been off the crankshaft taper.  I need to liberate it, to set the non-automatic timing chain tensioner (or at least to check it).  Plus, I worry about things being in close contact for THAT long of a period of time.  Having said this, it has lived in a 70 degree F dry basement all of its life.
Incidentally, apparently you are supposed to bring the removal bolt to some reasonably-high torque value, and then are supposed to rap the nose of the rotor with a rawhide-faced mallet or something that "gives" a 'wee bit (or does not damage the rotor-nose).  The percussion is supposed to remove the rotor with a snap.  Just trying to apply torque to the centre bolt will not be effective, and risks stripping either the crank female threads, the bolt threads, or the bolt head (like the OP must have done, here).
« Last Edit: July 15, 2019, 11:25:20 PM by Cdn850T5NT »
Offline Matt Story
  • Flint, MI
« Reply #39 on: July 15, 2019, 11:25:50 PM »
If you're going into look at the timing chain tensioner, you really should replace it with a Valtek style.  They are cheap and work well.
http://www.mgcycle.com/index.php?main_page=product_info&products_id=347
'02 BMW R1150RT
Flint, MI
Online nc43bsa
« Reply #40 on: July 16, 2019, 12:31:02 AM »
I was instructed to rap the BOLT with a hammer after putting it under sufficient torque.
And to have a hand nearby to catch the rotor when it pops off.
« Last Edit: July 16, 2019, 12:31:20 AM by nc43bsa »
1990 MilleGT
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #41 on: July 16, 2019, 12:37:05 AM »
Ah, so you're saying it is proud-of-flush with the rotor.  Ah ha.  Then the notion of using a good quality but expendable bolt - rather than the original allen head bolt - doubly has merit.
In answer re the automatic timing chain tensioner - I would prefer to NOT go there (as I believe it means removing the timing chain + sprockets to gain access and make the swap)???  NP... except for the red loctite.... Ugly.  I could be wrong, here.  But I would prefer to NOT have to heat the hell out of the sprockets.
« Last Edit: July 16, 2019, 12:43:51 AM by Cdn850T5NT »
Offline Matt Story
  • Flint, MI
« Reply #42 on: July 16, 2019, 06:33:31 AM »
I believe the tensioner can be upgraded without removing the chain.  Haven't done that.  Mine was all apart anyway.  Don't know about the red loctite.  Someone else here has done it I'm sure and can advise.
'02 BMW R1150RT
Flint, MI
« Reply #43 on: July 16, 2019, 09:00:20 PM »
This 750 S3 has the upgrade cam chain tensioner installed
You might be able to replace the cam chain and tensioner without removing the motor but I think it would not be worth the restricted space leaving the motor in the frame.
« Reply #44 on: July 16, 2019, 09:26:17 PM »
Removing the timing chain is easy and if the nuts have red lock tight I doubt it came from the factory that way.
Offline 750S3
« Reply #45 on: July 17, 2019, 07:06:08 AM »
Thanks for all the help and tips. Got the bolt out with a combination of Chuck’s method and a torx + impact driver
Puch125
Honda250
Kawasaki750
Ducati 900GTS
Moto Guzzi 750S3
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #46 on: July 17, 2019, 09:54:24 PM »
Thank you All, for your info re the timing chain and the tensioner.  I did not consider the whole matter of whether the timing chest cover would come off (at all) with the engine remaining in the frame  :sad:.
The implication of this, is that if a person retains the manually-set timing chain tensioner (and intends to readjust it at interval to account for wear) then it MAY BE that you simply cannot do this with engine-in-frame - and then it REALLY IS compelling to have the automatic tensioner in place, once and for all.
Comments, please, re access to solely adjust the manual chain tensioner, engine-in-frame (please)?
I also attach a couple of photos that would seem to indicate that the timing chain / sprockets have to come off, in order to put the automatic tensioner in place (more significantly - in order to REMOVE the manual one, it seems).  Commments?
« Reply #47 on: July 17, 2019, 10:15:31 PM »
 Stainless steel comes in many different grades and saying stainless is softer than steel is not a correct statement,  steel comes in many different grades as well. :tongue:
« Last Edit: July 17, 2019, 10:16:41 PM by John A »
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #48 on: July 17, 2019, 10:42:26 PM »
Sorry, I was thinking specifically austenitic stainless steels. like type 304, 304L, 316, 316L  Sorry, not the correct ASTM (/ AISI?) names.  And this of course, then, is only a small bit of the range of stainless steels.
Right you are...
« Last Edit: July 17, 2019, 10:43:44 PM by Cdn850T5NT »
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #49 on: July 18, 2019, 07:19:56 PM »
Hey, just to re-ask the question:  for a T5, and SPII, a Lemans IV or V, a Strada, an SPIII, or a MilleGT - all the same (or very close to the same Tonti frame, square-barrel big-block) - can a person take the timing chest cover off while the engine is still in the frame?  I am seeking to adjust the manually-adjustable timing chain (slack-side ?? I think) tensioner.
Online nc43bsa
« Reply #50 on: July 18, 2019, 07:38:57 PM »
I installed the Valtek in my MilleGT in the frame.
I supported the engine with a few blocks of wood and removed the long bolt.
« Last Edit: July 18, 2019, 07:42:33 PM by nc43bsa »
1990 MilleGT
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #51 on: July 19, 2019, 09:48:53 AM »
Hey nc43bsa and/or Others - did any of you find Loctite on any of the sprockets?  And I should confirm: you do need to remove chain/sprockets to install the Valtek, correct?Thks, All, BTW.
« Last Edit: July 19, 2019, 09:51:27 AM by Cdn850T5NT »
Online TOMB
« Reply #52 on: July 19, 2019, 10:22:48 AM »
 Cdn850T5NT
 Tensioner installed with engine in the frame.
If you insist on removing the tensioner in one piece  then you may need to remove the sprockets.
If your going to replace the chain then cut the chain off , remove the tensioner .
Replace the chain with one with a master link. Problem solved.
This was done on my convert 30,000 miles ago .NO ISSUES .
Im sure that others have done it this way .
TOMB
« Last Edit: July 19, 2019, 06:32:19 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline Cdn850T5NT
  • Cdn850T5NT
« Reply #53 on: July 19, 2019, 11:57:26 AM »
Now that's a good thought; I had not considered that.
Thx
« Reply #54 on: July 19, 2019, 12:23:22 PM »
When I changed the tensioner in my EVT, I was a bit nervous about pulling all the gears and not getting every thing back right. I read up on how to do it by searching this board and asking.
One thing I did seemed to make things a bit easier. I turned the crank until the timing marks were lined up like they should be. Then I took a black marker and put a mark on a tooth of each gear as well as a corresponding mark on the chain. Doing this made it so that I did not have to guess how many links between the gears when I put it back together. If your replacing the chain as well, it may still work if you transfer the marks to the new chain.
You "CAN" change the tensioner without pulling the gears. After reading up on how to do it, I felt it was easier/safer to just pull the gears.
One last tip, drain the oil before you pull the front cover.
Good luck,
« Reply #55 on: July 19, 2019, 02:26:43 PM »
 :smiley: :thumb:
