Author Topic: V7II Rear Shocks  (Read 3117 times)
Offline guzzi4me
V7II Rear Shocks
« on: June 18, 2019, 09:22:49 PM »
Finally decided to upgrade the rear shocks on Olivia.
Considering these...
https://gtmotocycles.com/collections/suspension/products/gtm-s2w-ifp-twin-shocks
http://www.mgcycle.com/index.php?main_page=product_info&cPath=197_200&products_id=4849
Appreciate any comments or other options.
Ride safe and often,
Jeff
Jeff S
Fruita CO
01 Jackal "Mistress"...sold
Re: V7II Rear Shocks
« Reply #1 on: June 18, 2019, 10:11:24 PM »
My backside knew within the first 10 miles on my V7 that a rear shock upgrade was mandatory.
I think both of the options shown would serve you well, and be a huge improvement over the stock shocks.
I installed Progressive Off Road shocks based on the recommendation received from Dave Richardson at Moto International.  They have to be mounted upside down to fit the V7, but this shock can be mounted either way.  The Progressives were in the same price range as the shocks you are considering
« Last Edit: June 18, 2019, 10:13:36 PM by Dave Swanson »
Offline malik
« Reply #2 on: June 18, 2019, 10:54:16 PM »
I have the Ikons on the V7S and the Gazi on the V7C. The Ikons are good, the Gazi better (so they should be for 50% more money). BUT a test ride of the V7 III Racer showed me what a different high quality shocks, properly set up can make. Chalk & cheese. Go for the best your wallet can stretch to. Include the set up costs by an expect in your calculation.
Offline jpv7
« Reply #3 on: June 19, 2019, 08:18:43 PM »
I'm not a fan of the 1 size fits all Ikons.  I mean i'm sure they are good quality, but the best solution is always the one set up specifically for you.  That's been my experience with suspension.  Yes, good ones are $
Offline Bulldog9
« Reply #4 on: June 19, 2019, 08:20:37 PM »
Buy direct from Hagon, they will custom valve and spring for your weight. $avethegreenbacks!
Very satisfied with mine, together with KTech fork springs, the Hagon Enduro shocks transformed my Stornello from punishing to plush. No more bottoming out, crashing of herniating discs..... I've never ridden a bike with worse OEM shocks than the stock units on the V7ii, and I am NOT picky with suspension bits.
« Last Edit: June 19, 2019, 08:23:19 PM by Bulldog9 »
MGNOC#23231
Offline jpv7
« Reply #5 on: June 20, 2019, 09:27:04 AM »
Hagons are what I have on the rear of my V7ii - they work great for me too.  But I heard that the gentleman assembling them (forgot his name) is no longer around.  Does that mean no more US support?
Online mechanicsavant
« Reply #6 on: June 20, 2019, 11:07:39 AM »
I got my Icons from MG cycles. Quite a bit cheaper than from Icon USA . So far so good.
Online Frenchfrog
« Reply #7 on: June 20, 2019, 11:30:13 AM »
Shock factory are the very hot ticket amongst the guzzisti in France...run by an Englishman.....much better value than the Ikons and Hagons and still at a sensible price.....http://www.shock-factory.co.uk/
Offline guzzi4me
« Reply #8 on: June 20, 2019, 06:46:16 PM »
Thanks for all the ideas!
The Shock Works looks like a high quality unit as do the Ikons. I have had Hagons on the V11's and have been happy. Must say it is nice to have choices...sometimes in the Guzzi realm you have a choice of maybe 1!!
Jeff
Jeff S
Fruita CO
Offline Warren Rhen
« Reply #9 on: June 20, 2019, 11:20:13 PM »
I have Ikons on my V7 stornello. I can't say I'm impressed w/them. Slightly better than stock shocks set very soft but I should have tried the hagons. past experience says I would have liked them better Love my bike though after 15K
Cheers,
Warren
16 Piaggio BV 350
86 Citroen 2CV6 Dolly
18 Dodge Charger R/T
