Author Topic: Stornello Sport  (Read 1901 times)
Stornello Sport
« on: June 01, 2019, 11:05:47 AM »
This little cutie just arrived this morning. One family owned since new.
Re: Stornello Sport
« Reply #1 on: June 01, 2019, 11:11:31 AM »
Very nice.  In for service, or did you buy it?
Re: Stornello Sport
« Reply #2 on: June 01, 2019, 11:27:35 AM »
In for service. Hasn't run in years (decades?), so will need the "usual".
Offline Ringosdad
  • 07 Norge
Re: Stornello Sport
« Reply #3 on: June 01, 2019, 12:31:34 PM »
Charlie, do you think they would miss it if you don’t send it back?  :rolleyes: :cool:
Never look straight up at a bird
Offline Green1000S
Re: Stornello Sport
« Reply #4 on: June 01, 2019, 12:45:56 PM »
I want it!
Lauri
2014 Green Stelvio NTX
2016 Stornello #101
1972 Bultaco Matador SD
2016 KTM Duke 390
1968 Riverside MW 125
Ciao!
Offline Roebling3
Re: Stornello Sport
« Reply #5 on: June 01, 2019, 03:02:46 PM »
Fresh fuel and outside of a small amount of fuzz, on a battery terminal, Zooom. May I please be the first, after you, of course, for a test ride? R3~
Re: Stornello Sport
« Reply #6 on: June 01, 2019, 04:24:55 PM »
Going to take more work than that. No spark, so at the very least, points need to be cleaned and gapped, fresh plug. Carburetor is gummed up big time, tank has failed liner of some sort inside. Not a lot of compression. Should clean the centrifugal oil filter (which requires removing the left engine cover). Throttle cable is broken (looks like an Ambo upper will work), clutch cable not far behind.
Re: Stornello Sport
« Reply #7 on: June 15, 2019, 10:05:16 AM »
Looking for an "oil filter" for this. It's the little cylindrical strainer screen at the drain plug (part no. 5515 2200).
Re: Stornello Sport
« Reply #8 on: June 15, 2019, 11:07:02 AM »
OEM cables are unobtanium - You'll have to improvise or make them.  Seriously doubt that oil screen does much.  I had to buy an large hex socket to drop the plug.
