Author Topic: Griso Stuck in Lexington Ky, Probably water in gas  (Read 5959 times)
Offline Mike Tashjian
Re: Griso Stuck in Lexington Ky, Probably water in gas
« Reply #30 on: June 20, 2019, 07:24:35 AM »
If you have any water lingering around in your tank a siphon hose can easily be poked around to get it out.  I would consider running fuel with ethanol for a while to soak up any water that can't be siphoned out.  Changing the fuel filter would be on my short list too.  If the gas cap let in a bunch of water I would inspect it closely as the water may have carried some crap into it which is causing the vacuum issue.  Mike
