Shorten a CalVin Windshield?
Topic: Shorten a CalVin Windshield? (Read 4199 times)
janguzzi
Gaggle Mentor
June 12, 2019, 03:43:49 PM »
Maybe shorten a California Windshield could also solve the buffeting problem for some drivers (deflectors, taller shields, vents and holes were discussed already).
A friend of mine is a graphic designer and I have asked her to make some proposals.:
original
90%
80%
80% and much shorter
Last Edit: June 12, 2019, 03:58:07 PM by janguzzi
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
Gusable
Re: Shorten a CalVin Windshield?
Reply #1 on:
June 12, 2019, 04:06:23 PM »
Great idea! Then have rifle or ???? Make them
1994 California 1100
Global Moderator
Reply #2 on:
June 12, 2019, 04:11:55 PM »
If you are attempting to lessen the buffering by shorting the shield height.... all I have to say is good luck! That pretty much like the theory if I remove the windshield in a rain storm I won’t get as wet. 😂😂😂
Last Edit: June 12, 2019, 04:18:31 PM by Ncdan
janguzzi
Gaggle Mentor
Reply #3 on:
June 12, 2019, 05:39:17 PM »
I have no idea if this could work
maybe somebody here already tried this?
Maybe a shorter shield moves away the buffeting from your head.
On my V11 Le Mans the fairing also made the riding experience noisy. Only a new helmet (BMW Sport Integral) solved that problem for me.
I once tried a taller shield (customer-specific, made by MRA) on that fairing but the result was disappointing. The taller shield added more noise + buffeting.
The stock CalVin windshield (I tried different positions) looks good but riding faster than 90 km/h (56 mph) is not fun.
On my Griso (naked bike, just add a fly screen) I do not have those problems at all.
Last Edit: June 12, 2019, 05:41:19 PM by janguzzi
Kind Regards
www.janguzzi.de
Sheepdog
2007 Moto Guzzi California Vintage
Reply #4 on:
June 13, 2019, 09:06:59 AM »
Jan, I have considered this, also. A combination of more rake and less height should result in clean airflow to the rider's chest. The smaller area of the shield will create less low pressure and the greater rake better laminar flow. A shorter shield would probably make the bike more stable at speed, as well.
flower_king001
Reply #5 on:
June 13, 2019, 09:27:25 AM »
Quote from: Gusable on June 12, 2019, 04:06:23 PM
Actually Guzzi makes them!
Clean airflow to the face IMHO is the only way to go as so many things can cause buffering
Here is some good info:
https://www.clearviewshields.com/choosing-correct-shield-height/
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
grebmrof
Reply #6 on:
June 13, 2019, 02:29:41 PM »
The stock windshield on the CalVin that I got last month was very annoying and ruining the ride. In my frustration, I just removed the whole thing. I tried flip flopping the brackets side to side, but that wouldn't have done enough. A new larger screen (Rifle?) will make sense when the weather gets colder or in the event I take a trip anywhere. The stock screen is in the corner for now. Much cleaner air flow with no screen.
'08 Triumph Bonneville T100
Sheepdog
Reply #7 on:
June 13, 2019, 03:25:29 PM »
Rifle has a jig for the Vintage windshield mounting brackets. They have a variety of heights, widths, and tints or will do custom heights. They fit very well.
janguzzi
Gaggle Mentor
Reply #8 on:
June 14, 2019, 01:53:13 AM »
@ Tom: How did you mount your foglights?
One solution is the holder from this set:
https://www.stein-dinse.biz/product_info.php?language=en&products_id=15202
Maybe it is this one:
https://www.stein-dinse.biz/product_info.php?products_id=14235
Kind Regards
www.janguzzi.de
grebmrof
Reply #9 on:
June 14, 2019, 04:42:17 AM »
Hi Jan,
When I removed the stock windscreen, I left the vertical blades in place, so the mounting brackets of the foglights were unaffected. I've thought of putting a small bikini fairing on the bike using those mounts - but that might be like putting a bikini on a fat girl and that could hurt your eyes! The vertical blades don't look the best, but they are nice pieces of stainless steel. The cleaner airflow when moving along is a vast improvement. I wear a visored helmet so the vibration and wind noise with the stock windscreen was really annoying to me.
janguzzi
Gaggle Mentor
Reply #10 on:
June 14, 2019, 05:51:54 AM »
Somebody from the German Guzzi Forum also has a CalVin without a windshield, but he made special holders which support the original fog lights holders.
Last Edit: June 14, 2019, 05:53:28 AM by janguzzi
Kind Regards
www.janguzzi.de
Sheepdog
Reply #11 on:
June 14, 2019, 09:13:11 AM »
...or you could use what Guzzi used on the California Vintage concept bike:
https://www.motomachines.com/hepco-becker-twinlights-moto-guzzi-california-special-sport-jackal-stone-touring-with-windshield
janguzzi
Gaggle Mentor
Reply #12 on:
June 25, 2019, 07:40:03 AM »
And here is how an improved larger windshield could look like (a bit higher, wider at the top and more space above the headlight to ensure airflow):
Kind Regards
www.janguzzi.de
