Author Topic: Drilling holes in windscreen  (Read 10832 times)
Offline Gusable
Re: Drilling holes in windscreen
« Reply #30 on: May 29, 2019, 07:53:29 AM »
Excellent info thank you
1994 California 1100
Online inditx
« Reply #31 on: May 29, 2019, 11:56:12 AM »
Vetter's late-model Windjammer used two pop vents. In this photo I'd guess the vents are about three inches, assuming that's a 7-inch headlamp.
 :thumb: Thanks
inditx
This is the day.....
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
« Reply #32 on: May 29, 2019, 01:38:50 PM »
« Last Edit: May 29, 2019, 01:39:55 PM by janguzzi »
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
Online MGrego
« Reply #33 on: May 29, 2019, 01:53:18 PM »
The Vetter vents didn't fix my buffeting problem unfortunately, leaving them out did.  They just didn't allow enough air through to equalize the air pressure.
Just my experience in one case.  Hope they work better for you --
Online Ncdan
« Reply #34 on: May 29, 2019, 03:31:57 PM »
I known these vetter vents have been added by members here who swears by them and I’m not questioning their assessment, That being made clear. In 1983 our 12 member motor unit utilized 1982 and 81 Honda 900CB customs with the vetter fairing as shown in the picture I offered. We all was in agreement that we Could not tell any  difference one way or another, if the vents were
opened or closed. However the lowers that we added in the winter did make a lot of difference with wind control.
« Last Edit: May 29, 2019, 03:33:45 PM by Ncdan »
Offline Gusable
« Reply #35 on: June 02, 2019, 09:31:52 PM »
Well I did it. Drilled four 2.5 inch holes right in the middle. Only had time to test the outer two.  They seemed to improve things. I can’t help but think it’s gonna work!
« Reply #36 on: June 03, 2019, 08:12:17 AM »
They'll work.   :thumb:
Online PeteS
« Reply #37 on: June 03, 2019, 10:23:17 AM »
You could also fit a vent used on the 1800 Honda Goldwings, With the deflector angled it eliminates buffeting at least for the driver. 15 bucks on eBay.
Offline Gusable
« Reply #38 on: June 08, 2019, 11:18:56 AM »
Little update.  Finally got to test the holes out at highway speed. Noticeable improvement! Not perfect but if scoot forward just a smigde it’s great    I might play with visors now to make it 100%
« Last Edit: June 08, 2019, 11:24:41 AM by Gusable »
Offline flower_king001
« Reply #39 on: June 08, 2019, 11:57:18 AM »
Good to hear!!
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline Gusable
« Reply #40 on: June 18, 2019, 10:11:02 PM »
Little update and a question.   I cut the hump out of my neds seat and took off the airhawk pad. That put my at eye level with the top of the barn door.  One of the best rides I’ve had on the bike!! Like 97.52% fixed! BUT the lower seating position isn’t great.  I’m acquiring a Corbin seat which will put me up higher in the turbulent air.  Should fix seat/tailbone/ergo issues but now back to buffering issues.  I’m thinking about trying a puig clip on visor.  I had one on a Honda nc700x that absolutely transformed that bike!  It would give me a “ taller “ windscreen and the two panels of airflow.  Anyone here tried a puig visor or Mra visor?
Offline Andy1
« Reply #41 on: June 19, 2019, 05:14:44 AM »
I had bad buffeting from my R100R BMW windscreen - I experimented with tapeing a piece of cardboard along the top to raise the screen height.  I expected it to maybe flap or blow off but it stayed there and showed me that an extension would work.  I then trimmed it down to find the best size and copied it in polycarbonate.  The final version is held in place with 2 plastic number plate screws - so in the event of a crash it will break off - and it has edge trim.  Been in use around 80,000 miles.
So before buying anything it may be worth experimenting with tape and cardboard.
Andyb
« Reply #42 on: June 22, 2019, 07:35:18 AM »
But would it LOOK good?  :wink:
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline Gusable
« Reply #43 on: June 22, 2019, 08:38:30 AM »
I think I’m gonna find out! The large puig is 13 in across
« Reply #44 on: June 22, 2019, 11:40:14 AM »
i think this is what you might need  :wink:
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline Sheepdog
« Reply #45 on: June 22, 2019, 01:41:05 PM »
I tried the Vetter Pop-Vents on a Rifle 22" windshield. It was a pretty good solution, too. However, I tried a 23" shield that was raised about 1" above the headlight and raked back to just under my sight line (I'm 5'11"). I look over the windshield, but the buffeting is negligible. It's the best solution yet.
IMG-0535" border="0
With Pop-Vents
Full-Size-Render" border="0
With the 23" shield.
Offline Gusable
« Reply #46 on: June 22, 2019, 01:42:54 PM »
Good looking sheepdog
« Reply #47 on: June 22, 2019, 02:21:08 PM »
I’m having buffeting issues on my 98 ev.  In another thread here about helmets someone mentioned drilling hole in the big hard door screen I have.  Does anyone have a picture of said holes? I’m thinking of doing a series of like 1 inch holes right under my guzzi sticker.. thoughts?
I bought aviation pop vents and with the appropriate size hole saw added them to a few of my bikes.
You can go from closed, vent popped open, to removed for more air flow.
« Reply #49 on: June 22, 2019, 02:57:22 PM »
Best buffering solution to date...also looks quite cool!  :grin:
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #50 on: June 22, 2019, 06:33:44 PM »
Online inditx
« Reply #51 on: June 25, 2019, 06:41:57 PM »
No windshield is indeed good looking and no buffeting however.....bugs, road stuff, wind etc. sometimes calls for one.
Anyway, I tried drilling holes and the vents, no workie for me.
Anyone want a holy windshield?  :blank:
inditx
inditx
« Reply #52 on: June 25, 2019, 07:00:22 PM »
This windscreen was awful when I put it on, it's acceptable now that I raised it over the headlight and angled it back.
Offline Gusable
« Reply #53 on: June 29, 2019, 06:19:44 PM »
Well... I finally got a Corbin seat.  It fixes the leg ergo problems! It looks pretty good! It seems to be ok on the tailbone issue! But now my lower back is killin me. Real bad too... I do have the backrest but not tried it yet.  But this is about windscreens and not my seat lol.  It did put way up higher in the air so the turbulence is at its worst. Bikes virtually unridable.  I get to work, take off screen completely and ride home.  Not too bad... I’m digging it. Heavy winds kick in.  Tries to literally pull me off the bike BY THE HELMET!!! Worst motorcycle experience if I’ve ever had. So my lower back is shot now and I’m back to fixing issues. No screen and backrest next.  Then puig clamp on large visor set to high. Thanks for all the help.  Now I need a drink...
Offline Gusable
« Reply #54 on: July 13, 2019, 07:33:14 AM »
Update— puig large clamp on visor fixed my issues. Puts the air right over my head and it’s on the lowest setting.  Extremely satisfied!!!  It fixed another bike in the past and came through again!
