Author Topic: Fuel system 2000 Jackal  (Read 1455 times)
Offline rudyr
« on: June 14, 2019, 05:23:57 PM »
I got a blessing today!  At home not on my way to Mn. next week.  Started my Jackal and fuel is spraying out down under the seat.  Question can I use what kind of fuel line to repair?   And should I change pressure reg.  It’s 5:00 o’clock can’t order any thing till Monday. Rudy
Re: Fuel system 2000 Jackal
« Reply #1 on: June 14, 2019, 05:56:47 PM »
 Fuel injection hose rudy .
 Oh , be sure and post on Luap's thread in the stickies .
Offline Rich A
« Reply #2 on: June 14, 2019, 06:45:45 PM »
Sounds like it may be from around the fuel pump if it is spraying and not just dripping. Some people have used SAE hose without problems, but I've had better luck with metric.
Rich A
Offline Kev m
« Reply #3 on: June 14, 2019, 08:38:05 PM »
We're going back years but I feel like I used hose from NAPA on my Jackal.
« Reply #4 on: June 14, 2019, 09:01:08 PM »
Its only 40 PSI any hose rated for gasoline at that pressure should do.
« Reply #5 on: June 14, 2019, 09:10:26 PM »
What Kev m and Kiwi_Roy said.  I got rubber fuel line from NAPA.  The hose on my '97 Cal 1100i had the number an fuel injection printed on it.  When I went to NAPA, the rubber fuel line they supplied only had the same part number printed on it minus the "fuel injection" part.  Rubber hose works fine.
On a side note, I just replaced a nylon fuel injection line from the connector to the injector rail on a PT Cruiser.  Hard to work with.  Took me a couple of tries.  Heat gun did not work properly to soften the line.  I ended up leaving it in the sun. It soften enough to install.  A little grease on the barb connectors and was able to twist/push the line on.
Offline rudyr
« Reply #6 on: June 15, 2019, 05:58:25 AM »
I haven’t pulled it off yet. What size fuel line?rudy
