Author Topic: 8/33 final drive  (Read 1860 times)
Offline handyandy
8/33 final drive
« on: June 17, 2019, 03:23:39 PM »
The 8/33 final drive on my 93 Cal was too tall for my liking. Found a 7/33. Like it much better. The 8/33 is for sale. If anyone interested please pm me. Ciao Andy
Offline bigbikerrick
Re: 8/33 final drive
« Reply #1 on: June 17, 2019, 07:36:55 PM »
The 7:33 "sidecar" gears work really well in the Californias. I have a set in My 03 aluminum, and never want to go back to the 8:33 , even without the sidecar!  I like to be able to use 5th gear, and the way the bikes takes off from a standing start with the lower gears is amazing. :thumb:
Rick.
Offline guzzista
« Reply #2 on: June 17, 2019, 08:24:03 PM »
AFAIK the 7/33 final drive gear is the most common for many Tontis but is not the sidecar  gearing which is 7/37 to my knowledge. I would like to add that for riding cross country on the big slab the 8/33 does quite well. I also have 7/33 gears swapped in my Cali1100 and am quite happy with the change.
« Last Edit: June 17, 2019, 08:56:17 PM by guzzista »
Offline Idontwantapickle
« Reply #3 on: June 18, 2019, 02:15:23 PM »
I got out my ancient guzzi notebook 'cause you got me thinking about the sidecar gears. The lowest one I know of is 6/32 or 5.334 to 1. It has the finer splines like the Convert 9/34 (3.77 to 1) gears which are also the tallest in Guzzi-dom. The only 7 tooth pinion set I know of is the 7/33 but there could be later versions I am not aware of.
I like that the gears can be swapped on the loop and tonti bikes with relative ease since they used the same design for so long. If only the CARCs were like that!
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Groover
    • Scooteropolis
« Reply #4 on: June 18, 2019, 02:50:36 PM »
There is a 7/37 for the newer-of-the-older bikes.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=72&products_id=916
I'm looking for one by the way..  :grin:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #5 on: June 18, 2019, 04:55:28 PM »
Cool, I'll add it to the notebook. I would think a 7 tooth pinion would be more durable than 6.
72 Eldo
84 BMW R100RS
