Author Topic: Cruise control for Norge  (Read 3627 times)
Offline giusto
  • Giusto il canne del Como
    • photobucket
« on: June 08, 2019, 08:24:27 AM »
Hello
I'm sure this has been talked about here...just cant find it.
I'm looking for a cruise control for my 2008 Norge and was hoping to find some input and suggestions. My buddy Randy mentioned there was someone on this site a while back manufacturing a quality unit which I'd like to find.
Thanks for the help
cheers
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Moto
Re: Cruise control for Norge
« Reply #1 on: June 08, 2019, 09:50:46 AM »
Hello
Thanks for the help
cheers
Assuming [!] you're referring to an electronic cruise control, I don't think anyone on this site has manufactured one. However, you should look here for excellent instructions on mounting a Rostra electronic control on a Norge: https://www.guzzitech.com/forums/threads/cruise-control-for-the-norge.4583/. You'll have to register to download the pdf file.
One user considered getting a kit manufactured for the Griso, but hasn't mentioned the idea for quite some time.
Moto
Bert Remington
« Reply #2 on: June 08, 2019, 10:35:24 AM »
Related articles:
https://www.guzzitech.com/forums/threads/electronic-cruise.5838/
https://wildguzzi.com/forum/index.php?topic=93396.msg1474868#msg1474868
https://wildguzzi.com/forum/index.php?topic=63286.msg965791#msg965791
https://wildguzzi.com/forum/index.php?topic=63253.msg965792#msg965792
https://wildguzzi.com/forum/index.php?topic=70702.msg1097629#msg1097629
Please post your installation pictures if you add a cruise control.  I have an MC Cruise on my BMW and its great for freeways.  If I install one on my Norge I will probably use the GTM airbox lid suggestion.  And you always need another farkle. :smiley:
Offline giusto
    • photobucket
« Reply #3 on: June 08, 2019, 11:10:42 AM »
Thanks Bert and Moto
I'll have a look at the links.
I was actually referring to a mechanical throttle lock at the bar end...ihonk has one made by a fellow somewhere in Europe that he got through this site long ago and it's really nice.
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
« Reply #4 on: June 08, 2019, 11:11:35 AM »
I just went with a Throttlmeister and was going to recommend that route, but I just googled them and looks like they are not around anymore!
Offline JeffOlson
« Reply #5 on: June 08, 2019, 11:43:37 PM »
Kaoko Throttle Lock is what I have used.
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Offline jdgretz
  • Proud Owner of a Red Norge
« Reply #6 on: June 09, 2019, 03:57:33 AM »
I've been using the Go Cruise for years.  Simple and it works well enough for the Norge.
jdg
1999 Honda Helix - Zippy
2008 Honda Goldwing
Offline craigclu
« Reply #7 on: June 09, 2019, 11:19:32 AM »
I use a Throttlemeister on my Norge.  I don't really care for it and seldom use it.  The typical roads I travel in Wisconsin are in rolling hills and what becomes 85-90 on down slopes is 55-60 on the up-sides.  It's just too erratic for comfortable use for me.  It could have some good application in the ideal road situation but in my case, I have little use for it.  They're easy to install and the price is moderate so it would be pretty easy to give one a try for your duties....
He who is without oil shall cast out the first rod...”-Detonations 5:72.
« Reply #8 on: June 09, 2019, 12:19:46 PM »
But that’s not going to roll the throttle off and apply it, to adjust to changing conditions.
Why can’t you just get a car one and attach the magnets to the disc and hook the actuator to the linkage ?
They are only magnets passing a sensor, they don’t know if they are on a bike or a car.
Offline Idontwantapickle
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
« Reply #10 on: June 09, 2019, 03:27:32 PM »
The O ring can be effective, depends on the bar end and the gap to the grip.
I picked up one of those plastic "clothespins" that slips on the grips and locks the the clothespin against the brake lever.  Takes all of about 20 seconds to install, costs about $20.  Also picked up a Chinese aluminum one for $20 on ebay but haven't bothered to install it.
I also those thumb switch throttle locks for both my Guzzis.  Those take about an hour to install.
« Reply #11 on: June 09, 2019, 04:21:04 PM »
I like the "clothespin" one as well.
72 Eldo
84 BMW R100RS
Offline malik
« Reply #12 on: June 09, 2019, 05:06:46 PM »
I prefer the simple clothes peg one - the GoCruise - simple, elegant design, nothing to go wrong. I've tried some of the more complicated versions, but the simplest seems best for me. On all my bikes. I've done some 400,000km with them. They are not perfect, the throttle doesn't move a tad with the vibration & bumps, but a light finger on the throttle holds it. So it does the job of resting the right hand, and it's quick & easy to slacken off.
