Author Topic: Extended Length Shocks for V9 Roamer  (Read 2198 times)
Offline greer
« on: June 07, 2019, 05:48:31 AM »
The factory shock measures 13.75 inches center to center of the eye bolts, best we can tell.  How about a set of shocks measuring in the neighborhood of 14.50" in an attempt to increase ground clearance a bit?  If you were to try such, which manufacturer would you choose?
Sarah
Offline Petrus Rocks
Re: Extended Length Shocks for V9 Roamer
« Reply #1 on: June 08, 2019, 08:25:51 AM »
My concern is how much angle is too much for the cardaman joint.  I have raised my shock length about 3/4" so far on my Cal II.
Offline greer
« Reply #2 on: June 09, 2019, 05:13:09 AM »
Yes, that's our concern, too.  We're looking at the GTM 2S Twin Shocks with 20mm increased length, per Todd this will not cause an issue with the driveline on the Roamer.  We'd like a few more opinions and and hope to hear some past experiences if we could.  How did it go with your Cal II?
Sarah
Offline MMRanch
  • MMRanch
« Reply #3 on: June 09, 2019, 10:31:23 PM »
You might try the HD Shocks , off ebay before you invest big $$$ .   :wink:
2016 V7-II Stone
Offline TalbotMatra
« Reply #4 on: June 10, 2019, 01:29:13 AM »
Moto Guzzi V9 Bobber,
« Reply #5 on: June 10, 2019, 02:10:28 AM »
One of the very early posts I made here involved me suggesting putting a big block Guzzi on the centrestand and running the bike in gear for a particular reason.
Before I knew who Pete was (so that’s how new I was) he posted a suggestion in no uncertain terms that this was not a recommended practice due to the magnified angle on the u joint and a couple of other factors.
Armed with this knowlege, I would seek his advice and follow it were it me..
Not only will you be working the joint through a larger angle as would have been my error, you are also loading it heavily..
The argument suggesting this is cruel, is now very clear and I would not do it.
« Last Edit: June 10, 2019, 02:11:41 AM by Huzo »
Offline greer
« Reply #6 on: June 10, 2019, 05:29:16 AM »
Thanks, everybody.  Yes, really hoping Pete chimes in.  Way back in the early discussion and speculation regarding the Roamer longer shocks were mentioned, that's what got us thinking.
MMRanch, cheaper would be better, at least as an experiment.  We don't know Harleys other than our experience with Sportsters.  Is there a particular model's suspension you would consider?  Thanks again.
Sarah
« Reply #7 on: June 10, 2019, 10:33:06 AM »
depending on how handy you are you can make shock extensions that bolt to the shock mount and the shock before buying shocks.
Offline MMRanch
  • MMRanch
« Reply #8 on: June 10, 2019, 10:55:11 AM »
 greer
I've changed shocks length on my LS650 (belt drive) by asking the seller about eye to eye length.    Also noticed the belt gets tighter as the line from pulley to pulley grows , so I have to run the belt a little looser at the normal ridding position .
That advice about "Leaving-it alone" might be a good idea on a shaft drive ???  :huh:
How much spline engagement do you have to play with ?
2016 V7-II Stone
« Reply #9 on: June 10, 2019, 11:26:09 AM »
This is starting to sound like what the Doctor said the day I was born.
“This is gunna’ get ugly...”
Offline Red
« Reply #10 on: June 10, 2019, 04:13:39 PM »
I am just going to go with a pair of IKONs, it should do the trick inexpensively. If the 3.8 " travel is managed well, you could stay with the stock length. If you do raise the back, it will quicken the steering which is already quick on the Roamer.  Best of luck sorting it out!
72 XS 650 Original Owner
76 XLCH Sportster
14 Road King
16 Street Triple R
17 Bonneville T100
17 Moto Guzzi Roamer
Offline greer
« Reply #11 on: June 15, 2019, 04:53:28 PM »
I'm mostly hoping to gain a little ground clearance, better handling would be a plus. Even one up, no luggage and me at 160 lbs ready to ride it grinds the pegs (feelers removed)  in curves that are really not that bad. We are headed out this week on a 6000 mi trip with the bike loaded for traveling so I'll have to be pretty cautious going onto curves. To me the steering doesn't feel that quick, not much different from our Sportster which shares the same tires.   Doug
