Author Topic: Replacing fork seals  (Read 2988 times)
Offline nealwp
« on: June 08, 2019, 04:08:53 PM »
I need to replace the fork seals on my Bassa and it looks straight forward. How difficult is it to pull them out of the brackets?
« Last Edit: June 29, 2019, 06:47:43 PM by nealwp »
Offline bete
Re: Replacing fork seals
« Reply #1 on: June 08, 2019, 05:15:52 PM »
Taking them off is very easy.       Getting the bolt out of the bottom that holds the rod in is the tough part, at least on mine.
Offline Guzzidad
« Reply #2 on: June 08, 2019, 05:54:56 PM »
   Impact gun makes short work on that bottom bolt
Offline bete
« Reply #3 on: June 08, 2019, 10:05:46 PM »
       I'm going to pick one up tomorrow.
Offline nealwp
« Reply #4 on: June 29, 2019, 06:40:46 PM »
OK I have my forks drained. I'm looking at the seal. Upon inspection it looks good. I have cleaned the tube well with a clean room cloth. I'm wondering if I should leave well enough alone and put fresh fluid in it and put it back together.
How difficult is it to insert a new seal?
« Reply #5 on: June 29, 2019, 07:17:19 PM »
Easy, pop off wiper, remove clip, pop out seal.  You are there now, just do it.
Offline nealwp
« Reply #6 on: June 29, 2019, 11:54:44 PM »
My concern is getting it started squarely and working it into place without damaging the seal. The manual mentions using "special tool Z". I don't have this tool.
Offline Mackers
  • Five miles or 1000ft...how hard can it be?
    • Motoguzzimackers Moto Guzzi Diaries
« Reply #7 on: June 30, 2019, 02:30:28 AM »
Nealwp,
I did my Metal Stone years ago.  I made the mistake of using after-market seals instead of Guzzi ones and had to redo the job a year later.
http://motoguzzimaintenance.wikifoundry.com/page/Moto+Guzzi+Metal+Stone+Fork+Seal+Replacement
Raymond Massey:  "No doctor, I think this calls for something special.
                  I think, perhaps, the Melbourne Method!".
Peter Lorre:  "Not the Melbourne Method!!  Please!!"
            - Arsenic and Old Lace, 1944.
('06 Breva 1100 and '02 Cali EV - '01 Metal Stone deceased).
Offline nealwp
« Reply #8 on: June 30, 2019, 06:23:09 AM »
My seals are from Harper's. Failing to get them in squarely could bite me too. Did you use a tool or did you just  press them in.
Offline Cage Free
« Reply #9 on: June 30, 2019, 10:56:14 AM »
Special tool consists of getting an appropriate size of piece of PVC from home depot. Been doing it this way for years without any problems.
« Reply #10 on: June 30, 2019, 11:22:18 AM »
If you pull out the tubes, I use a big socket and seat them firmly on shim & you're done. If you don't pull tubes, I have a 2' PVC tube ripped down the center that I squeeze against tube and keep outside the lip area on seal & inside the leg. They seat firmly with 1 big wack.
Offline nealwp
« Reply #11 on: June 30, 2019, 11:56:36 AM »
 :thumb:OK I pulled the seal. There is no turning back. As it turn out the vacuum attachment on my shop vac is the perfect fit for the inner rim of the seal. The old seal really did need to be pulled so I could clean everything out. There was gunk built up around the edge of the seal. It would have leaked if I put it back in service that way.
One good whack huh? I'm going for it.
« Reply #12 on: June 30, 2019, 01:19:32 PM »
That is w/syn 80w90 smeared on outside of seal and this on the lip
https://www.motionindustries.com/productDetail.jsp?sku=00782658
I use this stuff alot, it makes leaks disappear.
